Kenworth T2000 - Dodge Cummins Diesel Forum
General Diesel Discussion Discuss General Topics related to the Cummins , Dodge Rams , Other Diesels Ect....NO ADVERTISING
post #1 of 3 (permalink) Old 07-10-2009, 03:25 PM Thread Starter
nbaca's Avatar
iTrader Score: 1 reviews
Kenworth T2000
Hey guys i amworkin on a friends truck and he is having AC problems and i cant keep the clutch in motion for more than a minute and then it turns off. Does anyone know where the freeze switch is.....how can i test it......how can i test those pressure switches.....
Diesel Pros, Maximum Diesel, Diesel Auto Power, Ultimate Diesel, OTT Performance, F1, Wicked Diesel, ARP and much more
To view links or images in signatures your post count must be 3 or greater. You currently have 0 posts.
nbaca is offline
post #2 of 3 (permalink) Old 07-10-2009, 05:54 PM
CoalRoller's Avatar
iTrader Score: 0 reviews
Its been a while since I’ve touched a T2000 but follow the high pressure line back from the condenser and you should find 2 pressure switches attached to the line these are the binary and trinary switches. One switch will control the engine fan and the other will control the a/c compressor clutch. I know they are there for sure on a W900 and if I remember right the T2000 has them too.
You can test the circuit with a jumper wire. Unplug the fan switch and the fan should engage when the circuit is open and disengage when you insert the jumper wire. Unplug the compressor switch and the compressor should disengage with the circuit open and engage with the jumper inserted. You really need a/c gauges connected if you do this so you don’t let the head pressure get too high.
Next look on the driver side of the coolant reservoir. You should see a low pressure a/c line with a low pressure switch attached to it. Im not sure about testing this one because I think it has 3 wires, but like I said it’s been a while since I’ve worked on one.
If your engine fan is working properly and the compressor is cycling your switches are probably good. Check to make sure the condenser is clean. If air can’t pass through and cool it the high side pressure gets too high and the compressor will shut off.
Also if the refrigerant is low the low side pressure falls too low when the compressor comes on and the low pressure switch cuts off the compressor.
Have you hooked up a set of gauges to the truck to check the pressures and see if you have a blockage in the system?
2002 6 speed, Edge Drag Comp, DAP 100s, Phatshaft 62/65-14, ARP 425's, Valair Kevlar/ceramic single, FASS 95
CoalRoller is offline
post #3 of 3 (permalink) Old 07-12-2009, 12:24 AM Thread Starter
nbaca's Avatar
I found the problem and it was the freeze switch. The probe that is inserted into the evap was bad and was causing a bad signal causing the clutch to cycle. Of course none in stock here in ABQ but at least i found the problem. Thanks for the help.
nbaca is offline
Closed Thread
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Dodge Cummins Diesel Forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Show Printable Version Show Printable Version
Email this Page Email this Page
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
