Boost on stock head gasket? - Page 2 - Dodge Cummins Diesel Forum
Old 02-07-2008, 02:32 PM   #13 (permalink)
get vert's Avatar
How are you turning up and down the boost like that? Im new to cummins. Mine is only going up to 25 psi.
99 Quad cab lb, 24v, 13" lift, twins, ddp 150, fass, etc.. SOLD : 04.5 CC, custom 6" lift, billet trans, ats 4k, 5" pipes, ddp50 SOLD: 98 12v CUSTOM Carli built!, Current 08 THUREN BUILT
get vert is offline   Reply With Quote
Old 02-07-2008, 03:37 PM   #14 (permalink)
THE Hood Stack Guy!
BossHawg600's Avatar
Originally Posted by JSPulliam21 View Post
So, it is a good idea to re-torque the head bolts to make sure they are what they should be?
its would be a real good idea to check them and then crank'em down. A few sled pullers around here run head bolts and crank them down and do fine. but I wouldnt trust it forever.
2008 Ford FX4 F350 6.4 Powerstroke.....I dont really belong here anymore
93 EXT Cab DRW - Unnamed Puller ( For Sale)
BossHawg600 is offline   Reply With Quote
Old 02-07-2008, 03:45 PM   #15 (permalink)
JSPulliam21's Avatar
You use an adjustable boost elbow. It regulates the pressure the wastegate sees, and keeps it closed longer. You need more fuel to make more boost, though
That is what I thought, but when I was asking some questions about adjusting my valves a bunch of folks told me it did not matter unless I had studs. Guess I'll pull the valve cover again.
98.5 3500 QC LB NV4500 4x4 3.55 SRW, DiPricol gauges, BHAF, 4" Silverline, FBD 150's, Edge Comp, Valair 3800 DD, Draw Straw, 1/2" Filter to IP Line, FASS 95HPFP, 2" Leveling Kit, DSS, 35" Toyo M/T, KDP killed 403HP/899 TQ
JSPulliam21 is offline   Reply With Quote
Old 02-08-2008, 02:05 AM   #16 (permalink)
bmac's Avatar
I'm surprised about all the variances here. I have heard 48 to be the magic number with 50 being stable. I am not going to go to rings, but will be doing studs with my turbo upgrade in the coming 2-months. I want to run a solid, consistent and reliable 48.
FOR SALE!!! 99 Dually, Edge 5 (not tapped), 100HP sticks, ATS 5dsk Trans and Co-Pilot, FASS150, Cammed, Gages, ATS 3-piece Header, Banks Intake, 4:10s & Lockers, AmSoil, Hadley air horn, 5-inch exhaust
bmac is offline   Reply With Quote
Old 02-15-2011, 09:42 PM   #17 (permalink)
humincumin's Avatar
45 psi and havent had any problems yet knock on wood!
04.5 ccsb white sport airdog 100 smarty jr fluidampr 90hp nozzels 5" straight arp mains and head studs haisley rod bolts afe intake 2nd gen exhaust manifold bored .40 over coated pistons and bearings goerend built trans on order
humincumin is offline   Reply With Quote
Old 02-16-2011, 12:48 PM   #18 (permalink)
Super Moderator
High boost isn't the only factor in blowing the head gasket, timing can cause much more problem.
Advanced timing causes higher cylinder pressures, excess boost just adds to it.
Don't know how the electronic timing works an a 24 valve or if the controller boxes you guys use alter timing but on a fixed timing engine like a 12 valve once you get over 19° it's time to think about studs and rings.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
