Old 10-29-2009, 02:39 PM   #121 (permalink)
Is BEER a food group?
Lonno's Avatar
Really, no cat. Hmmmm. Whats the CARB# ?
2001 Quad 4X4, Airdog 100, 4" ex, BHAF, Stage 4 Jammers, DTT trans, Triple disc TC, valvebody, GM solenoid, Jhooked, QuadADR, BETA 3000, BD Rad, GM drum cylinders, 3" Lift,Burnin a lil veggie oil and my exhaust smells like carnitas.
Lonno is offline   Reply With Quote
Old 10-29-2009, 04:35 PM   #122 (permalink)
Danderson's Avatar
Yeah,your year ran clean enough to not require a cat. CARB= Ca Air Resources Board. They're the folks that are prompting the potential emission testing. They issue exceptions to some aftermarket equipment to enable that equipment to be legally used in Ca on vehicles. Everything under the hood's got to be stock for the test. The box will have to come off,then you can replace it. same with air filters etc. Bunch of junk.
'07 2500 SLT,5.9,reg.cab.,G-56, 4wd,8' Northstar popup 24/7. Carli,Defiant,Thuren,King.
Danderson is offline   Reply With Quote
Old 10-29-2009, 04:37 PM   #123 (permalink)
MOPAR MAN's Avatar
as far as I know my 2000 didnt come with a cat ether.
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper.
MOPAR MAN is offline   Reply With Quote
Old 10-30-2009, 01:58 PM   #124 (permalink)
HELP FIGHT CA SMOG REGS!
dezl's Avatar
Originally Posted by Danderson View Post
2001's didn't come with a cat. Why add even a gutted one? They had a resonator and a muffler stock though.Under the hood, if it doesn't have a CARB # I believe it's grounds for failure.
Correct, any after market items IE, intake, turbo will need to have a CARB #. As of know I think the only company that has any approved item's through CARB is banks.
Sorry pal but its not "potential" the testing start 1/1/10.
I would call your local dealer and ask, it may not have come with a cat but it probably had a resonator. Your dealer will be able to tell you for sure.
http://www.petitiononline.com/8484/petition.html
08 Chevy LMM 6" lift 20" monsters w/35's, other than that all stock.
69 Chevelle, big motor and bad brakes
dezl is offline   Reply With Quote
Old 10-30-2009, 02:00 PM   #125 (permalink)
MOPAR MAN's Avatar
But a resonator or muffler are not emishions related. So it should not matter as long as it didnt come with a cat
Old 10-30-2009, 05:27 PM   #126 (permalink)
dezl's Avatar
In theory yes, but you have modified the truck with non CARB approved items meaning it will fail.
Old 10-30-2009, 08:47 PM   #127 (permalink)
On a non cat truck (all 24v 98-02) the exhaust is not an emmission part so mod away on the exhaust
05 2500 4x4 Carli Dominator 3.0 Suspension Baja proven
94 2500 4x4 Carli performance 2.0 with full leafs
90 wrangler injected locked and caged crawler
bob4x4 is offline   Reply With Quote
Old 10-30-2009, 08:53 PM   #128 (permalink)
Originally Posted by powermad View Post
so wait its ok to have a aftermarket turbo?
Must be stock turbo.Now if you have an HX40 it looks just like the hx 35 (just bigger) the now popular Switzers stand out like a sore thumb they look completely different even a rookie smog tester will see the brand diference
Old 10-30-2009, 09:36 PM   #129 (permalink)
powermad's Avatar
yea my turbo is not discrete at all what if i wrap everything in exhaust wrap so they cant see anything? lol
i miss you dad r.i.p! i will always love you!
THE NEW TRUCK...1997 white dodge cummins 2500 sport. 62/65/13, ats 3 piece exhaust manifold , afe stage 2, 3000gsk, #10 plate, 3"carlie suspension. built 5 speed swap
powermad is offline   Reply With Quote
Old 11-03-2009, 05:30 PM   #130 (permalink)
dezl's Avatar
I would assume the tech would want to investagate a bit more.
Old 11-10-2009, 07:29 PM   #131 (permalink)
Just got back from SEMA a couple days ago. The big news is that CARB has sent out cease and desist letters to all manufacturers and also those who sell there products. They are not allowed to sell anything that "touches air, or fuel" into calif after Jan 1st 2010. Also they are not allowed to advertise these products either. At least until they get a CARB number for each item. Unfortunately Carb is broke and has layed off a lot of employees. So testing is very slow. I have had about as much as I can stand of this State. The Berlin Wall went down 20 yrs ago, and is now going up around Calif.
I have already called my state Sen to see what I can do. Maybe nothing, but I am sure going to give it a try. This means half of what I sell in this state is now illegal.
2007 6.7 4x4 Laramie. 68rfe w/ATS 5star torque converter Edge Juice w/Att, H&S Kit 5" turbo Back w/Stack. ATS Diff cover, 6" lift 35"toyos tires. Locking hubs.
diesellady is offline   Reply With Quote
Old 11-10-2009, 08:40 PM   #132 (permalink)
Danderson's Avatar
Richard from Glacier returned my call@ 7:00 pm last night(great customer service) and we discussed the upcoming regs. The way I'm seeing it is,his MK-2 filter system will render our vehicles unpassable in the eyes of CARB. Cleaner fuel=cleaner burn=green compliance(gosh I'm beginning to hate that term) but not to CARB here. Nutcases running the show.
