manual transmission q's - Dodge Cummins Diesel Forum
Old 01-15-2008, 02:28 PM   #1 (permalink)
I know that alot of guys put temp. gauges on the auto trans. Is it possible to put one on the manual trans
countryboy166 is offline   Reply With Quote
Old 01-15-2008, 03:07 PM   #2 (permalink)
CTD6SPD's Avatar
Yes you can. My EDGE Jw/Att. says to install the sending unit in the PTO cover. Here is a link to their installation instructions for a step by step. http://www.edgeproducts.com/product_...manual-143.pdf
2002 2WD Silver 3500 DRW, NV5600 & 3:55s, Silencer Ring Removed, BHAF, MBRP S.S. 4" turbo back to 6" mitre cut stacks, Edge Juice w/ Attitude, AirDog100, and a Draw Straw II
CTD6SPD is offline   Reply With Quote
Old 01-15-2008, 04:39 PM   #3 (permalink)
thanks, that should help
Old 03-30-2008, 03:49 PM   #4 (permalink)
luckyhat12's Avatar
anyone done this on a G56 yet? I just got the commander and will use the tranny temp sensor if I can figure out where to put it.
--Chris-- 07 Silver QC LB 3500 5.9 4X4 G56 w/ SBC DD, BD Ex. Brake - no longer a Full Time RV'er-
luckyhat12 is offline   Reply With Quote
Old 03-30-2008, 05:31 PM   #5 (permalink)
I don't really see a point to one on a manual tanny...
Black '06 2500 G56 "Big Horn"
FBD 5" exhaust - Volant Intake - DiPricol Boost/EGT/Fuel - Bully Dog Crazy Larry
MP-8
zbollman is offline   Reply With Quote
Old 03-30-2008, 07:44 PM   #6 (permalink)
Banned
DORKWEED's Avatar
Location: "The Peoples Republic of Illinois".....behind enemy lines
DORKWEED is offline   Reply With Quote
Old 03-30-2008, 08:02 PM   #7 (permalink)
Buck Ofama
Magic smoke's Avatar
I don't know what the safe temp is but I try to keep mine under 220 and it doesn't take long on a hot day pulling 10k. I have my temp probe through the fill plug and 1/2 quart overfull.
07 5.9 All Stock
Magic smoke is offline   Reply With Quote
Old 03-30-2008, 08:06 PM   #8 (permalink)
theres no reason you need a temp guage on a manual
99 Ex,cab longbed 4x4 5 sp manual 6 inch lift, banks big head turbo wastegate, banks turbo, banks exaust brake dana 60 front, dana 80 rear 3.73 gears, airbag helpers, edge chip, powdercoated traction bars, mag hytech diff covers
norcalcummins is offline   Reply With Quote
Old 03-30-2008, 08:09 PM   #9 (permalink)
Buck Ofama
I agree at stock power.
07 5.9 All Stock
Old 03-30-2008, 10:21 PM   #10 (permalink)
It is for sure a lot of work to go through... I installed the temp sensor in my 2000 6 speed, you have to drain all oil as the sensor has to be "tapped" into the cover, then tough to get the oil back in....plus it is hard to find the correct oil for the 6 speed... plus being expensive
road_warri0r is offline   Reply With Quote
Old 03-31-2008, 12:39 AM   #11 (permalink)
luckyhat12's Avatar
Hypothetically I am at the oil change interval of my G56 and I have to change the fluid anyway, where would it be put? So hypothetically I am not at the stock HP levels, Where would it be put? So I have a gauge that comes with the thermocouple already and it won't cost much more to have it installed, where would it be put?
I understand that it isn't needed. I also absolutely know that if I was buying individual gauges that I would not buy a trans temp gauge for a manual at all. But, if it is in cluded in the package and the thermocouple is there, why not put it in? Otherwise you have a parameter that is fully capable but isn't being used. What is the point in that?
Thanks for the PTO cover suggestion.
Old 03-31-2008, 12:46 AM   #12 (permalink)
texs4x4's Avatar
Whether it's need or not, the more you know about your truck and what she's doing, the better off you are. I like the idea, never thought about it before. I haul kinda heavy and not near stock power anymore. I changed my 6 speed oil with synthetic and don't know what going on in there
2007 Mega Cab 4x4 dually 5.9., 35" mud tires, Snow stage 3 injection, Diablo/Diablo puck stack. On my 4th auto trans!
texs4x4 is offline   Reply With Quote
