Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 01-18-2008, 06:40 PM   #1 (permalink)
tatkins85's Avatar
Need help on the install please!
ok i just installed my fass and havnt started it yet but realized that on this step "Disconnect factory fuel line from inlet side of the factory injection pump and
install the injection pump o’ring fuel fitting into this inlet port. (Note: This is
where the suction fuel line from the fuel filter enters the injection pump.) As
seen in photo 4A & 4B. Torque to 18ft lbs." it never tells me what do do with the factory fuel line or the factory fuel system? if i just leave it there wont it just spray all over the place?
06 quad cab cummins, Manifold's, Air Intake, Big Turbo, big nozzles, Big cp3, Single Stack, Smarty, Nitrous, Gauges, Studs, Springs, Big Fass, Built Trans.
tatkins85 is online now   Reply With Quote
Old 01-19-2008, 07:53 AM   #2 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Nope.....you disable the stock fuel pump with the WH-1004 Harness (The one with the relay), or by cutting the gnd wire for the intank pump depending on how new your system is. You can just cover and bag the lines up if you wish.
Diesel-Dan is offline   Reply With Quote
Old 01-19-2008, 08:55 AM   #3 (permalink)
tatkins85's Avatar
ok but i dont think my syock 1 is disabled beacuse the harness i was suplied only ran from my battery to a built on fuse it had then 2 the fass? nothing else was on the switch. if i have 2 cut the wire then will that throw a code in my cab? and if not then can u explain a little more what wire 2 cut so i dont cut the wrong one? thanks
Old 01-19-2008, 09:58 AM   #4 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
This should be covered in the directions. You should cut (or removed the pin out of the connector if you wish) back at the tank. Its going to be one of the heavy gauge wires on the out side of the plug. Pin #1. This wire is going to be black with an orange tracer if i recall correctly. This is the gnd wire. As long as you have the 12+ wire hooked up to the in-tank pump, it will not pop a code. (The positive wire is going to be at Pin #4 location.)
Old 01-19-2008, 10:59 AM   #5 (permalink)
tatkins85's Avatar
in the directions i was suplied it tells me to plug something into that then plug the other behind it but my kit didnt come with anything to plug into the harness? so i guess i need to cut the wire. so im cutting the positive wire in the harned thats pluged into the fuel tank and it should be black and orange?
Old 01-21-2008, 06:39 AM   #6 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
In the instructions....what is the part number of the harness that says should be in there?
In your kit....what is the part number of the harness that was included....should be on a white tag.
Old 01-21-2008, 02:11 PM   #7 (permalink)
tatkins85's Avatar
dont worry about it dan thanks 4 your help thow. my buddy cam down and just connected all the electrical to the factory one. so it works good now. ill get that spring ordered and i should be set
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
