Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 07-19-2006, 06:55 AM   #1 (permalink)
Administrator
Andy's Avatar
Do I remove the old fuel lines?
Hey Dan,
Just installed one of your systems...LOVE IT! One question, do I remove the old fuel line or lift pump?
Thanks,
Lem
Forum Administrator
www.cumminsforum.com
Help Support CumminsForum.com by upgrading to Premium Membership
The Diesel Journal
2002 2500 4WD Ext. Cab Long Bed Edge Hot Juice w/Attitude, DynoMite Diesel Injectors, AFE Stage 2, FASS, NADP Torque Converter & Valve Body, MBRP 4" Turbo Back, Line-X Spray on Bedliner, Access Roll Up Cover, BD Twin Turbos, Diesel Dynamics Camshaft
Andy is offline
Old 07-19-2006, 07:15 AM   #2 (permalink)
old lift pump
to remove the old lift pump i removed the electrical connection and the fuel lines going in and out then the far right retainer nut. then the three nuts that hold it on and pull the lift pump out then put the new one the opposite way
aceisme is offline
Old 09-05-2006, 08:56 PM   #3 (permalink)
Administrator
Andy's Avatar
Didnt quite understand that answer.
Dan, can I remove the stock fuel filter assemly and lift pump? If so, what do I do with the electrical connections to the stock fuel filter assembly? Anything else I should know?
Thanks,
Lem
Forum Administrator
The Diesel Journal
Andy is offline
Old 09-05-2006, 09:01 PM   #4 (permalink)
If you are removing the stock fuel filter housing, keep in mind that will need to do something about a fuel heater. The stock heater is in the housing.
374.2/846.7 at 30psi
99 cummins is offline
Old 09-05-2006, 10:15 PM   #5 (permalink)
Administrator
Andy's Avatar
Does the FASS System address this already? If I'm bypassing the filter, the stock heater isnt helping me anyways, right?
Forum Administrator
The Diesel Journal
Andy is offline
Old 09-05-2006, 11:45 PM   #6 (permalink)
That is right. If you are not using the stock canister you do not have the heater. This is a bad thing in the colder weather.
Old 09-06-2006, 07:59 AM   #7 (permalink)
Administrator
Andy's Avatar
What would be the best solution for me then?
Forum Administrator
The Diesel Journal
Andy is offline
Old 09-06-2006, 01:41 PM   #8 (permalink)
HOW in the world did the FASS search miss this one? I guess no one used FASS until yesterday......haha....funny.....
Andy...talked to you today. AND to put it in public fomat.....yes....you can remove the stock filter houseing with the 98.5-02 Dodge kits. AND you can take out the stock lift pump...but leave the bracket to keep from leaking oil everywhere. The 03 and up, you can remove the housing, but you need to address the fuel return that runs through the filter head. Not hard....but some fittings an hose can be made to work.
Unless you are exposed to sub-zero temps 90% of the winter (Or maybe the extreme North states)....dont worry about the fuel heater....run additives when it gets cold.
Diesel-Dan is offline
Old 09-06-2006, 09:17 PM   #9 (permalink)
Administrator
Andy's Avatar
Thanks a ton Dan! I did it. I also taped the sensor connectors up so that moisture wont get inside. Looks a lot cleaner and I have more room around my engine now!
Thanks again. The FASS is working out GREAT for me. Really glad I made the move.
Forum Administrator
The Diesel Journal
Andy is offline
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
