Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > FTEDiesel.com
FTEDiesel.com FTEDiesel.com
Old 10-29-2009, 09:58 AM   #61 (permalink)
Super Administrator
BBRam's Avatar
It launched real hard (much harder than I expected at 15psi) then tried to wheel hop. Then the dreaded loud BANG!
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 10-31-2009, 10:58 PM   #62 (permalink)
Super Administrator
BBRam's Avatar
Well Wally, I misdiagnosed that one. Intermediate shaft this time.
Old 10-31-2009, 11:34 PM   #63 (permalink)
FTE DIESEL
JacktheBear3's Avatar
We can fix that.... Happy TruckandTreat
2002 24V, 2500 Quad Cab, Dark Silver, We Bit O Lift, Plain Jane, Comp (drag), BDRAD, Smarty Stack, 027 SO VP, FASS 150/150 w/BigStraw, F1 Mach 7.?, The Girlz are T61 & S400, PDR Stg III Head w/Rings top & bottom, HTS/FTE FULL billet Auto, SS Single Converter, Optix Gauges ( all high #'s), Detroit Locker, Custom 6" Miters, and plenty O junk in the Trunk...
Floor It CP3 MOD's & PPE Dual Fueler Kits
6.7 Race / Delete Pipes and Sims in stock
JacktheBear3 is offline   Reply With Quote
Old 11-01-2009, 11:01 AM   #64 (permalink)
Super Administrator
BBRam's Avatar
We figured you could. We'll talk on Monday.
Old 11-01-2009, 11:24 AM   #65 (permalink)
03 Cummins
well that's why you cant have nice things do all of the bolt holes on the adapter plate still have threads? i mean all of the times the tranny has been in and out of that thing?
2003 2500 6spd 4x4, SB-DD, short shift, springs, studs, 5"exh, afe, pillar of isspro, traction bars, BDS 6" lift, boost fooler, FASS 150, 64/71/13SS, SMARTY REVO, stock injectors got honed 60%,
gator6 is offline   Reply With Quote
Old 11-01-2009, 11:27 AM   #66 (permalink)
Super Administrator
BBRam's Avatar
Why do I keep hearing that.
Old 11-01-2009, 11:30 AM   #67 (permalink)
Super Administrator
BBRam's Avatar
We only use half of the bolts each time, and rotate the bolt sequence each install.
Makes for quicker R&R, along with less wear on the threaded holes.
Old 11-12-2009, 10:41 AM   #68 (permalink)
Super Administrator
BBRam's Avatar
Here's a pic.
But it's all fixed now. Thanks Wally!
Old 11-12-2009, 10:53 AM   #69 (permalink)
FTE DIESEL
That piece looks like it will make a nice lamp for the garage office
Old 11-12-2009, 11:59 PM   #70 (permalink)
pro99's Avatar
I thought we could just weld it back up and put it in the Drag truck trans
pro99 is offline   Reply With Quote
Old 11-13-2009, 12:01 AM   #71 (permalink)
pro99's Avatar
Here's a pic.
Wash that pig
