when to plug in, and how long? - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 12-05-2009, 11:34 PM Thread Starter
heyzipupyourfly's Avatar
I did a search and came up with nothing.
I was wondering when I should plug my truck in? (block heater 110v plug in front btw)
do i leave it plugged in overnight or buy a timer? will it hurt to leave it overnight?
will it hurt anything if it is plugged in and i start it with remote start?
and has enyone heard of anything going bad or shorting because the plug is exposed to the elements?
Thanks guys sorry for the list of questions
Oh and through my searches i saw someone mentioned something about a cab heater that ran off of diesel? then it was not mentioned again. does anyone know about that?
2005 SRW quad cab longbed, Auto.Polished one peice driveshaft mopar#52123220AB.Thuren coils and mini leaf pack,home made control arms,37" pro comps, Camo Seat covers, Miller high life sticker.
heyzipupyourfly is offline
post #2 of 17 (permalink) Old 12-06-2009, 03:39 AM
DedDuk's Avatar
i plug mine in at night when it starts getting below 30, does not seem to need it, always starts up, but i figure its better for the motor to be semi warm rather than cold. thats what it is there for.
i do this on the road while working when im in cold places. at home (Texas) i have never plugged it in.
Silver 2006 SLT 4 Door 4X4, 3500 Long Bed, LONE STAR EDITION. Custom 20" Wheels, Front and Rear Bumpers. Black Tool Box on Black Diamond Plate Rail Covers.5.9 Stock Cummins.
DedDuk is offline
post #3 of 17 (permalink) Old 12-06-2009, 03:49 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
If I had to leave for work in the morning and it was below 50 I would plug it in all night so the heater would be warm and the engine was at 110. I have since heard it costs alot to leave it plugged in all night but I lived at home and my folks never said anything so im not sure.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #4 of 17 (permalink) Old 12-06-2009, 04:52 AM
Some-Sho Some-Go
H.R.D's Avatar
Do it all the time when temps are below freezing. I leave it all nite with no problems thats what a block heater is designed for. Plus easier on the old batteries when that grid heater has to warm up for 5 seconds instead of 30+ seconds.
-Jerrod-
2002 3/4 ton X-cab Short Box 4x4 5 speed, Volant CAI, Blue Chip VP44, Edge J/A*HOT*, PDR HX40, AD 100, CFM+, BD short shift, Noise Makers, Flo-Pro SS Duals...
H.R.D is offline
post #5 of 17 (permalink) Old 12-06-2009, 08:33 AM
I leave it plugged in all night if it's stays outside (like when I'm at the fire house) or on a timer when it's at home in the garage.
99 2500 QCSB
IAFF Local 706
firemanram is offline
post #6 of 17 (permalink) Old 12-06-2009, 08:41 AM
plugging a diesel in below 50 is crazy. its 27 28 here in the morning and i dont run the grid heater yet. truck starts the same as it was 80 out side, once it starts to get around 25 and below i run the grid but i wont plug it in till single digitz. the cummins is a cold weather eng, they start so nice and easy in cold weather.
04 charcol grey, 2" leveled, 35" coopers, minus the muffler and silencer ring
1swany65 is offline
post #7 of 17 (permalink) Old 12-06-2009, 09:24 AM Thread Starter
ok I have a 6 mile ride to work every night, and i normally dont hit 180-190 degrees till about a 3rd the way there.
would it benefit me to plug it in to help the warm up, even if its only 40 out?
What about winter fronts?(grille covers) should I invest in some or is it not needed in my area? (new england) it doesn't get in the negative temps much and if it does it's not sustained for a long time. but it will get into the single digits and stay around 15-20 at times.
post #8 of 17 (permalink) Old 12-06-2009, 09:31 AM
ok do you want heat in the cab so its warm to get to work or are you worried about the truck not getting to operating temp for a long period of time. short trips are hard on a diesel. not a good thing. but plugging it in to get it warmer your still not gonna keep the moisture out of the eng in that short of a trip. plugging it in will get warm in the cab faster yes but better on the eng not really being its that short of a ride. a winter front is the same way, gonna warm up faster in the cab but not really get warm for long enough to evaporate the condensation out of the eng. the truck needs to really get warm and run warm for a period of time, the warm cold warm cold causes condensation, moisture inside the eng and the operating temp will evaporate that moisture out. those short runs are just too hard on a cummins.
1swany65 is offline
post #9 of 17 (permalink) Old 12-06-2009, 09:56 AM
Heck if I know
bulldogbones's Avatar
I start plugging mine in when it gets around 20, its on a timer at my house and when im on the road I just snake a ext cord out my motel window and let her go.
But like ^^^^1swany65 was saying short trips for our trucks arent the best. I would suggest starting it and letting it idle for 10min with the high idle.
But the comment about the moisture in the engine is very true. When I start my truck in the cold I throw the EB for some back pressure, and the exhaust will throw steam for a good 5-8 min before it goes to just hot air
2010 6 wheeler, 4x4, 4th gen factory matched gauges (Boost, Trans, Egt) A1H11 Studs Parts waiting to get installed S467, Steed Speed, BD EB, and some sort of tune
bulldogbones is offline
The Following User Says Thank You to bulldogbones For This Useful Post:
05cummins96 (11-27-2015)
post #10 of 17 (permalink) Old 12-06-2009, 10:41 AM
Left out in the cold's Avatar
Plug at 20. How long? depends on how cold.
Left out in the cold is offline
post #11 of 17 (permalink) Old 12-06-2009, 10:44 AM
2 hours would get it warm enough to start and drive away, an hour would get it started easier but id still let it run and build some heat. the colder it gets it may take longer but 2 hours should be enough down to zero
1swany65 is offline
The Following User Says Thank You to 1swany65 For This Useful Post:
grovom (12-28-2009)
post #12 of 17 (permalink) Old 12-06-2009, 10:48 AM Thread Starter
heat in the cab i could really care less. my passengers are always scolding me because they are cold. I tell them to drive themselves and they shutup.
but yes i am more worried about the short distance i drive, beating up on the motor. Its a long 6 miles though. I end up going through 26 lights total between my house and my work in just that 6 miles. so its a stop and go stop and go. no highway.
I did get a remote start and i have been giving it about 5 minutes before i leave then i thought i could maybe let it run an extra 5 minutes or so when i park it at work? wouldn't hurt? i do have the high idkle turned on but it wont activate with the remote start i still have to go out and trn it up. so i've been letting it idle low because if i am stepping out to do that i might as well leave for work.
So to me it looks like an exhaust brake would be a decent investment. and the winter fronts in my eyes would only make a difference after the T stat is open, so its more for if the truck is having trouble reaching operating temps on a long trip in fridged cold?
