Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > General Cummins High Performance
General Cummins High Performance Discuss Everything else Pertaining to High Performance
Old 10-22-2007, 10:47 PM   #1 (permalink)
compound turbos?
how many people are running a compound turbo setup here and what kind of boost are you running?
persicutor is offline   Reply With Quote
Old 10-22-2007, 10:50 PM   #2 (permalink)
RyanB's Avatar
I am!! I am pegging the 100psi boost guage and figure its only around 105-110psi as my drive pressure is just under 100psi and at around 85psi drive pressure I am seeing just a hair over 95psi of boost.
RyanB is offline   Reply With Quote
Old 10-23-2007, 06:51 AM   #3 (permalink)
Go for Broke
Graphic Man's Avatar
around 70 psi of boost and around 70-80 drive pressure
Scott
08 Mega cab is on it's way
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline   Reply With Quote
Old 10-23-2007, 06:57 AM   #4 (permalink)
BD twins, set at 74 psi currently.
Diesel Nut is offline   Reply With Quote
Old 10-23-2007, 10:21 AM   #5 (permalink)
what does that sound like?
1999 TurboTransAm - 11.7@135 on street tires
2003 Yamaha R6 - 10.7@124
looking for a 2.5 gen Ram 2500 4x4 cummins
smokinhawk is offline   Reply With Quote
Old 10-23-2007, 10:27 AM   #6 (permalink)
#1 Thread Derailer
BBRam's Avatar
Same here at 60+psi.
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 10-23-2007, 12:32 PM   #7 (permalink)
nice, Ive always liked the compound turbo setups. Now, after how much boost do you generally have to upgrade the internals? and what about things like headbolts, and hardpipes etc? Also, I calculated that at 70+ psi of boost, the outlet temp of the air is close 300 degrees celsius. Are you guys also using water to air intercoolers ?
Old 10-23-2007, 12:37 PM   #8 (permalink)
Sales Rep For BD Power
dave@BD Power's Avatar
WOW, that is a lot of boost Ryan, what mods are you running, fill in your signature for us please.
03 Dodge Ram 2500 "Reg Cab"
Fuel: BD X-Tuner - BD X-Power - Max Flow Lift Pump
Air: BD Super-B Turbo - BD Intercooler - Dual X-Hale Exhaust - BD Exhaust Manifold - BD X-Power Intake Elbow - Ice Box Air Intake
Power Train: BD Transmission - BD Low Stall Convertor
dave@BD Power is offline   Reply With Quote
Old 10-23-2007, 12:51 PM   #9 (permalink)
Go for Broke
pro built motor for his pulling truck.......1 nice rig :thumbsup
Old 10-23-2007, 01:03 PM   #10 (permalink)
No kidding, very impressive
Old 10-24-2007, 09:13 PM   #11 (permalink)
how do the flow rates work with compounds? you cant just add the flow rates of both turbos together right?
and do regular tbolt clamps work at these high boost pressures, or are constant tension spring loaded ones needed?
Old 10-25-2007, 09:17 AM   #12 (permalink)
you would think you needed vband connections for over 70psi.
anyone have a sound clip of one?
