Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 01-15-2008, 10:07 PM   #1 (permalink)
tatkins85's Avatar
Where do i bolt up the fass system?
hey guys i cant find a spot under my cab to bolt up my fass it wont fit anywhere? any spot that looks good ill try but the top of the fass will hit the top of the bed before the holes will line up on the brackets i have an 01/02/06 made dodge 2500 shortbed cummins where do i put this thing? the fass us the 95/150.
06 quad cab cummins, Manifold's, Air Intake, Big Turbo, big nozzles, Big cp3, Single Stack, Smarty, Nitrous, Gauges, Studs, Springs, Big Fass, Built Trans.
tatkins85 is offline   Reply With Quote
Old 01-17-2008, 07:43 AM   #2 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Short beds are the hardest of the trucks to get a FASS installed. AND also the hardest for me to explain as well.
I know the frame bracket needs to be attached to the cab mount, not the bed mount. If you need to trim the end of the bracket to clear the spring, that is fine. My suggestion is to get the frame bracket as low as you but will still bolt up. Use vice-grips to gauge where you need to put it.
I might have to wait until our 2wd short bed shop truck gets here. I can go out and look at it for reference. It, too, has a 95 Series on it.....so that should be a good comparison.
Ill post more later.....
Diesel-Dan is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
