Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 01-03-2008, 05:42 AM   #25 (permalink)
Hello, I am kindve new to this site, but I joined because I really have a problem that needs fixed with my truck... I have the Fass 150, along with a 9 month old Injection pump, 150 hp injectors, and superchips - edge comp. stacked.... What is happening is the truck runs fine at idle and at minimal throttle, but when I start into about half throttle or so when the truck is out of first gear and higher rpm's and boost (using more fuel) the truck starts to flutter like its starved for fuel... I thought it was the filters so I changed those.... that didn't fix it.... so I went to Columbus Diesel Supply where I got the pump and got a different spring to put in the pump to raise the pressure.... and that as well did not fix my problem... I kind've have an idea of what it could be but I just thought I would see if anybody has ever had those symptoms. I believe it could be my STOCK draw tube either too small, or clogged up.... any suggestions would be appreciated! Thanks, Matt
mrl64 is offline   Reply With Quote
Old 01-03-2008, 08:13 AM   #26 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Whats your fuel pressure comming from the FASS.....Idle? WOT?
Diesel-Dan is offline   Reply With Quote
Old 01-03-2008, 09:18 AM   #27 (permalink)
i have a fass 150/150
what are the part numbers for the filters
a different spring came with my pump, what will the pressure be if i change to this spring
thanks
daniel
'07 5.9, g56, magnaflow muffler, no cat, cummins cool hose,autometer phantom II pyro, boost, and FP, dipricol RP, smarty beta 4.2, street screamer 62/24, quadzilla boost fooler, SB dual disk, FASS 150/150, CFM+ intake 491 rwhp 894 torque
gomer pyle is offline   Reply With Quote
Old 01-03-2008, 09:31 AM   #28 (permalink)
kalkhokm's Avatar
that is a common issue when stacking the edge comp and superchips, especially if there is timing involved in both. get rid of the superchips and buy a smarty to run on the FUEL ONLY settings
99' 2500 4x4 Ext. Cab 2" Leveling Kit, 6" Stack, BHAF, 7x.012 EDM's, .093 tubes, Adrenaline, Prostreet 66/14/71, BD exh. man., icebox boots, Fass 150/150, guages, Goerend triple disk, billet input shaft/flexplate, suncoast vb
kalkhokm is offline   Reply With Quote
Old 01-03-2008, 10:11 AM   #29 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
Good catch on that one...i totaly missed that stack.....
Old 01-03-2008, 12:48 PM   #30 (permalink)
Dan, I am in the proccess of getting a fuel guage on my truck to have a better understanding of whats going on with the system. I only have boost/pyro/trans. temp on there right now so I am unable to give you the numbers, but as soon as I have them I will let you know because I am stumped!! Thanks, Matt
hmmmm...... that is so funny because I have talked to many diesel performance places and nobody has said that it wasn't good to stack those two together?? Where do I buy a smarty at? Thanks, Matt
p.s. I am already finding this place to be very helpful!
Old 01-03-2008, 12:53 PM   #31 (permalink)
Dfer10's Avatar
you can get a smarty on here used or new from several vendors
MADS Electronics - Smarty - CaTCHER - Distributors
2006 Mega 6" lift 37's on 20's. 6" Stacks. 4:10's. Smarty. FASS 150/150 Turbo
Dfer10 is offline   Reply With Quote
Old 01-03-2008, 04:21 PM   #32 (permalink)
kalkhokm's Avatar
my friend had that stack on his truck and it would spit and sputter real bad under hard acceleration...too much timing b/n the superchips and comp
there are always smarty's popping up for sale b/n the many diesel forums. you could also sell your stack and try to get your hands on an adrenaline - similar to the smarty/drag comp stack w/ a lot of cool features (turbo timer, defueling, ect.)
Old 01-03-2008, 04:25 PM   #33 (permalink)
kalkhokm's Avatar
check out quadzilla's website
Diesel Performance | Quadzilla Performance | Diesel Truck
read up on the adrenaline
Old 01-04-2008, 02:36 PM   #34 (permalink)
FASS Tech Dept.
Diesel-Dan's Avatar
thanks
daniel
FASS 150 Filters:
FASS - Fuel Air Separation System - fassride.com
Just toss the spring....its no good to you with a 150 GPH kit.....it was a misprint in our mounting package instructions that caused it to be included in the kit.
Old 01-04-2008, 09:10 PM   #35 (permalink)
ropnjessi's Avatar
What the install time on the FASS HPFP 150 (no filters)? (03 dually)?
03' Dually 4 x 4, 4" exhaust
HTB2/62/12, CFM+, AFE Torque Tube
FASS 150, Stage 1 cold air box
Smarty/Puc(60hp),stack/TST-6/0
Goerend Trans.
Westach Combo Gauge. 51" Donaldson
ropnjessi is offline   Reply With Quote
Old 01-05-2008, 05:26 AM   #36 (permalink)
shambo's Avatar
Bump
Dan,
Is that what I should do?
Originally Posted by shambo View Post
Dan,
I'm the Guy Kurt at Diesel Specialist spoke to you about a few weeks ago. thanks for promtly sending out the new pump everything works well. I'm getting 18 PSI out of your pump. ( hooked up a guage also) everything seems to be working well thanks again! Kurt told me that you never received the warrenty card in the mail. I can e-mail a copy of my receipt in PDF if that would work.
2003 3500, CTD HO, ZILLARAIDER ,SUPER CHIPS, AFE STAGE 2, BD-X FLOW, QUADZILLA COMMANDER, ARSON CP3 KIT, FASS 95/200-1007, 305/55-20 NITTO TERRA GRAPPLERS ON 8.5 GUNNER 8'S,
1/4 MILE RUN 15.144@88.58 MPH ,408 HP 792 TORQUE.
shambo is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
