Gas cans to diesel cans - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 03-20-2017, 06:32 PM Thread Starter
saltlife3122's Avatar
Got 3 new scepter jerry cans that are plastic. They were used for gasoline previously. Is there anything I need to do to clean them out or can you just put diesel in them and go? Not sure if this is the right area to post this. Thanks for any input.
2006 Dodge Ram 2500 4x4 Mega Cab, 5.9l 24v cummins, Synergy HD Steering, Synergy steering brace, Mopar big box 09+ steering gear upgrade
saltlife3122 is offline
post #2 of 7 (permalink) Old 03-20-2017, 07:07 PM
Master_Chase's Avatar
I would just check to make sure there's no junk in them and there 100% empty.
Noob learning
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #3 of 7 (permalink) Old 03-20-2017, 07:23 PM Thread Starter
They still have a little gas in them, they do need to be cleaned. They have some dirt and grime, these were military use. Not sure How to clean them, can you just use soap and water? Make sure they are really dry before diesel? Or do you need to use something to clean them? I was told acetone or whatever would be to harsh on the plastic.
post #4 of 7 (permalink) Old 03-20-2017, 08:45 PM
^^^^ I needed a can for diesel and the only cans on hand previously were used for gas. Made sure they were empty and never looked back.
04 QCSB 4x4 auto 2500 / MBRP4"duals/HP Tuner -by Firepunk/Fass 150/ II 62/474, ARP 425's /Edge Insight CTS/ 3.5"T.G.C.lift w/steering upgrade/Red Head/ TOYO AT II's Extremes 35's/XD Revolvers 18x9/ PRXB PAC exhaust brake.
'12 TDI Jetta 6spd.
brooklyn 12 is online now
post #5 of 7 (permalink) Old 03-20-2017, 08:52 PM Thread Starter
They are empty, they have some residual gas in them. You can also see some dirt in one of the cans, and some black flakes of something in the other two. So I can just make sure they are good and empty and fill them with diesel? I don't need to clean them or put a degreaser in them? Sounds good to me. I guess I can put some diesel in them and try and get that crud out then fill them with fresh diesel.
post #6 of 7 (permalink) Old 03-20-2017, 09:42 PM
#40Fan's Avatar
That's what I would do. Put a little diesel in them, slush around, dump and fill with new fuel.
2011 2500 CC ST G56 LB MM 5" Flo-Pro 463
#40Fan is offline
post #7 of 7 (permalink) Old 03-21-2017, 03:11 PM
Grogg's Avatar
I've used Simple Green to clean out dirty fuel containers before. But if it's a fairly new container that had gas in it, and I need to fill it with diesel... I just fill it with diesel and keep on going
2006 Dodge RAM 3500 DRW G56 4WD SLT/"Lone Star"
Grogg is offline
