Block heater plugged in all night?? - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 12-18-2010, 02:01 AM Thread Starter
First Timer
big94GMC's Avatar
I hear alot of guys saying how they've put timers at the outlets that their block heaters are plugged into. I could make that work for me, but it wouldn't be as 'carefree' as most. So, my question (my concern) is, is it harmful to leave the truck plugged in for long, extended periods of time? In short, is it bad to leave the truck plugged in for 10?, 12?, 24 hours???
......Chris
--'94 GMC Sierra 2wd, 5.7, NV3500, 3.73, 6" RCD, 33" ProComp, stereo
--'95 GMC Sonoma 4x4, 4.3, 4L60e, 203/205 trip stick, D60's, 4.10 welded, 38" SX's on H1's
--'04 Dodge Cummins DRW, 4x4, 6spd, 22.5 Alcoas, some goodies (SOLD)
big94GMC is offline
post #2 of 11 (permalink) Old 12-18-2010, 02:02 AM
railer and bailer
elephantrider's Avatar
iTrader Score: 10 reviews
i keep mine plugged in all night . never
had any issue at all ..
jason
closet poster
Originally Posted by tco2612 View Post
I would not sell it to you a$$ hole
elephantrider is offline
post #3 of 11 (permalink) Old 12-18-2010, 02:06 AM
Out There, Savin' Lives
stodg73's Avatar
I have kept mine plugged in for 3 or 4 days at a time. No problems yet.
O.O., 01.5, 2500, H.O.(245/505), 6 Speed/NV5600, 3.55's, 4x4, QCLB, Sport, 105k, currently stock engine, K&N Air Filter, 285/75R16s, Glow Shift Gauges: FP, Boost, EGT, Oil Temp, SMARTY@1, lift pump 19@idle, 14@WOT, Propane, IAT Fooler = More MPG,
Toys:
'79 CJ5, 258ci, 3" lift, 33x12.50x15, Stock Engine and 3 Speed Tranny, '05 GSX1300R Hayabusa
stodg73 is offline
post #4 of 11 (permalink) Old 12-18-2010, 02:51 AM
ykdave's Avatar
unless its +40c outside (risk of boiling the antifreeze), the only thing your going to hurt is your power bill
the factory block heater is appx 750watts, so its not too bad, but leaving it plugged in all the time adds up
If your set up like myself, 750w block heater/250w oil heater/250w trans heater/2x 80w battery warmers. its pretty hard on the power bill, i have it on a timer at home, but leave it plugged in at work or wherever im not paying for power LOL
My espar is on the way though... no more plugging in...
ykdave is offline
post #5 of 11 (permalink) Old 12-18-2010, 11:09 PM
I was a paid professional Fire fighter for 27 years and our engines and trucks were plugged in anytime they were parked in the engine house. Never a problem in all those years.
I do the same with my rig. It's plugged in whenever I know I will be using it and has been plugged since last night. Been doing that as long as I have owned it.
RR
'01 QC 2500 long bed, 3:54 auto w/Dunrite VB & LU switch, untapped Comp, Scan gauge II, Raptor lift pump, fuel pressure gauge and trans temp gauge.
Russ Roth is offline
post #6 of 11 (permalink) Old 12-18-2010, 11:16 PM
Bluedually4x4's Avatar
Leave mine plugged in all night. And it has sat that way for two three days in a row.
1998 3500 4x4 5 speed reg cab dually 12valve
TST #10, ATS exhaust man, 5" turbo back exhaust twin 5" stacks, SB 13.5 clutch, BHAF, DDP 75 hp injectors, 3000gsk, timing set at 16
Bluedually4x4 is offline
post #7 of 11 (permalink) Old 12-18-2010, 11:20 PM
CF Administration
KMKDIESEL's Avatar
iTrader Score: 9 reviews
the only reason people use timers is to cut down on the power bill, it only needs a couple hours to heat up, so they set there timers just to give it enough time to warm up. I leave mine plugged in for 2 weeks straight while I am at work, because its free, at home I never plug my truck in because its not needed. I start my truck up and drive it almost everyday, and most the time I dont even wait for the grid heater to cycle unless it is in the -*.
-Nic - Idaho Oil Burners President
2009/ 3500/ Laramie/ Mega Cab/ Electric Blue/ Blackmaxx MCC tuned/ATS Stage 6 48re/ TS Mp8/ 5" Dual Exhaust/ 66-74-14/ Pdi manifold/ 50% over nozzles/ H&S Intake Horn And Boost Tube/ Afe stage 2 CAI/ Stage 1 Cp3/ GDP Maximizer Kit/ Shaved,Flycut,Coated Pistons/ A1-H11 Headstuds/ GDP CCV Kit/ 8" Lift/ 37" Toyos. 648 hp 1351 tq uncorrected
1996 12v 2.8 puller "dominate this"
R.I.P. Tucker
KMKDIESEL is offline
post #8 of 11 (permalink) Old 12-18-2010, 11:22 PM
You could try installing a circulating tank heater (
). On nights where it drops to -20F, I'll run mine on a timer for a couple of hours. Truck starts no problem and usually starts blowing warm air within 5 minutes. They run a 1500 watt element vs the stock 750 watt element, but because the fluid actually circulates, your able to acheive the same results with this unit in a couple of hours vs pluggin your vehicle in all night with a stock unit. Makes sense to me!
2006 5.9L, G56 6 spd, 2500 4x4, 35x12.50R17 Toyo MT's, Kore leveling kit, Bilstein 5100's, BD Steering Box brace,Mopar HD steering box,Mopar 09 Steering Upgrade,Firestone Airbags,Solid Steel adjustable track bar,AFE Stg2 Pro5,5" MagnaFlow Exhaust w/5" FTE Exaust Resonator (cat removed),SC EFI Live w/ Anarchy Tuning, Amsoil DRB kit, AirDog II 165 kit w/ 1/2" Big Line,TGC Dual Steering Stab,TGC Adj control arms,Carli Ball joints,Southbend SDD 3600GK Clutch, Isspro pyro,boost,fuel rail & fuel press, Spyntec Free Spin Hubs, Taterbuilt 62/65/12 turbo.
Higa2000 is offline
post #9 of 11 (permalink) Old 12-19-2010, 07:30 AM
Dodgezilla's Avatar
iTrader Score: 18 reviews
I've found that 6 hours does me as good as leaving it plugged in all night so I got a timer. For years I just plugged it in all night though. What's great about keeping it plugged in all night is that if you put your heater on the defrost mode before you shut down your windows will rarely frost up. I've had cars parked right beside my truck before and in the morning mine was totally clear while the car beside me was completely frosted over... Nice.........
04 Ram 2500,Green/Silver-305/555HO,48RE,3:73s, QC,LB,4x4,Roadwire Leather,Laramie Interior,Infinity, HE351 Turbo,Custom 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan,Fogzilla,TRM,4th Gen 18" Laramie Rims w/ stock 275-70 tires,106,000 miles
Dodgezilla is offline
post #10 of 11 (permalink) Old 12-19-2010, 11:10 AM
Ed ke6bnl's Avatar
When I was driving mine as a daily driver I had it plugged in near the garage with a timer set for on at 4pm and off when I left for work at 10pm BUT I put a 110volt thermostat in series so that nothing would go on till the temp dropped below 38 degrees. saved a lot on the electrical. ED
1998 CTD 24v,DTT trans billet in and out,Edge EZ, exhaust brake, 4" turbo back exhaust, 275 injectors, Mag-tech trans and diff pan/cover, piller gages, digital fuel psi, 4door, shortbed, larger turbo.Air Dog fuel pump/filter/air water separator
Ed ke6bnl is offline
post #11 of 11 (permalink) Old 12-21-2010, 10:46 PM
5.9fan's Avatar
thats a dam good idea!
2014 CCLB 4x4 Tradesman. 5th wheel prep, upfitter switches, LSD, plow prep, on board air, amp bedstep
Its quiet... too quiet...
5.9fan is offline
