Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Edge Products
Edge Products Edge Productsl
Old 02-20-2008, 08:44 AM   #1 (permalink)
EZ edge issues
Hey guys, new to this forum and I got a question about my 01 dodge which i put an EZ edge module on.
The problem is that it seems to work intermittently, on my way to work theres a good hill to climb, one day it will do it in OD no problem, other times it has a hard time with it, reducing me to 4th gear just as it did when the engine was stock. It feels like the module simply turned off, the turbo is quieter, the engine seems to be working fine it just isn't as peppy as it is when the edge module is functioning. Is this a known issue with these modules? Is it possible a loose or dirty connection would cause this? It seems to act its worst when in cold temperatures. I've only had this module on since november from new.
any ideas?
alberta fabber is offline   Reply With Quote
Old 02-20-2008, 09:14 AM   #2 (permalink)
Super Moderator
rbmchief's Avatar
i would definitely check your connections. If thats not it and you bought it new contact edge and they'll get you fixed up
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin 2 stroke.
rbmchief is offline   Reply With Quote
Old 02-27-2008, 05:47 PM   #3 (permalink)
mine was acting up to it was the power connection not grtting good connection i used a better fuse connecter the 1 that rapps under the fuse and then up instedd of the 1 that you stick fuse through the hole.
06 dodge 3500 ,banks big hoss six gun ,smarty tnt,tst,southbend clutch ,diablo sport ,edge w attude
easymon is offline   Reply With Quote
Old 03-03-2008, 01:38 PM   #4 (permalink)
2500redram's Avatar
I had the same problem with my 1st EZ, it was the module it self that was bad.next time it does it try pulling over and cycle the key, if it starts working i would say it is the module.
01 dodge 2500 4x4,2" procomp leveling kit,edge comp,4" magnaflow Turbo back exhaust w/5" tip,BHAF,autometer trans/boost/pyro,bollinger front bumper w/KCs and marker lights,nv4500,valair 13"kevlar/ceramic clutch,fass 150 BD 130 nozzles.
2500redram is offline   Reply With Quote
Old 03-16-2008, 06:52 PM   #5 (permalink)
Whippit96's Avatar
Wow....I just started to experience the exact same thing. I go over a pretty big hill to and from work and I noticed the same thing as you. Also it can be noticed from getting on the go pedal heavily from a dead stop, when the EZ is working it will throw the truck broadside in a heart beat, when it's not working it won't even spin the tires.
My EZ came on the truck when I bought it, and I've checked all the connections and everything is good. Glad I'm not the only one experiencing this though.
1999 2500 Quad Cab 4x4, Edge Juice w/Attitude, AirDog 100,BD Super B Special, 4" turbo back to Dual 5" Miter's, BHAF, CoalTrain 150 Injectors, thanks to Holland Court Diesel!
Whippit96 is offline   Reply With Quote
Old 03-16-2008, 07:04 PM   #6 (permalink)
wewille's Avatar
Ive got the problem too. I checked my connections awhile ago and i still had the problem, i just havnt got around to calling edge yet
2005 Ford F-250 Powerstroke. 1999 2500 extended cab short bed, edge ez, staight piped, silencer ring removed, walbro fuel pump, Diprocol fuel, boost, and pyro. gooseneck, 15% tint, transgo kit, a new western mvp v plow on order!!! and a 53 block
wewille is offline   Reply With Quote
Old 03-16-2008, 07:14 PM   #7 (permalink)
Whippit96's Avatar
Only problem is Edge probably won't be able to help me out since it was on my truck when I bought it.
Old 04-30-2008, 11:15 AM   #8 (permalink)
Jerry @ Edge's Avatar
give us a call 888 360 3343, and we'll get you taken care of!
THANKS.
Jerry @ Edge is offline   Reply With Quote
Old 05-06-2008, 12:29 AM   #9 (permalink)
Whippit96's Avatar
THANKS.
I will give ya a call tomorrow, sorry I just noticed this now. It's been a bad month or so...
Old 05-06-2008, 01:30 AM   #10 (permalink)
Ed ke6bnl's Avatar
I have one as you it came with the truck and seems to be working fine at all times. then I have never disconnected it but the truck goes like crazy and I am not going to make any changes, did also come with a 120 hp adder I think by tst but I really don't need more power and what might come with that. Ed
1998 CTD 24v,DTT trans billet in and out,Edge EZ, exhaust brake, 4" turbo back exhaust, 275 injectors, Mag-tech trans and diff pan/cover, piller gages, digital fuel psi, 4door, shortbed, larger turbo.Air Dog fuel pump/filter/air water separator
Ed ke6bnl is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
