| General Diesel Discussion Discuss General Topics related to the Cummins , Dodge Rams , Other Diesels Ect....NO ADVERTISING |
#25 (permalink) | |
Diesel Poser
![]() Join Date: Oct 2007
BTW - Nice avatar.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew stealth shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8 When a strong man armed keepeth his palace, his goods are in peace - Luke 11:21 |
#26 (permalink) |
most of the large "v-block" engines are essentially two of their smaller inlines mated together, forming a "V". this is done for packaging reasons.
1996 single cab 2500, nv4500, 4x4, #100 plate, BHAF, strait piped, third gens w/michelins 1998 ext. cab, long box, 4x4,12v, south bend FE, #100 plate, twins, 6" stacks, 325 toyo MT's, leveling spacers |
#27 (permalink) |
Like someone else said, inlines are for torque and V's are for HP. Now with a locomotive, they use a V style for horsepower to turn the main generator. Then it uses electrical energy to turn the traction motors in the trucks underneth it. So the electrical energy is what make the locomotive move and give it it tractive effort. But some older Baldwin, Fairbanks Morse, and I think Alco locomotives did use inlines in them for a powerplant.
Matt"Locomotive Superhero" 2002 Dodge Ram 2500 4x4 Reg. Cab, Arrest Me Red SLT Laramie 24v Cummins AT w/ 4.10 LSD. Quad XZT+, Gauges, Amsoil BHAF, Loud 4" Pipe, Tonneau Cover, Tinted windows. Thanks to South County Diesel Performance. |
#28 (permalink) | |
Also why are they going from the cast iron head to the aluminum head?
2004.5-{Atlantic Blue},6" superlift w/37's, all the free mod's, K&N drop in, Superchips Flashpaq, Phantom 2 gauges...more to come,
#30 (permalink) | |
Yep
![]() Join Date: Jun 2006
2006 2wd DRW Auto Lone Star White Quad Cab, Smarty Jr. , GDP Intake, GDP Grid Heater Delete Silencer Delete, MBRP 5" Catback, Isspro Boost,Pyro,TransTemp Pillar Gauges, Turbo Ring GONE, Kilby's Condenser Guard, AMSOil Drop In, Airbox modded, MBRP 6" Tip, Ipod, XM, 5 MPG Cupholder, BedRug, Ranchhand Brush Guard
#31 (permalink) | |
04.5 6 spd dually,Smarty,MP8,Isspro performax,II twins,arp,FASS,bd ic,ats arc, winnspeed heater delete,SB DD 3850#,flux2,Hamilton's,maghitec,Spirson 6", toyo,defiant sbs, Sulastic's, dynatrac hub's, cognitto traction bars, Carli LT bags, amp steps, oasis Last edited by liftman : 01-16-2008 at 12:46 AM. Reason: wording |
#32 (permalink) |
Yep
Man this is almost as exciting as a classic AMSoil vs. K&N post ![]() Next
#33 (permalink) | |
2007 Ram 3500 QC LWB SRW 4x4 5.9 CTD 6spd 2000 Ford F350 CC LWB SRW 4x4 7.3 PSD Auto |
#34 (permalink) |
Inline delivers more torque because it can provide a longer stroke of the piston over V-block. Better fuel consuption because of 2 less firing cylinders than the V-blocks. They will also wear more evenly because their vertical. V Blocks do fit into a smaller space, weigh less, and because of shorter stroke rev-up faster. Also a shorter crank shaft and cam shaft is stronger. They do contain more moving parts to make them function so whyever one would want to use it is beond me. ?? May have to do with a patented design and the only way other companies can compete was to have a different design.
'95 12V, super cab 4x4, BHAF, 400,000 +mi. pac brake, KDP retainer done, #10 fuel plate, boost elbow, DDS stabalizer, 215 Bosch injectors. Now I have a Truck. |
#35 (permalink) |
well most every diesel engine i see other then power stroke and duramax are in lines. i dont think i have ever seen a big rig with a v motor. i know there out there but i would think cat and detroit are more popular with the inlines. i beleive that inlines make more torque because of the strait up and downward force of the piston. if you where to take a twenty pound weight hold it over your shoulder and do push it up and down its a little harder to push up but comes down hard as well. well take a 15 pound hold it at a 45 degree angle from your chin and move it away from you and towards you. its a little easier to push away and doesnt wanna come back as hard. you change your weights because in a 6 cyclinder i would think that the piston and connecting rod as well as the counter weights are heavier then on a v8. ..... torque is a twisting force so the harder that piston comes down the harder the crank is going to turn.
06 qc 4x4 g56 edge juice hot unlock smarty sbc dd 3600 strapped centerplate no more chatter! htt 62.65.12 2nd gen manifold leveled 35's 6"single 487hp 990tq |
#36 (permalink) |
in the old days detroit built v 8 2 stroke diesels cummins had them also they just dont make the torque a strait six does now if ford could get international to put the dt 466 in a f 350 or 450 id have to buy a ford thats a better motor than the 5.9 or 6.7
