| Diesel Performance Products (FASS) Home of Diesel Performance Products |
#2 (permalink) |
FASS Tech Dept.
Check for power coming out of the stock harness. Make sure you are not getting a signal from the ECM. If no power, check the relay and make sure its not stuck. That can happen every once and a while. You can check it with a relay out of the fuse box. If you are getting power from the ECM when the key is cracked.....you might have issues beyond what i can help you with!! haha.... This is a weird one......but i would think that the relay is stuck on...that is my guess right now...... EDIT.....DUAH...if the relay stuck....it would run all the time........haha...next day after some sleep....
Dan MacDonald www.FASSRide.com 2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp, Currently running on B-100 '02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG Last edited by Diesel-Dan : 05-09-2006 at 07:54 AM. |
#3 (permalink) |
Tech Specialist
I just remembered....There is a TSB out for the 03's that involves a re-flash that keeps the lift pump running at key on. It is suppose to fix the hard starts that the 03/04 guys were seeing once they had the in-tank lift pump retrofit done. I guess the usual 2 seconds of run time wasn't enough to get fuel to the CP3 when the pump was located at the rear of the truck. I had the re-flash done to my truck and really liked it. During the winter when I used my autostart, it kept the lift pump running during the 20 seconds or so delay my auto start had for the grid heater. It didn't run "forever" though. Eventually it would cut off. Since it is a software re-flash, the latest BullyDog software may have it incorporated. On edit: TSB 18-017-05, Flash: Long Crank Times
03, 4X4, QUAD, LWB, Standard Output, 47RE, 3.73, ATS TC/VB, DTT Trans/Billet, Flex Plate, TorqLoc, RAD, Twins, Snow, Hot Cp3, Injectors, Cam, 315s, 8,200 lbs wet. 12.32 @ 109 Videos: Vid 1 & Vid 2 Add yourself to the Cummins Forum Map. Last edited by AK RAM : 05-08-2006 at 04:53 PM. |
#4 (permalink) |
FASS Tech Dept.
Well there you go......One of Brads trucks (The shop truck) takes a whie to crank...its an '05....so that makes sence.....(AND that is the truck without a FASS!......its going bye bye in a few anyway for a 06.)
Dan MacDonald www.FASSRide.com 2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp, Currently running on B-100 '02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG |
#5 (permalink) |
Posts: n/a
Well its definatly getting the signal to run from the ecm since the relay is hooked direct to the battery per instructions, I had heard of that tsb but found no sticker indicating it had been done on the truck.....................this all makes sense now cuz before i installed the BDDL I primed the FASS and got that all lookin good and at the time the key on made the pump run for the 5 seconds and a bump gave it the 25 seconds, then I did the BDDL and the pump runs all the time with key on so the program must be in the downloader........magic thanks for the info men I get more impressed every day! |
#6 (permalink) |
FASS Tech Dept.
Just a hint.....might want to unplug the HPFP when using the BDDL.....voltage drops can do funny things when trying to flash a truck. Just a suggestion......
#7 (permalink) | |
Posts: n/a
