Ok I see. Could you tell me how to keep the size corrected when I take the xrt off?[/
as long as you dont change it when you return to stock it will stay at what you set it.you can still plug your xrt in & change tire size with efi live running you truck.
Ok cool that's what I needed to know. Thanks
__________________ -09 6.7 2500 QC SB G56(#2) 4X4: 635HP/1100TQ EFI Live by Ryan!, FI S472/83/.90, Steed Speed w/wastegate capped, Haisley H11 studs and fire ringed, Hamilton springs and push rods, Floor it 3.5 CP3, GDP 125hp nozzles, 5" TBE, Custom 5" intake, Pusher Intake Manifold & Boost Tube, EGR/EGR Cooler deletes, Airdog 150, SBC DD3250, GDP Ladder Bars, Pro comp Long Arm kit, Fox shocks, 20" XD-Series Revolvers, 37" Toyo Open Country M/T, Recon Smoked LED Cab Lights, 20% tint, Line-X, AMP Research Steps, Autometer: Boost, Pyro,and Fuel Pressure. -'12 Mustang 5.0: Intake, Exhaust, Tune...421 RWHP/ 376 RWTQ
07 6.7 QCSB, EFI LIVE BY DAVE MATTHEWS, dpf and egr junk fell off, gh delete, arp studs, modded cp3, tuned tcm on 35"s. 487/ 1100 with a slipping stock tranny. 13.6@98.6 http://youtu.be/VFjzJA0TjbY
We hit a few hurdles with the transmission controller. Reading is enabled, but we were not gaining ground so it's been put to one side for the moment in favor of projects we can more easily progress.
hey quick question: Does Efi live control the speed limiter?
Also if i want to use my xrt to change my tire size. Can i just do it or do i need to take the efi live tune off?
Speed limiter is controlled with EFILive.
As for tire size, you'd need to understand what your programmer does. If it just changes ECM parameters like EFILive then the EFILive flash will override those. If the programmer changes the ABS or other module that EFILive touches then the programmer changes will remain in place.
A year from the other day. They are working on it after the 03+ 5.9. Then the 10+ will get their turn.
The Following User Says Thank You to disposablehero For This Useful Post:
Ok gotta question I am fixing to buy EFI Live for my truck. The question is can my brother and his friend us the same programmer they have 5.9L so there would be three trucks being ran off of this programmer is that conceivable if o bit two 5.9 L licenses and one 6.7L license.
