Sea Foam! - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 04-07-2007, 11:30 AM Thread Starter
Firebrand's Avatar
Talking Sea Foam!
My 03 has 50,000 miles on it now, and has been a little off lately. Power has been off, a little sluggish, and a noticable rattle that wasent there before. I read some comments here about Sea Foam, and figured I would give it a shot. Did a full service, added a pint to the oil, and filled the fuel filter resevoir with it, and dumped the rest in the tank. Wthin 5 minutes, the engine was completely quiet, and the power was 100% back to normal! This stuff is AMAZING! Thanks for puttin me on this stuff!
Firebrand is offline
post #2 of 13 (permalink) Old 04-07-2007, 07:58 PM
DBLR's Avatar
Have you not read where it is not advised to use any fuel additive that has alcohol in it unless you are using it to de-gel your fuel? Yes it may clean up your injectors and clean some carbon but it is not good for your fuel system and can even hurt it. To sum it up I’ll copy what DD had to say in another post about it “Fact is that alcohol kills lubricity, and that is the last fuel additive that should be used on a diesel.”
Also why did you add SeaFoam to your oil, were you trying to clean out some sludge in your engine by running it for 5 minutes before you dumped the old oil and installed new oil?
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's:
DBLR is offline
post #3 of 13 (permalink) Old 04-07-2007, 08:22 PM Thread Starter
Firebrand's Avatar
I was advised via PM to try it. It worked, and I see no reason to reveal the source. But as it was allready pointed out in another thread, It seems that in a simple oil change, I have damaged my engine with alcohol, and used a dangerous oil filter for my engine. Why on earth are these things still on the market for people like me to use? Is fram aware that these filters should not be used in a Cummins engine? Not to mention sea foam's false advertisement as being safe for all diesel engines, and will not void any warranty? Stuff like this drives me crazy.
post #4 of 13 (permalink) Old 04-07-2007, 08:27 PM
Duluth Diesel's Avatar
It does drive me nuts as well, Firebrand. Diesel fuel additives should not have alcohol, since it kills lubricity. It is consumer beware, unfortunately. Fram makes an OK filter for gas engines, but these Cummins diesels really pound on an oil filter with large oil pressure fluctuations. Fram's economical filter construction is not strong enough for this application. That is the wide opinion for years on Fram and diesels. But the guy at the parts store will never tell you that.
I run the AMSOIL diesel fuel additives and Donaldson Endurance oil filters. There are also many other additives and oil filters on the market that are better than Frams.
Duluth Diesel is offline
post #5 of 13 (permalink) Old 04-07-2007, 09:19 PM
goosesgarage's Avatar
Ive used i can of sea foam per every 3 tanks and it cleans all the carben buildup off the injectors been doing it 30,000+ miles no problems.
97 dodge 3500 drw nv4500 single cab western hauler with a few mods
[SIGPIC][/SIGPIC]
goosesgarage is offline
post #6 of 13 (permalink) Old 04-07-2007, 09:23 PM
Alcohol kills lubricity. Every major additive manufacturer, including the stuff that Cummins puts their endorsement on, know that alcohol is a bad deal for diesels. You are not doing your engine any favors using SeaFoam. There are better diesel fuel additives that do not use alcohol.
This is what I use: https://www.amsoil.com/storefront/adf.aspx?1206252
-Chuck
post #7 of 13 (permalink) Old 04-07-2007, 09:27 PM
To be fair, SeaFoam itself isn't a bad product. While it is widely known that alcohol has no place in a diesel fuel due to lubricity issues, I have used SeaFoam in gasoline engines, especially small engines, and have had good results. The only issue with SeaFoam in a diesel application is the fact that there is alcohol in it.
post #8 of 13 (permalink) Old 04-07-2007, 11:28 PM
JIM KAZ's Avatar
Smile
I'VE ALWAYS USE MARVEL MYSTRY OIL IN MY FUEL AND NEVER HAD A PROBLEM. A OLD MAN TOLD ME ONE TIME IF I USED IT I WOULD NOT HAVE ANY PROBLEMS, HE WAS WRIGHT, WHEN I SOLD MY 97 I HAD 323K ON IT AND IT HAD NEVER BEEN TOUCHED
JIM KAZ is offline
post #9 of 13 (permalink) Old 04-07-2007, 11:34 PM
jbarker's Avatar
i used marvel mystery oil in an old monte carlo i once owned. it had a sticking lifter and it cleared it right up:thumbsup
But i have never tried it in my fuel.
John
jbarker is offline
post #10 of 13 (permalink) Old 04-08-2007, 08:39 PM
THE Hood Stack Guy!
BossHawg600's Avatar
That stuff is a cure all for a lot of vehicles. But I know it was desogned for gas engines so I would nessasarly use it in mine. But a bit to cure a little problem wouldnt hurt. Oh ya and Advance Auto Parts has that stuff on sale this month!!!
2011 Mega Cab, Deleted and Fleece EFI live.... The "Mocca Cadillac"
BossHawg600 is offline
post #11 of 13 (permalink) Old 04-08-2007, 08:55 PM
mikemopar2003's Avatar
well one point on the alcohol bit is that it will absorb the water in the diesel my dad has put methenol in his bulk off road diesel tanks to absorb the water and have never seen any problems. Plus how much alcohol do you really think are in that little bottle of seafoam im sure not enough to hurt the engine or the pump.
Just traded the 01 with inj and edge comp for an 2008 Ram 2500 6.7 Gray with newly added Smarty 67me and Thew out the DPF
mikemopar2003 is offline
post #12 of 13 (permalink) Old 04-09-2007, 12:16 AM
I had a really noisey injector.. From the posts on here I figured it was just carbon buil up since I sit in traffic and idle alot..
Dealer was really no help in fixing it.
I tried the power service, lucas and none helped.. dumped in a can of sea foam and within 2 tanks it was quiet again.. Now I know what you are saying about the alcohol and all but What is worse .. a little alchol in 2 tanks or carbon on the injectors??
2005 CTD Laramie, Mineral grey, auto, 2" daystar leveling spacers, 315 BFGAT's, air horns, Isspro guages "A" pillar mount (egt,trans temp, boost), Snug top hard cover with Remote latch, bed rug, daily driver with light towing now and then.
Gerry is offline
