Turbo Flutter?? - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 01-09-2008, 07:46 PM Thread Starter
sledneck696's Avatar
Turbo Flutter??
Iv heard a few trucks when they rev up high or are giviner good and let off the gas there is like a turbo flutter or some noise....anyone know what this is and how i get it? It sounds awesome!
2001 q-cab 4x4 sport 6 speed swap, 3600SB clutch, SB hydraulics, B1/B2 twins, Mach 7's, Edge juice w hot, fire rings, ARP's, Rips Boot Kit, airdog, BD short shift, Hurst shifter, Dipricol Optix boost gauges, subs, dvd, Fabtech 5.5" dual shock lift, dual shock steering stabilizer, 5" curved top stacks
SOLD
sledneck696 is offline
post #2 of 18 (permalink) Old 01-09-2008, 07:50 PM
I think what you're talking about is turbo bark. this happens when you are revving, causing the turbo to spool up, then suddenly release the throttle. I don't know why you would want it as it can cause turbo failure (broken shaft I think)
2001.5 2500 24V QC LB 4X4
2001.5CTD2500 is offline
post #3 of 18 (permalink) Old 01-09-2008, 07:50 PM
RSWORDS's Avatar
That is Turbo bark and is VERY BAD for your turbo. Will whip out th ebearings quick.
RSWORDS is offline
post #4 of 18 (permalink) Old 01-09-2008, 07:54 PM Thread Starter
well that cant be good then, I was at an automotive shop the other day and they installed a banks six gun system like intercooler and all and i heard that noise as they were playing with it after and it sounded good but i guess not......
SOLD
post #5 of 18 (permalink) Old 01-09-2008, 07:54 PM
kalkhokm's Avatar
i cringe every time i head that noise...definately not good for the turbo
'06 Megacab 4x4
kalkhokm is offline
post #6 of 18 (permalink) Old 01-09-2008, 08:01 PM
smok'n12v's Avatar
Not good for the turbo at all. This is why they make blow off valves.
1998 12v. Quad cab,4x4, 5 speed,# 10 plate, 5" FBD Exh., bhaf, fluidampr, Autometer cobalt boost and egt gauges. PPE DD clutch, Bosch 4k GSK, Peak Diesel 60# valve springs.
*92 AWD turbo Talon Stock
smok'n12v is offline
post #7 of 18 (permalink) Old 01-09-2008, 08:05 PM
kalkhokm's Avatar
yea BOV's are expensive though...just dont lett of the throttle so fast, if u can help it
'06 Megacab 4x4
kalkhokm is offline
post #8 of 18 (permalink) Old 01-09-2008, 09:28 PM Thread Starter
Can you get the bov's for our trucks??
SOLD
post #9 of 18 (permalink) Old 01-09-2008, 10:08 PM
kalkhokm's Avatar
BD's turbo guard
'06 Megacab 4x4
kalkhokm is offline
post #10 of 18 (permalink) Old 01-12-2008, 02:02 AM
JSPulliam21's Avatar
Are we talking about the short choppy "chooo chooo chooo" sound when you let out of the throttle at high rpms, or the "whoooosh" sound like when shifting gears? Like the sound at the end of THIS video?
98.5 3500 QC LB NV4500 4x4 3.55 SRW, DiPricol gauges, BHAF, 4" Silverline, FBD 150's, Edge Comp, Valair 3800 DD, Draw Straw, 1/2" Filter to IP Line, FASS 95HPFP, 2" Leveling Kit, DSS, 35" Toyo M/T, KDP killed 403HP/899 TQ
JSPulliam21 is offline
post #11 of 18 (permalink) Old 01-12-2008, 02:53 AM
Isn't the "flutter" referred to as turbo surge? When the throttle is suddenly chopped at high boost pressures there is nothing forcing the the turbine to spin therefore causing the remaining air on the compressor side still has to be forced out of the turbo. But with the high pressure air fighting the now effortless compressor it cause it to flutter. Sound right?
yzgaret is offline
post #12 of 18 (permalink) Old 01-12-2008, 10:07 AM
Cummin of age's Avatar
Maybe its not even "bark" he is referring too. After you let off the pedel on High boost, or elevated boost pressures, the still exsisting boost pressure is no longer needed in the turbo to be forced into the intake so the boost pressure is dumped thru the Waste gate. That is more than likley what you may be hearing. I hear it in mine everyday and it is the wastegate dumping boost out before it gets spooled into the intake.
During acceleration and haring the whistle fo love from the turbo and then letting off the pedel, you will hear a long accentuated "WHHHOOOOOOSH".
This is waste gate dump, not bark. Am I correct here. Someone chime in.
Just my .02
07, Big Horn 2500, 5.9, autometer Pyro and Boost,Predator stacked w/Power Puck,westin deer catcher,XTang tilt up, Nitto Dura Grappler 285/75R17E, Muffler MIA,Gutted Torqe tube,AFE BladeRunner,IceBox, Amsoil NANO4510,Galaxy DX99V CBRadio,Linear,Wilson 5000
Cummin of age is offline
