Old 06-05-2006, 10:52 PM   #13 (permalink)
Mega3500's Avatar
edit: linky worky now. (go figure) they don't list an oil/fuel filter for '06 though?
What's BHAF? Big Honkin' Air Filter?
2006 MegaCab 3500 SLT CTD
light khaki metallic, SRW, 4x4, 48RE, Superlift leveling kit, 315/70R17 BFG ATs, RanchHand front bumper, ARE Z-series bed cap, Quadzilla Commander, Bushwacker flares, WetOkoles.
Mega3500 is offline   Reply With Quote
Old 06-05-2006, 11:05 PM   #14 (permalink)
Guest
Posts: n/a
link works there site was down for a few mins
and yes on the bhaf
Old 06-06-2006, 05:30 PM   #15 (permalink)
Mega3500's Avatar
what about '03+ motors?
Old 06-06-2006, 05:43 PM   #16 (permalink)
Guest
Posts: n/a
Contact Nate , Not sure if the mounts are the same price ect....
And Im unaware of the Fuel Delivery Status on 3rd Gen Rigs Some one will key in'
DM
Old 06-06-2006, 05:44 PM   #17 (permalink)
Tech Specialist
Drew's Avatar
the problem is how the VP44 is lubricated. The VP44 pump is actualy lubricated and cooled by the diesel fuel itself. take away the diesel and the pump will eat itself up in short order.
the CP3 pump in the 03+ HPCR trucks is lubricated and cooled by the engine oil like the VE and P7100 pumps. The 03-some 05's still have the fuel filter mounted lift pump, the same pump the VP44 has. it will die, it is just a matter of when. however a nice aspect about the CP3 is when the lift pump dies it wont take the CP3 with it since it is lubricated by the engine oil. in about 05.5 on these trucks use an in-tank pusher pump that is supposed to be a bit more reliable.
is a fuel pressure gage mandatory for lift pump equiped HPCR trucks. not realy, but it is nice to get an early warning of lift pump problems before you are stranded.
so to answer your question for your 06, I doubt you need one in stock form, but once the mods start appearing I would suggest haveing one.
04.5 6spd QC 4x4 4.10's line-x on the rockers, TST, smarty 5-31-09, 475/853
73K still on the stock clutch, lift pump and all other internals
giving her 'H' 'E' double hockey sticks every day
Drew is offline   Reply With Quote
Old 06-06-2006, 05:48 PM   #18 (permalink)
Diesel-Dan's Avatar
I know the steering column mount is differant for the 03's +. but every thing else should work....just off the top of my head....i used to install TONS of gauges! As far as fuel pressure, its not as improtant as the 2nd gen 24V's. BUT when mods do happen...its not hard to suck down to 0-1 PSI and run your rail dry..
Great Idea.......
Dan MacDonald
2002 TDI Jetta...stock for now
Diesel-Dan is offline   Reply With Quote
Old 06-06-2006, 05:48 PM   #19 (permalink)
ndurbin's Avatar
Mounts are the same price for the 03+ trucks so only thing that would change the price is if one wanted a Autometer Electronic FP gauge as the Isspro's and Dipricol's are mechanical.
http://img.photobucket.com/albums/v3...tinb4k/New.gif
1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck
2002 Ford F150 Super Cab - Daily Driver
ndurbin is offline   Reply With Quote
Old 06-06-2006, 06:17 PM   #20 (permalink)
Mega3500's Avatar
Thumbs up
Thanks for the info. I hate being such a noob about all this. Oh well, that's why I'm here, to learn!
Old 06-06-2006, 06:48 PM   #21 (permalink)
Mkline's Avatar
Just checking to make sure that is a BHAF and not just an OEM replacement filter. They don't show a picture. That price seems too good to be true.
Matt
1995 Dodge 3500 150,000 miles, Isspro boost & pyro, custom ground plate forward, AFC forward, starwheel just enough smoke, GSK washer mod, 3" straightpipe, BHAF
Anyone Like Working On Classic Cars/Trucks? www.redwingsteelworks.com
Mkline is offline   Reply With Quote
Old 06-06-2006, 07:01 PM   #22 (permalink)
Guest
Posts: n/a
The Napa 2790 BHAF and the FleetFilter 42790 Is the exact same thing no diffrence at all same box ect
DM
Old 06-06-2006, 07:13 PM   #23 (permalink)
Mkline's Avatar
Thanks DM, I'm definatly going to order from there.
Matt
Old 06-06-2006, 07:19 PM   #24 (permalink)
Guest
Posts: n/a
Good Move ! Then Make you up a heatshield from the template and your good !
DM
