Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 03-18-2008, 06:28 PM   #1 (permalink)
keep losing power to FASS 150
i bought my 01 ram 2500 with a fass 150 hpfp on it and it keeps losing power through the terminals on the battery. is there any way to get a more reliable power source that isnt going to corrode and stop getting ground/power like it does on the terminals.
josborn93pgt is offline   Reply With Quote
Old 03-18-2008, 06:45 PM   #2 (permalink)
Super Duper Moderator & Ontario Chapter VP
Ruckuz's Avatar
Thread moved to FASS Forum.
1996 2500 4X4 Auto CC LB Banks Power Pack, Boost, Pyro & Oil Temp, 3k GSK, BHAF, #0 Plate Full Forward, Low Stall Triple Disc TC, TST Valve Body, Mystery Switch, Rancho RS9000's, MTX MZS1204'2/Alpine MRD M501, Viper Alarm & Remote Start, Dual 5" Grand Rock Turnouts, Rickson 19.5"s, and lots of stuff to make her look good.
Ruckuz is offline   Reply With Quote
Old 03-19-2008, 07:10 AM   #3 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
You can ground to the engine and then tap for power at the fuse box.
BUT i can say this is not a prob i see alot of. Might give your posts a good clean with water and baking soda and spray with some corrosion inhibitor.
Diesel-Dan is offline   Reply With Quote
Old 03-19-2008, 08:33 AM   #4 (permalink)
where would i tap for power at the fuse box?
Old 03-19-2008, 08:38 AM   #5 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
You got two lugs.....one black and one red. They are both hot. You pick.
Old 03-19-2008, 08:38 AM   #6 (permalink)
Dad
Administrator
Dad's Avatar
Foreware - the fuse box under the hood (behind the drivers side battery) has a big black cable and a big red cable connecting it.
They are BOTH HOT. The black is not a ground.
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune
Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's
Dad is offline   Reply With Quote
Old 03-19-2008, 08:40 AM   #7 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
CORRECT!!!! DO NOT CONNECT THE GND WIRE OF OUR HARNESS TO THE BLACK CABLE. GND TO THE ENGINE ONLY!!! OR YOU WILL FRY YOUR STOCK HARNESS.
Old 03-19-2008, 09:03 AM   #8 (permalink)
MOPAR MAN's Avatar
Fill out your sig. If you have a edge unit or are running a turbo timer i think you should get your power from the # 9 fuse so the FASS keeps running as long as the motor stays running. I may be wrong but thats just my .02
00 Ram 2500 4x4 5-SPD, AirForce One Performance CAI & Intake Horn, 5" TB Exhaust, Edge Juce W/Atitude (HOT), Custom GT3788R Dual B.B. turbo, 120HP EDM Injectors, FASS 150/150, H.O. VP44, 7" Lift, ValAir DD Clutch, Fluidamper, & more to come
MOPAR MAN is offline   Reply With Quote
Old 03-19-2008, 09:07 AM   #9 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
FASS takes its trigger for the realy off the stock lift pump circut. SO it should still run if the turbo timer keeps #9 fuse hot......
Old 03-19-2008, 04:42 PM   #10 (permalink)
i have a edge EZ. so just run my red wire into my #9 fuse under the hood? and could i just ground my ground on the body of the truck somewhere?
01 2500-edge EZ,FASS 150 hpfp, 4 in. SS turbo back magnaflow, S&B cai, super dark windows,2in. leveling kit
Old 03-19-2008, 04:49 PM   #11 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
No.....the Red wire on our harness needs 100% power all the time. So you have to attach to one of the lugs at the UNDERHOOD fuse box. If you pop the lid you will see them. This is getting over complicated.......
JUST make sure you ground the GREEN wire to the engine or neg batt post....NOT the fuse box.
Might i suggest that if you are having a hard time understanding this you look for local help to hook this up. Its not difficult but if done incorrectly, it can cause damage to your stock engine harness.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
