Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 09-02-2008, 03:16 PM   #397 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by SootKing View Post
thanks, and why does my brothers 05 duramax with a fass 150 when he turns the key on the fuel pump stays on until he starts his truck. mine just clicks on for a second then i start my truck. why is that?
His pump is triggered off the fuse box and yours is ran by the ECM. D-max trucks have no lift pump circut, per se, to trigger off of.
Originally Posted by rhino 660 View Post
when i first turn my key my fass no longer primes for a few seconds, it only comes on when started now. checked relays and fuses....... fass 95 HPFP no filters
I wouldn't worry about it. If the pump runs when the engine comes on, its doing its thing. I would check the ECM trigger on the relay plug. Bump the engine and see if the pump will run.
also my wait to start light does not come on any more
You might have other issue going on there....might start checking fuses.
Originally Posted by bcollin3 View Post
If found the problem. Its the relay. It has been getting WAY TOO hot and has begun to melt the insulation off the wire, one of the red ones going or coming from it. When I gradded it to get a better look at it, the wire fell out in my hand. I fixed that part, only the relay still gets really hot when the pump is running. I think my relay is bad, and its almost like it is not big enough to handle the current going through it. How do I go about getting a new one from FASS? Is that covered under the warranty?
thanks,
We might check what amperage our pump is pulling. BUT if you had a loose connection at the relay plug, that could cause the overheating situation as well.
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline   Reply With Quote
Old 09-02-2008, 10:45 PM   #398 (permalink)
Random Acts's Avatar
Fass 150/150
Does the relay need to be mounted to metal so it's grounded? Or can it be mounted to a non grounded surface? I would like to tuck it and the wiring up and out of the way.
Question 2. I have an Isspro mechanical gauge with copper tube from the Injection pump to the gauge ( I have a Needle valve) I run about 13 - 14 pounds at idle, 10 on the highway and I can get it down to 6 or 7 pounds at WOT. So thats good enough but not much margin. My Carter was 10 11 pound at idle, 7 drving around and 3 to at WOT. Could my gauge be reading low? The pump is fairly quiet and I installed a vulcan draw straw when I installed the Fass.
99 2500 Banks Power Pack Isspro Fuel Pressure
BHAF Quadzilla XZT A Fass 150/150 Vulcan Draw Straw
Random Acts is offline   Reply With Quote
Old 09-02-2008, 11:00 PM   #399 (permalink)
Smash "n" Grap
BILLS06's Avatar
Draw straw that came w/ the 95. Does it adjust? I can't recall!!
06 QCSB Capped Rail Airaid Baffle Delete MagHytec Transmission Pan Aeroturbine Muffler Fluidampr Superchips Pyro/Boost & Autometer Ultra Lite Digital Oil Pressure & Transmission Temp Gauges ATS 5 Star TC Flexpiped CAT DDR Enabled Royal Purpled EZ Down Weston Nerf Bars Spray In Bed Liner Valley Gooseneck Hitch
http://www.myspace.com/montanadodge
BILLS06 is offline   Reply With Quote
Old 09-03-2008, 08:49 AM   #400 (permalink)
SootKing's Avatar
thanks man!
02 24 valve, 35" BFGs, fass 95, CoaltrainDiesel100's, laramie slt, banks jake brake, dark tint, ATS tranny pan, silencer ring?, Smarty, leveling kit, suncoast stage IV all billet by FLEECE PERFORMANCE, adrenaline, 8 in CAT stack
SootKing is offline   Reply With Quote
Old 09-03-2008, 11:06 AM   #401 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Relay doesnt need a gnd, its supplied when you hook up to the Batt with the Green wire.
I always suggest checking your gauge. Especally since you have used a way most dont use. Try running with the needle valve wide open. See what that does. ALSO might bleed any air in the line as well. Larger diameter line will hold more air and cause gauge error.
UM....not really. It they were set to a certian length. BUT they are mild steel so you can weld to them if needed. OR get another tube cut and tapped.
Dan MacDonald
www.FASSRide.com
Old 09-06-2008, 12:36 PM   #402 (permalink)
[quote=Diesel-Dan;826516]Relay doesnt need a gnd, its supplied when you hook up to the Batt with the Green wire./QUOTE] <- I screwed up something here
Hi Dan,
I bought my Fass used so I don't know if my wires are correct, but off the relay I have 2 green wires. One goes to the truck harness where the carter hooked up and the other runs down to the Fass. Am I missing a third green wire to go to ground? It looks like there is a space in the center of the relay connection where it could go.
Thanks for your help, You da Man Dan
Old 09-06-2008, 04:12 PM   #403 (permalink)
neilden's Avatar
did i send in my warranty card? and if not what can i do to get it warrantied. her are my numbers fass 150 14552 pump 6792. purchased in january of 2008. i was on the other side of the country when i had it installed and cant remember if i ever sent in the warranty card or not.
99 CTD 3500 sport 4X4, carli suspension, edge juice w/attitude, suncoast transmission, Mag Hiteck deep pan, scotty II intake, straight pipe exhaust, FASS 95/150, Hot Rod VP44, Solid steel lower control arms, steering stabilizer, 3rd gen track and relocation bracket,
neilden is offline   Reply With Quote
Old 09-08-2008, 03:58 PM   #404 (permalink)
Bump for Answer to Question
[quote=Random Acts;833010]
Hi Dan,
Old 09-10-2008, 04:44 PM   #405 (permalink)
Talking 95 install questions
Hey guys,
Well I installed for 10 hours the other day with the directions that dont exactly relate to "MY" truck.. nonetheless I kinda figured things out with basic knowledge of things...
Anyhow, a few last things remain...
1.) I have the stock wiring harness plugged into the stock in-tank lift pump. Should there be a cut wire or something to STOP the stock lift pump from working, YET continue to give me a read on fuel level in tank???
2.) What exact fuse should I be tapping into? I tapped into the ACC , IGN power fuse (20amp) and well, because I have the edge turbo timer thing.. all runs until engine shuts off but fass95 continues to run until front doors are open.. (it keeps the acc powered until doors open, so I worry that the pump could run with the acc powered for like 10 minutes.) (no need to excessively run and recirc fuel into return if it can be helped) right(?)
Thanks for the help!
and yes I notice a smoother get up and go, idle, etc.. good stuff!!!
2008 3500 4x4 White laramie QB LB - Love this Truck - 2.5" level kit, 35" BFG AT's on 18" ALum., Step tubes, Edge with Juice n probe, FASS 95, Bardo hot rod logo. DPF 4" and EGR delete. Thanks K2dieselperformance.com
robbyblv is offline   Reply With Quote
Old 09-10-2008, 05:00 PM   #406 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Hi Dan,
I got nothing on this number....show dealer being Industrial Injection......build date was 1-7-08......
Originally Posted by robbyblv View Post
Hey guys,
GUYS...i dont know why it waits until i get like 5 post and then shoots me an e-mail....SORRY!
BUT im super busy right now building pumps....ill post up here when i catch my breath if you dont mind...might be tom morn.....or later tonight.....thanks!
Dan MacDonald
www.FASSRide.com
Old 09-10-2008, 05:10 PM   #407 (permalink)
Smile thanks
Thanks Dan! Im looking forward to your response....
ps.. a quick pointer to the additional goodies to plug into the fass unit would be nice! ie: psi gauge and heater stuff...
Old 09-10-2008, 05:11 PM   #408 (permalink)
mopower
slateHD's Avatar
dan, i'm sorry i know this is the wrong place but, i need some filters.
2004.5 CTD, mineral grey HD, MKW-M19's w/305/55/20 toyo open country at's, AFE stage 2 w/amsoil nano, silencer ring MIA, str8 thru exh. w/5" tip, edge "HOT" juice w/att & turbo timer, smarty revo-hehehe, ATS valvebody/torque converter, fass150/150, optix trans temp/fuel press.
slateHD is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
