1) How do you measure a turbos size?
2) Is a smaller exhaust housing always better?
3) Whats more important volume or pressure? Or do they coincide?
4) Is there any magic calculation for picking a turbo?
LOL this is what I mean no one tells us what each part of the turbo does and how changing things effects things. All answers are not answers. Not dogging you just saying I have yet to see a post that actually really explains turbos.
Sizing a turbo is pretty much like rocket science (errr, turbine/compresor science i guess...)
1)Turbos can be sized different ways. One popular way of 'measuring' a turbo is by measuring the wheels O.D (typically in mm) and the turbine housings are usually measured in cm2 displacement. So you may see a number like 66/71/14, the O.D of the compressor wheel would be 66mm, the turbine wheel 71mm and the turbine housing would be 14cm2
2)Smaller turbine housings are not always better... A smaller housing will help spoolup, but can become a major choking point (restriction, at which point the drive pressures and egt will skyrocket). A larger housing is a tradeoff for slower spoolup but more free flowing.
3)This is one area that compressor maps are the key ingredient. Pressure and volume are dependant on the compressors wheel design/size amongst many other factors. Remember that pressure is only a measure of restriction, its the flow that you want, thus the reason for porting heads and opening up the intake/exhaust.
