Diesel Additives - Page 3 - Dodge Cummins Diesel Forum
Diesel Polls Cummins Forum Official Polls
View Poll Results: How many 6.7L CTD owners use a Lubricity/cetane improver
Yes I do 130 63.73%
No I do not 75 36.76%
Multiple Choice Poll. Voters: 204. You may not vote on this poll
post #25 of 63 (permalink) Old 09-21-2012, 09:38 PM
I use Power Service in the gray bottle.
I started using it when ULSD rolled out with concerns about lubricity. I saw mpg improvements and have used it in most tanks since in my 1.9TDi and the 6.7 . The 6.2 usually eats a decent concentration of WMO. No lubricity concerns there so it never sees the additive.
Sent from my DROID RAZR using Tapatalk 2
Matt65 is offline
post #26 of 63 (permalink) Old 10-25-2012, 11:37 AM
Alabama Chapter VP
OneFearsome5.9's Avatar
Power service diesel Kleen
SOLD: 2006 Ram 2500 4x4 QCSB 5.9 - Not Stock thanks to Firepunk, DPC, EFI Live & Anarchy, Edge, ATS, Bill, Rollin Smoke, MBRP, Rough Country, Suspension Maxx, Ranchhand, BMF, Toyo
OneFearsome5.9 is offline
post #27 of 63 (permalink) Old 10-25-2012, 11:54 AM
Hardcore Cummins Lover!
Gunny Fitz's Avatar
Yes I use DIESEL additives and truly believe something is gained from them. DIESEL Kleen is the best and know for a fact many long haul truckers use it in their rigs. It doesnt hurt anything, but isn't miraculous either.
Just another opinion thread such as which oil do you use.
**SEE POST 53 FOR A GOOD LAUGH !
Gunny Fitz is offline
post #28 of 63 (permalink) Old 10-25-2012, 12:43 PM
Alabama Chapter VP
They make another specialized for the winter too. Forgot what it's called
post #29 of 63 (permalink) Old 12-11-2012, 11:20 PM
EDGE82's Avatar
I dont know bout all of you but seems like every time i use diesel keen or equivalent I loose a little bit more mpg's
Any of you?? Used 4 ounces last fill up and got 30 miles less a tank than last time before I didn't use it
Sent from my DROID RAZR using AutoGuide.Com Free App
2002 dodge cummins 5.9, Red, 6" lift w/37's, 100hp injectors, stainless diesel 62mm turbo w/billet bullseye wheel, headstuds, valve springs, Banks High Ram Intake, royalty core grill, blacked out headlights w/8k HID'S.
EDGE82 is offline
post #30 of 63 (permalink) Old 01-15-2013, 08:46 PM
DodgeCTDpower's Avatar
I run Schaeffer's Soyshield every tank. Noticed .5 mpg increase.
2012 Ram 2500 CCSB Bighorn, 4x4, G56, 3:73, Minimax, 5" TBE Detonator Yellow
Sold: 2007.5 Dodge 3500 reg cab dually 4x4, 6spd auto, Inferno Red, Afe Mega Cannon intake, 5" TBE, XRT
DodgeCTDpower is offline
post #31 of 63 (permalink) Old 02-22-2013, 01:37 PM
Bruteforce05's Avatar
X2
I put it in about every other tank.
The grey bottle that you use in the summer seems to boost my mpg by about 1-1.5mpg. The winter time, white bottle, is too hard to judge accurate mpg's in my opinion. Between letting the truck warm up and the additives in the fuel, just hard to calculate.
Also after using it for a while, not as much black smoke when you push that skinny pedal hard.
09' 3500 Mega Cab SRW 4X4 165,000,All fluids Amsoil, deleted with XRT Pro at 35,000(Street setting) w/trans tune, ARP studs, 100HP Nozzles, Amsoil bypass kit, 35x12.50 Toyo AT II's,Thuren steering kit, 3'' lift(2.5 kings stage 2)Revmax Valve body stock 68rfe
Bruteforce05 is offline
post #32 of 63 (permalink) Old 02-27-2013, 03:57 PM
Ratdog1's Avatar
P-S in the gray used for the first time last week at 17K
just cuz
2016 4x4 3500 Laramie CCLB LOST MY EXHAUST SO I HAVE AN 18 INCH RESONATOR AND EGRDELETE.. ALSO HAVE EFILIVE BY PPEI
3.42 rear ,68 trans TUNED BY PPEI
Ratdog1 is online now
post #33 of 63 (permalink) Old 02-28-2013, 12:35 AM
norfla71's Avatar
Diesel Kleen; peace of mind more than anything else.
2008 3500 QUAD LARAMIE LB 4X4
***SOLD, SOLD, SOLD***
New ride???
norfla71 is offline
post #34 of 63 (permalink) Old 03-16-2013, 07:07 PM
Diesel Kleen, cant hurt, might help I liked the 2 stroke oil post, wonder what that does internally other than smoke.
2006 2500 quad cab SLT 4X4 SRW, 265/70/17 BF goodrich (yeh I know changing soon) T style steering, 48re Auto, Borg warner solenoid and transducer, Steering gear box brace. Draw tite gooseneck.
Joe4d is offline
post #35 of 63 (permalink) Old 03-16-2013, 07:24 PM
norfla71's Avatar
I used 2 stroke oil in my 7.3 Ford, but wouldn't use it in a CR engine. The 7.3 maxed out injection PSI at about 21,000, and that was under perfect conditions. The fuel systems seemed to be more forgiving in the Fords and aren't as affected by garbage in the fuel as CR engines are; real sensitive to water, though. Fords had HPOP systems (used engine oil to start the injection cycle at the injector, which are rather beefy.) The main drawback was having to change the fuel filter more often, but the filter was super easy to change.
New ride???
norfla71 is offline
post #36 of 63 (permalink) Old 03-16-2013, 07:40 PM
k7bandit's Avatar
Use PS in grey bottle , every fillup, piece of mind with Cali diesel
2012 2500 MEGA 4x4 Laramie Limited, S&B intake, Mini-Maxx
k7bandit is offline
