Edge Products
Edge Productsl |
#13 (permalink) |
if you want more smoke go through the jucie configuration and than go to low boost fueling and choose a level and move the indicator from 3 to 5 (most aggerssive) you can do this to any or all levels an u can move it the oppisite way for less fueling hope this helps
01 4x4 qc 35's nathan air chime built trans bd super b special edge juice "hot" smarty cfm plus airdog 150 130hp injectors airaid 7" mitre install next week: tst comp FBD 200 sticks studs 110# springs push rods exhaust manifold water/meth
#14 (permalink) | |
Just wondering what your numbers are off of the wheels/dyno? Thanks
2001 Dodge 3500 4X4; 4" exh, Kelderman 4Link/2Airbag, Edge J/A Hot Unlock, ARP Studs, BD x-monitor, Aux L/P, F-Plate, TC, Prfrmnc Tranny, Pulse Exh Mnfld, 130HP Inj, Twins, BD 100HP VP44. |
#15 (permalink) |
My stock setting remained after I got the hot unlock code. It simply added a 6th power level (hot). As stated, setting your low boost settings to 5 (aggressive) will increase your part throttle smoke output. With my Juice/Striker 2 stack, I can shut down 3 lanes of traffic with the amount of fueling both modules provide.
2004.5 Dodge Ram SLT Quad Cab CTD 4x4, 48RE, 3.73, AirDog 150, Edge Attitude w/HOT Juice, Striker 2, GDP Intake Horn, Airaid CAI, 5" MagnaFlow SS Turbo-Back Exhaust, SR MIA, 5" Torque Tube |
#16 (permalink) | |
2004.5, 2500, Cummins 600, 4x4, SLT, QC, SB, 48RE w/4.10's, Molten Red. Edge Juice w/ Att, Silverline 4" exhaust, AFE Blade Runner + PG7 with PSM box mod, DPP Red Cool Hose, 315/70/17 BFG A/T on black H2's, HTS valve body + deep pan, Gauges, Train Horns for
#17 (permalink) |
I don't notice my truck smoking more with my AirDog 150 than when I was running the stock lift pump. The truck rolled plenty of coal when my fuel system was stock. A pressure module will definately increase your low boost fueling, which will increase your smoke output. I like the Striker 2 because it's inexpensive and on-the-fly adjustable. It also offers more power settings than the Edge EZ which makes fine tuning your truck between two modules easier. You have more options available. With the Juice on 6/5 and the Striker on 5, I've actually had friends following me pull over because they couldn't see my truck or the road in front of them. This combo really will stop traffic if you set it up to smoke. Get up to 50mph in OD with the converter locked and slowly press on the throttle until you get to about 50-60% open and the world behind you turns black. Tailgaters ride my bumper for about 5 seconds before they pull over in terror.
2004.5 Dodge Ram SLT Quad Cab CTD 4x4, 48RE, 3.73, AirDog 150, Edge Attitude w/HOT Juice, Striker 2, GDP Intake Horn, Airaid CAI, 5" MagnaFlow SS Turbo-Back Exhaust, SR MIA, 5" Torque Tube Last edited by EddieCTD : 08-07-2008 at 06:48 PM. |
#18 (permalink) |
I have the edge att. w/hot juice on my 04.5 but there is no level 6.From what I understand different year trucks have different ways of obtaining the hot juice.Some units have to be sent to edge, some dont.I would like to know how to tell if I even have it on the truck.Guess I'll have to call them.
2004.5 3500,srw,48re,LB,Deep Molten Red |
#19 (permalink) |
If you find the Hot Unlock Code option in your menu, then you don't have to send it in. Go to the Edge site, print and fill out the waiver, then fax it in to Edge. THey will call with your unlock code.
#20 (permalink) |
it depends on the manufacture date on some of the juice with attitudes. The older ones wont have the option to enter in the code i know that, so you will want to call the tech support and find out if you can get a new one sent out and return the old one so that you can then get the hot code. It does retain the stock settings, with the added "level 6" |
#21 (permalink) |
Ya the hot unlock will dump some serous black.. mine would pour black all the time until I installed the fass 150.. now it cleans up once boost is happening. Its too much fuel for a stock turb though... make sure your low boost fueling is set up on the highest setting if you want smoke.. (sidenote) I've been running my truck on level five with the low boost fueling as low as it will go.. doesnt blow hardly any smoke but can still lay the smackdown and has nice throttle feel and responce.... if I want to race or be a dink throw er on hot mode with maxxed low boost fueling and leave people sitting in intersections.
#22 (permalink) |
I love mine. Had a young punk behind me the other day with his girlfriend driving like an a$$. when the smoke hit them he pulled over. ![]() ![]()
:06 5.9 3500 sg.rear wh. 6 speed 4 dr LB 4x4 red edge juice w/A2 HOT 1995 2500 4x4 5.9l auto, Head studs,60#v.s.,head ported. super b special,BD exh. man. ,75Hp. ddp inj, 4000 GSK,larger holders and lazer cut DV, 18.5* timming ,home ground 100 plate. |
#24 (permalink) | |
Get a pressure module for even more fun!
2004.5 Dodge Ram SLT Quad Cab CTD 4x4, 48RE, 3.73, AirDog 150, Edge Attitude w/HOT Juice, Striker 2, GDP Intake Horn, Airaid CAI, 5" MagnaFlow SS Turbo-Back Exhaust, SR MIA, 5" Torque Tube Last edited by EddieCTD : 08-13-2008 at 03:29 PM. |
