Dan - Ontario Cummins Crew President Ontario Chapter Facebook - Dan GONE but never forgotten - 2001.5 24V QC SLT Laramie 2wd 47RE/3.55, LB, ICEBOX w/4510, FBD 4" turbo back w 5x18 SS tip, silencer ring MIA, FASS 150, IIS HRVP, DiPricol 30 psi FP guage, 1 qt 2 stroke EVERY tank!! 16.5481 @83.29mph on 7/7/07 My new ride - 09 Ram, For NOW .... it's got one of them damn HEMI'S in it.
The force from the air in the tennis ball will pop the lock open. You have to hit the lock (key slot) really hard. If you get it right it works everytime!
2001 extra cab 2500 SLT laramie (dark blue over silver) 4x4 S.O. 55 block, 47re, silencer ring/resonator/muffler are MIA, gauges, big bumper up front, B&W turnover ball, 315 buck shots, and Quadzilla XZT+ (thanks DieselNut)
'89 GMC Sierra SLX 1500 4x4 186K 350TBI w/custom 400 tranny
'06 Freightliner Business Class M2 106 tandem w/lockers,30k# winch, and Altec digger/derrick
cmon now really, this really sounds like it *should* work or your gonna ding the door up trying. I'd have never thought of that in a million years :thumbsup
You really don't have to hit it very hard. Just put the hole over the key slot and push really quick.
yep it works. i keep a tennis ball ready to go in my tool box. But it has to be the kind of locks with the verticle lock thing that stick up and always hit your elbow (not sure of the technical term)
2008 Ford FX4 F350 6.4 Powerstroke.....I dont really belong here anymore
Please explain how that works. What does the compressed air do? The lock mechanism works this way: when you insert the key, the cuts in the key align the tumblers within, which allows the cylinder to turn freely. The cylinder is attached to an arm connected to the lock at the latch. Turning the cylinder moves the arm, which in turn locks/unlocks the door. Blowing compressed air into the cylinder doesn't do any of that.
2006 Ram SLT Sport 2500 4X4, QC, SB, CTD w/ 6sp, K&N Air Filter, Quadzilla Xzillaraider, Intake Baffle and Silencer Ring MIA, RokkTech Crank Sensor, Muffler MIA.
Get a coat hanger and make a big check mark with it. It needs to be kind of a big check mark since the door glass goes 4 to 5 inches below the sill. Get some sort of wedge thin enough to go between the glass and the weather strip at the base of the window. Once the wedge is in there, put the coat hanger in the door sideways and then twist it towards the pop up lock. Lift up gently and you will pop up your lock. Dodges are very easy to get into. I can get into one in under 5 seconds. Mods,,,please delete this if it's too much info.
Fletch
P.S.=Be careful putting the wedge in. You could break the glass. You want just enough gap to put the hanger in. Use at own risk.
