ok this is going on a 96 pjoke, as some of you know the downpipe is pretty much retarded... any how heres everything:
i've been looking at doing this for quite a while. im going to hold off on the opened up downpipe for now until spring/summer rolls around. i can get a 10' 4" pipe for about 77 or so bux from a local store. only problem is i'm planning on doing a side dump in front of the back tire. i haven't measured it yet but i know i don't need 10'. the longest sizes they do otherwise is 3' lengths. i also found pipes on line i can order by the foot. so here's the main question:
is the stock downpipe, coming rite before cat 3.5" or 3". i found the universal MBRP adapters online as well at ADAPTERS . id either go with 4" or 5". id like to get this done as soon as possible because ive been putting it off for far too long. i just cut off my muffler and back yesterday, its a little deeper but no big difference as im guessing the cat makes a big difference as well so i want that gone.
o yea heres the link with the exhaust tubing. TUBING
so if i get the adapter from 3.5"ID to 5"OD getting a 5" exhaust pipe wouldnt work correct???
what would you guys do with that given info???
