Power Steering Fluid Freezing Point ??? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 02-12-2007, 02:25 AM Thread Starter
Katmandu's Avatar
Question Power Steering Fluid Freezing Point ???
The last few mornings the temps here have ranged from -5 to 5F degrees outside. When I start my truck (outside at work NOT plugged in) there is a horrible groaning sound coming from the PS pump. The truck is alot harder to turn as well.
I'm guessing the PS fluid is thicking up due to the Low Temperatures outside.
I've searched the forums and others have suggested using Valvoline Semi-Synthetic PS fluid with good results.
What is the Freeze Point for Power Steering fluid ??
Worst mistake of my life was selling this truck!!
"The Holy Grail" 98 12 Valve, QC, SB,4x4,5 Speed, SLT, Leather, #10 Plate, 3K GSK, 100HP Injectors,AFC Full Forward,BHAF, '03' Track Bar,DSS bar. 400HP/953lbs TQ
Katmandu is offline
post #2 of 6 (permalink) Old 02-13-2007, 07:22 AM
Man Ive been in some really cold temperatures with my truck,its never frozen.It moans on startup when its really cold but thats it.Just keep the level full and I wouldnt worry about it.I run regular fluid and my trucks seen 40 below
01 3500 4x4 qc.Smarty.edge drag comp,grandrock 6 inch mitres.Vulcan big line kit,BHAF.
97 2500 lb ext cab.MBRP 4 inch ,BHAF
kelowna diesel is offline
post #3 of 6 (permalink) Old 02-13-2007, 09:49 AM
john in montana's Avatar
I deal with -33 here in Montana .I never had my fluid freeze.Yes it does groan on some vehicles because the oil is thick.Switch to a different oil if it bothers you.
1998.5*24 valve*2500HD*4W.D.* 4 Speed Auto* LB* Q.C.* Two Tone Paint*Trailer Tow *Adj Boost Elbow* 5in.Straight Exhaust* AFS Big Dog Fuel System *Custom Powder Coated Grill Guard with KC lights* 285/75/16* 4 wheel anti-lock brakes*Anti Spin Diff.*128K miles +counting
john in montana is offline
post #4 of 6 (permalink) Old 02-13-2007, 10:29 AM Thread Starter
Katmandu's Avatar
Arrow
I did the turkey baster thing last night and refilled with Valvoline Semi-Synthetic PS.
It's going back into the low single digits in a couple days so we'll see then if it worked or not.
Katmandu is offline
post #5 of 6 (permalink) Old 02-13-2007, 11:47 AM
DBLR's Avatar
My self I've like the Amsoil ATF as it is full synthetic fluid and it has held up in all of my cars and truck over the past 4 years with out any break down or flow problems down to -24 below zero.
JMHO
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's:
DBLR is offline
post #6 of 6 (permalink) Old 02-15-2007, 08:25 PM Thread Starter
Katmandu's Avatar
Thumbs up
Well, it went down to -2F last night and my truck started right up with NO groans or stiffness from the PS pump!!! :thumbsup
So I'd have to say that's proof enough that it worked ! :thumbsup
Katmandu is offline
