I am starting to look for a 12 valve truck and am debating about a 1st gen or 2nd gen. the truck would be used for towing fairly frequently and also spend a lot of time on rough roads as well as long trips on the highway.
I like the body style of the older trucks but will pick a more solid mechanical truck over looks any day. I despise computers in my vehicles and was wondering if the 2nd generation had any type of computer (i know the engine is not computer controlled). I am not looking to get huge horse power out of the truck so the VE pump is not a problem, but i will likely try to get a little more power out of the truck without having major effects on fuel economy. I have heard bad things about the manual transmissions used in both trucks and was wondering what the general opinion is on which transmission is better. and other pros and cons and opinions on each of the trucks would be appreciated.
I agree the later 2nd gen has more power and creature comforts. Maybe less miles too...
2001 Dodge Ram 2500 QCSB 4X4. Built in a farm shop My play truck
1993 Dodge Ram W250 flatbed 4x4 5 speed. My work truck. Powered by Snap On Tools.
'MERICA
what changed after 96 to give more power any different parts of just different tuning? can the same power be gained on older models without any more effort
how much computer stuff does a second gen have compared to a first gen is the comp just for the gauges and the grid heater or does it control more than that.
the 2nd gen injector pump is mostly mechanic there pretty much the same for the 1 and 2nd gen after 98 they had the vp pump which used electronics is not very reliable u can make it reliable but not like a 12 valve
"Oh yeah, I knew that guy too. He also had 11"s of manhood and could do everything I could do, but better."
all of the 12v engines are 'mechanical'. meaning no ECM required for operation.
The early VE pumped engines will require a +12v source to activate the shutoff solenoid. the p-pumped engines do not need anything at all if you use a cable/mechanical shutoff instead of the solenoid.
The PCM in the 94-98 trucks only controls some basic functions. grid heaters, charging (voltage regulator), gauges, and transmission functions for the auto trans
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
