| Diesel Polls Cummins Forum Official Polls |
| View Poll Results: TCC OR O/D Locking Unlocking At Highway Speeds | |||
| TPS Cleaning or Replaced |
25 | 29.41% |
| Battery Cable cleaning |
21 | 24.71% |
| Replaced Battery's |
4 | 4.71% |
| Valve Body |
5 | 5.88% |
| T/C |
6 | 7.06% |
| Valve body and T/C |
12 | 14.12% |
| PCM Re-flash |
4 | 4.71% |
| DTT Volt regulator |
1 | 1.18% |
| Noise Filter |
14 | 16.47% |
| Alternator |
4 | 4.71% |
| Or Othere |
20 | 23.53% |
| Multiple Choice Poll. Voters: 85. You may not vote on this poll | |||
Moderator
Tcc? O/d? Lock Unlock Fix?
This is a poll to see what helped you fix your TCC? O/D? LOCK UNLOCK concern. I see a lot of post here asking about this but not a leading fix for it so I thought I would do a poll for them that are asking. With that said what fixed your TCC, O/D Locking Unlocking concern? Thanks for taking the time to vote
Charles Estep Last edited by pro99 : 07-08-2007 at 07:32 PM. |
#2 (permalink) |
The only thing that worked for me was the Happi box filter. I tried everything else and the dealership also gave up on it. I tried the filter and its been great for the past couple of years.
'99 3500 QC SLT Laramie, Leather. 4x4 auto trans, Suncoast VB, TSC 89% TC, Firestorm2 inj, Edge w/Attitude, Raptor lp, Glacier F/W Separator Combo, 4" Str8t Exhaust, High Flow Intake, Ats Exh manifold, Super B turbo. Amsoil dual filters. Non 53. Original owner. |
#3 (permalink) |
Sales Rep For BD Power
Definitely try a Noise Isolator, we sell tons of them and for the price it is definitly the thing to try first. 8 out of 10 times it is the fix for us. BD Part Number 1300030
03 Dodge Ram 2500 2WD Reg Cab BD X-Tuner stacked with BD X-Power BD Super-B Turbo & Dual X-Hale Exhaust BD Max Flow Lift Pump Ice Box Cold Air Intake Toll Free 800-887-5030 ext 105 Dave www.dieselperformance.com dave@bd-power.com |
#4 (permalink) |
govenor pressure sensor and solenoid. (on valve body) about $130 from dealer
06 2500 quad cab long bed 4x4 auto scary larry recon bully dog gauges MBRP Cool Duals afe stage2 OLD RIG! 2001 2500 quad cab 61psi boost super phat shaft 62 turbo 130 hp injectors hrvp44 suncoast trans autometer gauges afe stage 2 NOS spearco intercooler |
#5 (permalink) |
noise filter worked for me...here is a website with further information about it and instructions on how to fix it urself Dodge Ram Cummins 24V Truck Converter Clutch Cycling Repair.
99' 2500 4x4, 6" Stack, AFE, 7x.012 EDM's, .093 tubes, Redline, Prostreet 66/71/14, studs/orings, Hamilton diesel 110 lb springs, BD exhaust manifold, Fass 150/150, guages, Goerend triple disk, billet input shaft/flexplate, suncoast vb |
#6 (permalink) | |
2003 crew cab chevy 2500hd 4x4 dmax charcoal grey 85,000 32" procomp xt's and efi live tuned by duramaxin14 13.97 @99mph on a stock trany yusta have a dodge but we went rollin proverbs 13:3 |
#9 (permalink) | |
DPIPER '99 Quadcab,4x4,SB,AT,Smarty,tripod autometer on the pillar, Mickeys, Nitto 33's, BHAF, Outerware, more to come soon. |
#10 (permalink) | |
1996 dodge ram 3500 ext.cab 2wd,modified tranny &torque converter,HTB2 62/14 turbo,K&N drop in filter,370 marine injectors,#100 fuel plate,GWK washer kit mod,AFC circut removed,,4" exhaust,autometer pyro & boost gauges.
#11 (permalink) |
I ran the ground from the PCM case. I loosened a screw from the rectangular that attaches to the firewall and tapped in there. It's still working. Not sure which one fixed it, but it did.
#12 (permalink) |
i did it ALL except buying a noise filter from an aftermarket source Remove engine harness and install braided noise sheilding on TPS wires from TPS to PCM and on Trans control wires from Trans to PCM. (this precludes the need for a noise filter since the braided sheilding prevents the noise from entering the wires intially) Ground PCM case w/ 8awg fine-strand cable to negative battery ground Replace Ground cables on battery Replace Gov Press sensor and Gov solenoid Replace trans fluid and filter Replace Output shaft speed sensor Remanufacture PCM Rebuild Generator. my Gov sensor/solenoid were faulty and that got my PCM out of limp and allowed it to shift normally. however, nighttime driving made the TC lockup, OD/D shifting problem apparant. i knew it was dependant on electrical load since it only happened at night, when running the lighting increased the Generator load dramatically. turns out the brush in the generator was worn down to the shoe and was arcing out on the armature. this acring created RFI which was introduced into the harness and the PCM via inductance. replacing this brush (even though my truck produced 14v while running and showed no evident signs of failure) solved my shifting problems 100% . my truck is now shifts as strongly, predictably and reliably as it did when it first rolled of the Lot. Moral of the story; REBUILD YOUR GENERATOR FIRST, before buying ANYTHING else.
`97 12v 2500, STD cab, 12v, #100 plate, tweaked AFC, Tabbed KDP, 4" FBD exh, BHAF, Built 47RE/VB/DTT 89% TC, 2wd, 3rd Gen Rims, 3.55's, PSI/Trans/EGT guages... And a `97 Dually "Handshaker"! Last edited by flubyux2 : 09-14-2007 at 09:49 PM. |
