Old 11-07-2009, 10:30 AM   #1 (permalink)
Pull It Till It Breaks!
Smourj21's Avatar
Best HID Color
I am lookin to get HID lights since they are only $50, What is the best color, i want white, unless there is a good reason to go blue....On ebay they say 6000K is the brightest but everyone on here says 4300k Whats the brightest white guys?
Leveled 2002 Short Bed Quad Cab 6 Speed SHO | MBRP 4" Duals | Short Shift | Valair DD | Edge A2 | BD HRVP44 | Airdog 150 | CFM+ | BD Steering Stabilizer | Brite Box| 3pc Exhaust Manifold | DDP 250HP sticks | 35" Toyo MT's on 18" Driiv Offroad |Bilstein 5100's| Dana 60/80 | 3:55's | Detroit TrueTrac | Traction Bars| HX40/S475 TWINS|
|520hp/1132tq With the 200's|
Smourj21 is offline   Reply With Quote
Old 11-07-2009, 10:33 AM   #2 (permalink)
TexasHemi's Avatar
I have 6k's and love them.
Franco R. // Don't know how to post pictures? - Click Here!
'03 Ram 1500 - The Hemi that wishes it was a Cummins
TexasHemi is offline   Reply With Quote
Old 11-07-2009, 11:42 AM   #3 (permalink)
Left out in the cold's Avatar
Depends on weather you want to look good or be able to see. 4000K.
91.5 I/C W250 5sp 3.07s turned up pump 16cm2 M&H M2 BHAF Bosch +40s
92 W250 Xcab auto 3.54 bonehead stock
Left out in the cold is offline   Reply With Quote
Old 11-07-2009, 11:42 AM   #4 (permalink)
the 4.3k is the brightest but the 6k is not far behind and the ebay 6k are actually closer to 5k and to me is a clearer light. the 4.3k has more yellow in it. one word of caution, the way you are trying to do it is not legal and blinds the other drivers and they are starting to fine heavy for it. another way to help with budget shortfall. you really need to go to a projector lens. go to hidplanet.com for ideas
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline   Reply With Quote
Old 11-07-2009, 11:42 AM   #5 (permalink)
CTD_Dually's Avatar
yea 4300k and 5000k are bright and white. i have 8000k and its not bad 100x better than stock but im thinking about getting some 5000k bulbs jus to have to extra light output. i like being able to see everything at light
1996 Dodge RAM 3500 Extended Cab Dually 150K Stock Transmission - 2in Leveling Kit, 8K HIDs, Stock Fuel plate FF, Starwheel cranked, 16* timing, 3kGsk, Isspro Guages (Pyro,Boost and Tran Temp), S&B Cold Air Intake, CFM+ Intake Manifold, 5x36in Flapper stacks
CTD_Dually is offline   Reply With Quote
Old 11-07-2009, 10:43 PM   #6 (permalink)
CalebZ400's Avatar
I have 5000k and its pure white and its great, but in the snow the 8000k is better, it allows you see everything bc snow doesnt absorb the light, but at the same time 8000k is horrible as soon as roads get wet.
2006 3500 Megacab Laramie 4x4 G56 4.10s: Edge Juice w/ attitude-Hot, Quad X2 race, 5k 55w HIDs, F.U. switch, Rev wheels w/ 295/70/17 Nitto Terra Grapplers, Randy Ellis Designs light bar, Lightforce 240s Coming Soon: Southbend 3600DD
CalebZ400 is offline   Reply With Quote
Old 11-07-2009, 10:48 PM   #7 (permalink)
B.B.'s Avatar
4500k from DDM Tuning - HID Kits, HID Bulbs, DEPO Lighting, BMW and Porsche Performance Accessories
97 3500 DRW
03 3500 DRW
B.B. is offline   Reply With Quote
Old 11-07-2009, 11:04 PM   #8 (permalink)
12VRattler's Avatar
+1....good luck getting anyone to understand your point about the projectors though. I haven't spent any time on hidplanet lately although I think that 4300 to 5 is the whitest and also the brightest. Anything less is yellow and anything more such as 6k starts to have a blue tint to it, but 6k is still pretty darn bright. I like the 10 and 12k's violet tint but they just aren't very bright.
1996 2500 12v/nv4500 4x4 335k miles and still going strong!! KDP tabbed, Amsoil 4510 BHAF, evicted silencer ring, plugged wastegate, 5 inch FBE muffled, #100 plate, Isspro boost and pyro, Mickey Thomson ATZ's 285/75R16's, B&W steel flatbed
12VRattler is offline   Reply With Quote
Old 11-08-2009, 10:15 PM   #9 (permalink)
Smourj21's Avatar
yeah i was planning on going to projector lenses
Old 11-09-2009, 08:54 PM   #10 (permalink)
B.B.'s Avatar
A retrofit is the best idea, Even the projector lens you buy on ebay scatter it a good bit.
97 3500 DRW
03 3500 DRW
Old 11-09-2009, 08:55 PM   #11 (permalink)
Smourj21's Avatar
what u mean a retrofit?
Old 11-09-2009, 11:17 PM   #12 (permalink)
terminaltsi's Avatar
a retrofit is where you buy projectors out of a vehicle that came with factory HID's and custom fit those into your original housings. that gives the best light dispersion, cutoff, etc.
it's pretty expensive and time consuming though.
i'll be doing one to my Lexus this winter since it will be parked, but normally, i just put the ebay plug and play kits in and let it go. it's still 10 x better than any other kind of bulb. \
just make sure you reaim your headlights when you're done.
i've never had a problem with glare, with probably 10 different cars and sets of HID's. only one car did, a WRX.
if you go with projectors housings off ebay, get the H1 hid kit, not the 9004 like the stock housings would need.
the cutoff is pretty decent, but the dispersion could be better. again, it's still light years better than stock.
oh, 4300k is definitley brightest on the road in terms of output. i've had 5000k which si good nad even 6000k is pretty damn good. anything higher i haven't been too happy with.
'99 2500 5 speed, 4x4, gauges,Quadzilla ADR, Smarty, BHAF, 5" turboback, 315/75/16 maxxis bighorns, Airdog, 13" Valair,3000k HID's, HID off road spotlights, LED back up lights, LED interior lights,alpine/cerwin-vega/mmats audio.
terminaltsi is offline   Reply With Quote
