International 4300 DT466 - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 05-04-2009, 12:55 PM Thread Starter
catcher149m's Avatar
Question International 4300 DT466
Hello Everyone,
I have a late model International 4300 chassis with the DT466. Does anyone know of quick and easy power upgrades?
'99 2500 ext cab SB 5 speed, Airdog 150, Autometer FP, EGT, Boost, Quad Adren, 5" straight pipe, Valair 500 HP SD
catcher149m is offline
post #2 of 13 (permalink) Old 05-04-2009, 08:45 PM
nevrenufhp's Avatar
Quickest & easiest is to take it to IH for a reflash/re-rate. Other than that, buy an extra oil temp sensor, and hook it to the wiring but dont thread it in the hole. Leave the original in the hole. It makes it think the oil is cold, and will advance the timing a smidge. You can also get a cam position sensor for the same year powerstroke. If you have the kash, DIYinjectors can make you some kustom higher flowing injectors. Price really isnt that bad.
My low buck diesel fuel rate site:
67 F100, 300, 4bbl
08 VW R32
nevrenufhp is offline
post #3 of 13 (permalink) Old 05-04-2009, 08:59 PM
MrCubbins's Avatar
your talking an electronic DT right? I believe diablo makes a programmer for them. if we're talking about a mechanical engine, PM me, depending on your injection pump I can tell you how to make her scoot
98.5 24V rclb 5speed 4wd.. Not stock
97 12V eclb dually 5 speed 4wd.. stock
Wifes truck: 99 24V eclb dually 2wd auto.. stockish
MrCubbins is offline
post #4 of 13 (permalink) Old 05-04-2009, 09:02 PM
nevrenufhp's Avatar
A 4300 is 466E, 2000 or newer.
I thought the Low Buck fuel rate site had pretty much most of the tricks for a mekanikal 466. Am I missing something?
67 F100, 300, 4bbl
08 VW R32
post #5 of 13 (permalink) Old 04-30-2010, 03:48 AM
Robert Ivey
Rivey's Avatar
iTrader Score: 5 reviews
I know this is an old thread but we have a 2002 International DT 466 4300 with the sychro 6 speed. What can we do to get more power out of it? TS performance makes a module for it. anyone else?
08|QCSB|6.7|68RFE|4x4|513 rwhp
08|RCSB|6.7|48RE|4x4|1155 rwhp
06|RCLB|5.9|48RE|4x4|
rwhp
Built & Tuned by me @ Calibrated Addiction
Rivey is offline
post #6 of 13 (permalink) Old 04-30-2010, 04:31 AM
wag06cummins's Avatar
Diablosport makes a powerpuck for it as well.
06 qc ats dual pumps, suncoast gone now garmon full race billet,Airdog150,smarty tnt-r,mp-8,springs,studs,wicked water bypass,64/480 twins,180cpps,
OHIO COAL ROLLERS
wag06cummins is offline
post #7 of 13 (permalink) Old 04-30-2010, 01:01 PM
Robert Ivey
Rivey's Avatar
Would it need gauges with that or will it run cooler?
rwhp
Rivey is offline
post #8 of 13 (permalink) Old 05-01-2010, 10:23 AM
macko300exc's Avatar
for us to program your engine to the next power level, it must be able to support that power. Meaning International will make sure the drive line is rated for the power level you want. Now the aftermarket i couldnt tell you
macko300exc is offline
post #9 of 13 (permalink) Old 05-01-2010, 08:44 PM
nevrenufhp's Avatar
Quite a few different makers of a performance module for them. Diablo, TS, Edge(I think), Hypermax, and maybe a couple others. There's a shop that I work with that will reflash your ECM, and rebuild and machine your injectors for higher flow to get you some bigger power gains. They say, they can easily get 350hp.
67 F100, 300, 4bbl
08 VW R32
post #10 of 13 (permalink) Old 05-03-2010, 07:31 PM
I think another place is Pittsburg Power, buddies C15 will blow over 60 psi with there turbo, programmer, and head kit.
post #11 of 13 (permalink) Old 05-03-2010, 09:36 PM
Bluedually4x4's Avatar
Same basics as a pickup, open up the exhaust and see about getting more air to the turbo.
1998 3500 4x4 5 speed reg cab dually 12valve
TST #10, ATS exhaust man, 5" turbo back exhaust twin 5" stacks, SB 13.5 clutch, BHAF, DDP 75 hp injectors, 3000gsk, timing set at 16
Bluedually4x4 is offline
post #12 of 13 (permalink) Old 05-03-2010, 11:15 PM
Robert Ivey
Rivey's Avatar
the diablo power puck looks to be the best bang for the buck so far....mainly need it for mileage
rwhp
Rivey is offline
