Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Edge Products
Edge Products Edge Productsl
Old 09-08-2008, 07:34 PM   #1 (permalink)
Dodge > Ford, Chevy
JDiepstra's Avatar
$200 for Edge Attitude turbo timer update??????
I heard from a guy here on Cummins Forum that he got a Turbo Timer upgrade for his 04.5 Edge Juice with Attitude for $50. I called Edge and they told me it would cost me $200! $200?! Then, another $100 for the Hot Unlock. $300 to update my $900 setup? Ouch! Then the guy from Edge told me that if I had my Attitude for less than 60 days, they would do the Turbo Timer for $50. Now wait a minute!!!! In the one year that I have had my Edge, and been a member of TDR, DTR, and CF, I have heard nothing about this turbo timer upgrade until yesterday. Why is this not advertised anywhere? I would have jumped on it on day one had I known it was available! Also, many other models of the Juice with Attutude come standard with turbo timer, fuel psi, and tranny temp. Why do I get shorted on my 04.5? Thanks for letting me vent!
2004.5, 2500, Cummins 600, 4x4, SLT, QC, SB, 4.10's, 315's, Molten Red. 48RE by HTS . BullyDog Crazy Larry + MP-8 stack, AFE PG7 and Blade Runner, Silverline and Magnaflow mufflers into 6" mitre, DiPricol pyro, boost, trans, fuel, and rail. Train Horns for
JDiepstra is offline   Reply With Quote
Old 09-08-2008, 07:43 PM   #2 (permalink)
I had a similar problem with edge where i called 3 times and the first 2 times they said that they don't even have turbo timers on most of there models. call the tech services line on there main number and talk with a tech they seem to know whats going on a little better than the sales side. it should only cost you $50 for the turbo timer and $100 for the hot unlock. i just got mine maybe 3 or 4 months ago. also the one i got back was different than the one i sent in, but i received a 30104 back that had the extra wiring for the timer
2005 Dodge Ram 2500 CTD 5.9L H.O.-4wd-Quad Cab-Edge Juice W/Attitude Hot Unlocked W/ Turbo Timer,DTT Trans, 50Hp injectors, Amsoil BMK11, PSC Steering Brace, Ice Box CAI, Bilstein 5100 Shocks
boozzer86 is offline   Reply With Quote
Old 09-19-2008, 10:27 PM   #3 (permalink)
BSouth's Avatar
Mine has a turbo timer on it and it only works about once out of 100 times.
05 3500 Yellow 6 speed,Mega cab dually fenders,Rumble Bee Scoop,Edge Juice w/A2,Edge EZ,Smarty,CFM+,ATS Exhaust Mani,Silver 64,90's,Airdog 150,Valair 3600 DD,5" Silverline exhaust,8" tip,Icebox with torque tube,Quad Rail Gauge,Mag-Hytecs,Lorenz Level, 22.5's
BSouth is offline   Reply With Quote
Old 09-19-2008, 10:50 PM   #4 (permalink)
Old_Sparky's Avatar
Turbo timer works fine on mine.
2000 Dodge RAM 2500, 5.9 Cummins, 4x4, 5-Speed manual transmission. Silverline 4" exhaust, Juice with Attitude,
Airdog 100, K&N air filter.
Old_Sparky is offline   Reply With Quote
Old 09-19-2008, 10:58 PM   #5 (permalink)
silvercummins31's Avatar
Do you happen to have the break pressed when you shut it off? Mine did the same thing and i realized i help the break when i shut it of and hitting the brake causes it to shut off.
01.5 2500 6 spd. HO silver, Quad Cab Short Bed. 120k, Edge Juice w/ Attitude HOT, amsoil 4510, 4 inch Straight pipe, silencer ring gone
silvercummins31 is offline   Reply With Quote
Old 09-19-2008, 11:16 PM   #6 (permalink)
BSouth's Avatar
the e-brake? or the actual brake?
Old 09-19-2008, 11:23 PM   #7 (permalink)
actual brake
Old 09-19-2008, 11:26 PM   #8 (permalink)
BSouth's Avatar
huh never knew that. Thanks for the heads up I'm gonna have to try this in the morning! Boy do I feel like an idiot now!
Old 09-19-2008, 11:27 PM   #9 (permalink)
TOXIC-DIESEL's Avatar
on mine when it worked i had to tap the skinny pedal real quick and then it'd turn off or sometimes my turbo timer keeps my truck runnin even though its way below the timer set point so i have to pop my hood open and un-plug the module from the wiring harness then my engine shuts off...... its really kinda a pain so i just disabled the feature and just watch my egts before i turn it off
TOXIC-DIESEL is offline   Reply With Quote
Old 09-19-2008, 11:28 PM   #10 (permalink)
lol i just put it on a week ago and i was trying it out and i was like sweet this is cool and then when i hit the brake it shuts off incase you don't want it to run so i went to show someone and shut it off and it didn't work i was like wtf it just worked and then i figured out i was holding the brake when i shut it off. lol
Old 09-20-2008, 12:31 AM   #11 (permalink)
jmono33's Avatar
Do you guys watch the thing on the monitor that says something like Press brake for emergency shut off?
1990 Dodge D250 R/C, Non I/C Cummins, 727 auto, autometer gauges, 366 spring, ground fuel pin, pump tweaks, straight pipe
jmono33 is offline   Reply With Quote
Old 09-20-2008, 12:42 AM   #12 (permalink)
white99's Avatar
turbo timer works fine on mine.everytime....
99 181k rebuilt rear/rebuilt trans/bd triple diskII 11 HOLE/J/A,afe/bd boots/bd x monitor/Leveled/recons/7x44 mitres
white99 is offline   Reply With Quote
