Guages - Dodge Cummins Diesel Forum
Old 12-08-2007, 02:12 PM   #1 (permalink)
Guages
Ok, I am very new to this. I understand why you need egt and Trans temp, but why fuel pressure? Thanks in advance
DieselFanatic is offline   Reply With Quote
Old 12-08-2007, 02:14 PM   #2 (permalink)
mega_cummins's Avatar
you can burn up your fuel pump real quick if your not watching it.
mega_cummins is offline   Reply With Quote
Old 12-08-2007, 02:16 PM   #3 (permalink)
So, what is acceptable fuel pressure? And Why would it get too high/low?
Old 12-08-2007, 02:18 PM   #4 (permalink)
Banned
Dodge puts junk lift pumps on the trucks. For the newer gens, it is not a problem if you are not modded but when you do mod the truck, it adds more fuel...because in a diesel you can keep throwing fuel at it (and to a certain poit) will keep making power. Well, if it adds more fuel, it's goign to need more fuel. When enough fuel is added, the stock pump won't keep up...
awenthol is offline   Reply With Quote
Old 12-08-2007, 02:20 PM   #5 (permalink)
Banned
Acceptable pressure for the 24v is 15ish psi, never lower than 5. For the 12v, you can run considerably more, but am not sure how much...
To add, the problem with low fuel pressure is, not only will it hurt performance (starving the engine) but the injection pumps are lubricated with diesel...and when there isn't enough pressure they are starved and thus running without lubrication...which causes destruction!
Old 12-08-2007, 02:28 PM   #6 (permalink)
ok, so it could burn up the stock pump when you mod up a 12 v. why do you need a guage though. dont you just upgrade the f pump when it needs it?
Old 12-08-2007, 02:33 PM   #7 (permalink)
Banned
How are you going to know if the fuel pump needs to be upgraded if you don't have a gauge...If you have a 12v though, I don't think a fuel pressure gauge is important...unless you're going for big HP...
For the VP-44 trucks (98.5-02), if the lift pump dies, the injection pump dies and an injection pump will cost $1200 (pump alone) plus the person will still have to upgrade the lift pump. If you have a fuel pressure gauge, you'd know if the lift pump is bad and could replace it before it takes the VP out.
Old 12-08-2007, 02:47 PM   #8 (permalink)
ok, But in a 12v FP guage not important? I want to push like 600 hpp when im done. Also isnt a 24v. easier toget hp out of because you cant chip a 12v can you?
Old 12-08-2007, 03:15 PM   #9 (permalink)
Banned
12v are easier to get hp out of because, all you have to do is turn stuff up. If you plan on 600hp, you'd be best off just getting a fuel pressure gauge.
Old 12-08-2007, 03:20 PM   #10 (permalink)
ok, thank you guys.
