Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 06-18-2008, 07:06 AM   #13 (permalink)
DART505's Avatar
Pump is 6 months old,I do not have the SN handy. I think I will blow back the siphon to see if it's strainer is partially restricted.Where is the bypass located in this pump?
2001 D2500 2x4
http://community.webshots.com/user/dart505
DART505 is offline
Old 06-18-2008, 07:22 AM   #14 (permalink)
Its internal and not servicable unless you cut the wire. This is not really an issue unless you got real crazy with the teflon tape or didnt use our prestrainer. That is about the only time I see issue with debris that causes pressure probs.
Diesel-Dan is offline
Old 06-18-2008, 07:30 AM   #15 (permalink)
DART505's Avatar
I use liquid sealer spairingly.I did have a actual filter on it for a month with 50 micron filter before I learned that you needed just a strainer 140 micron type.
2001 D2500 2x4
DART505 is offline
Old 06-19-2008, 05:31 AM   #16 (permalink)
DART505's Avatar
Well used high pressure to backflush the siphon tube and still no luck.If you have it in neutral with the box on #3 stick it to the floor real quick & let off 10 psi is what it drops to.
2001 D2500 2x4
DART505 is offline
Old 06-23-2008, 08:44 AM   #17 (permalink)
Have you tried the 5 gallon bucket test yet or sucking out of a jar of fuel?
If your suciton tube has a crack in it....blowing air back in the line will not do anything for you.....
Old 06-23-2008, 09:13 AM   #18 (permalink)
DART505's Avatar
I have not done the bucket test,guess that is next.
2001 D2500 2x4
DART505 is offline
Old 06-28-2008, 11:14 PM   #19 (permalink)
RednecknDesigns's Avatar
I just installed a fass 150 4 weeks ago pressure was reading 16 all the time with a 1 to 2 psi drop when i hogged on it and now it is reading 5 all the time. What might be the problem? it didnt drop all together, it dropped like 2 1/2 psi per day. Now steady at 5. Please help.
2006 CTD, S&B intake, 5" custom turbo back duals with 7" tips, BD wastegate, Smarty, DiPricol Gauges, FASS 150, SBDD 3600, 6" Tough Country lift, Diamo 20x10's w/ Mickey Thompson ATZ 35x13.50, more Cummin
RednecknDesigns is offline
Old 06-29-2008, 10:03 PM   #20 (permalink)
FTE Diesel
JacktheBear3's Avatar
Most likely your gauge set up..... have you checked it?
We installed a FASS 150/150 Friday, the gauge set up was not touched.... It read only 7-8 PSI after install and bleed session.
After we re-primed the gauge side of the isolator the truck showed 17PSI
2002 24V, 2500 Quad Cab, Dark Silver, We Bit O Lift, Plain Jane, Comp (drag), BDRAD, Smarty Stack, F1 Mach 7.?, The Girlz are T61 & S400, PDR Stg III Head w/Rings top & bottom, HTS/FTE FULL billet Auto, SS Single Converter, Optix Gauges ( all high #'s), Detroit Locker, Custom 6" Miters, and plenty O junk in the Trunk...
JacktheBear3 is offline
Old 06-29-2008, 10:12 PM   #21 (permalink)
Thanks I will try that this week.
Old 06-30-2008, 08:14 AM   #22 (permalink)
Im guessing we have an isolator inbetween the gague and fuel??? If so, rebleed the isolator and see what your pressure does.....
Im with Wally on this one....
Old 07-05-2008, 05:20 PM   #23 (permalink)
dukeboy_318's Avatar
hey diesel dan, im trying to find out which pump is under my brothers truck, it was on there when he bought it, serial number is 00874. its is the stand alone pump. thanks.
99 Ram 2500 Cummins , 5 spd manual with dual disk sb clutch, 4x4, K&N stage 2 intake, 4 inch straight pipe , Edge juice w/ Attitude. 150 hp injectors, 2 inch leveling kit, 305/70/16 BFG All-terrain tires
dukeboy_318 is offline
Old 07-07-2008, 07:15 AM   #24 (permalink)
HPFP SN: 874.
It was built 6-21-05 and Dave's Diesel was the dealer. I show that to be a 95 GPH unit.
You can further tell by looking at the Motor block (The block that directly attaches to the Motor). It will have an "A" or a "B" stamped in it. With the motor you have:
A = 150 GPH (.625" Gear)
B = 95 GPH (.335" Gear)
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
