Give Me Your Questions!!!! - Page 3 - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Performance Products (FASS)
Diesel Performance Products (FASS) Home of Diesel Performance Products
Old 10-30-2006, 12:12 PM   #25 (permalink)
Company Name
Diesel-Dan's Avatar
Originally Posted by Sick022500 View Post
Hey Dan,
I posted this question in another thread, then I found this one so I will ask the same here.
I ordered a FASS HPFP and I have a dealer installed in-tank lift pump. Do we need to bypass this pump, or do we connect to it on top of the tank without having to drop the tank and let the FASS suck through it?
You will need to do one of 2 things:
1. Get a stock sending module and reinstall it. (Which if you sweet talk your dealer, they might have a few just laying around waiting to be tossed in the trash)
2. Get a suction tube kit. STK-1001 for the 03-06 trucks and STK-1002 for the 94-02 trucks.
Either way.....tank needs to be dropped.....sorry!
Dan MacDonald
2002 TDI Jetta...stock for now
Diesel-Dan is offline
Old 10-31-2006, 01:44 PM   #26 (permalink)
BSouth's Avatar
I just installed my FASS 95/150 and my Hot Rod VP44. I'm only seeing 14psi at idle, have yet to have it WOT because my tranny isnt gonna hold. But I had been in the throttle kinda hard and it hasnt been below 12psi. I was hoping for more psi at idle then 14. I had better psi at idle with my stock lp. Also I can not get my water seperator filter to stop leaking. Ive had it off twice and the gasket/o ring looks to be in perfect shape. Not really wanting to buy a new filter since this one is brand new. Anybody else had this problem?
05 3500 Yellow 6 speed,Mega cab dually fenders,Rumble Bee Scoop,Smarty,CFM+,ATS Exhaust Mani,Silver 64,Airdog 150,Valair 3600 DD,5" Silverline exhaust,8" tip,Icebox with torque tube,Quad Rail Gauge,Mag-Hytecs,Lorenz Level, 22.5's
BSouth is offline
Old 10-31-2006, 01:54 PM   #27 (permalink)
Company Name
Diesel-Dan's Avatar
HUH....well if the Water Sep is leaking.....more than likely you are sucking air. This filter is on the suction side of the pump. Contact your selling dealer with your SN and have them call me. Double check the o-ring on the filter and make sure its pushed down all the way in its recess. Usally we see some fuel filters leak......WS we never see.
14 PSI is where we are setting these pumps up at now. Mine is at 14 and can pull it down to 11.5 WOT. This is fine. Will not hurt anything. VP's are not a hard pump to keep up with. The VP was set up to run at 14-15 PSI. YOu want more pressure, we have a spring that will put you up to 20 PSI if you want. Just let your dealer know its the "Old Style PS-1002 Spring". I think they are $3 IIRC........
Dan MacDonald
Old 10-31-2006, 01:59 PM   #28 (permalink)
BSouth's Avatar
Is more pressure going to hurt anything? If 14psi is standard then I guess it will be ok. I got the pump from Gus @ farmboys diesel. Is he the person I should be calling about the leak?
BSouth is offline
Old 10-31-2006, 02:23 PM   #29 (permalink)
Sick022500's Avatar
OK, we got the FASS HPFP installed. Gutted the in-tank pump and put in a suction line.
Now the fuel pressure readings are;
Commander at idle 9psi (before FASS it was 5)
Mechanical guage at idle 13psi (before FASS it was 9)
I feel more comfortable with the FASS, but still need the Commander issue settled.
02 2500 auto 4x4 quad cab California emissions, Quadzilla Commander, FASS HPFP (gutted the in-tank lift pump), MBRP 4" turbo back exhaust.
Sick022500 is offline
Old 10-31-2006, 03:18 PM   #30 (permalink)
Company Name
Diesel-Dan's Avatar
I would still try to draw fuel out of a bucket and see if you get any improvement...should be about 17-18 for an HPFP. Especially since you modded the intank pump set up, just to make sure you have no restriction (OR sucking air).
As far as how much pressure is too high on the VP.....MAN...its anybody’s guess. You can find 100 different answers on here about that. I think there is more speculation on this than who killed JFK!! BUT i have yet to see any hard core evidence that shows major pump failure at pressure 20+ PSI. I see people running VP's upwards of 30-40 with no issue and see people running them at 13 with TONS of issues.....so who knows!?!? We don’t build VP-44's. We just set up our pumps for what people want them. My personal specs on the range of the VP is 5 PSI to 25 PSI. I got mine set up to 14 PSI...that is about SMACK dab in the middle.....and reckon it'll work just fine.
Yeah….have Gus call me. Give him your SN number.
Dan MacDonald
Old 10-31-2006, 05:48 PM   #31 (permalink)
Sick022500's Avatar
Drove the truck home just now and got 12-13psi at 60mph, and it drops to 8-9 at idle. This is on the Commander. Before the FASS it was at 1-2psi at 60 mph and 4-5 at idle. Now I need to update my signature line
Old 11-02-2006, 10:43 AM   #32 (permalink)
BSouth's Avatar
Well cant get a hold of Gus tryed pm'n and callin. I have my serial # if u want it Dan. Let me know. Its still leakin.
Brian
BSouth is offline
Old 11-06-2006, 11:29 AM   #33 (permalink)
Company Name
Diesel-Dan's Avatar
PM Sent.....we will get this handled one way or another.......
Dan MacDonald
Old 01-08-2007, 10:08 AM   #34 (permalink)
Hey Dan I have a FASS 150/95-1006 on the truck in my sig. What should i see for fuel psi straight out of the box from you?
brad
2006 CTD crew cab 4x4 dually 6 speed 77,000 miles and ticking RokTek sensor, South Bend clutch, Amsoil EAAU 4090 filter with afe torq tube, B&W turnover ball, Quad Commander, FASS, Amsoil by-pass oil filter, straight piped, nasta s.s. nerf bars, Quad XZT, high idle
brad06ctd is offline
Old 01-08-2007, 10:12 AM   #35 (permalink)
PULN PWR's Avatar
Originally Posted by Diesel-Dan View Post
I want this space to be for YOU---The Cummins Forum User! Any FASS questions and problems i would love to be on here. SO this can help any with issues, looking to get info, and such. A FAQ Page of sorts.....so Please feel free to start any threads pertaining to FASS or the HPFP. HECK! I might even use some of yall to help me come up with better solutions to issues. Thanks to all in advance!
Dan
Which FASS set-up for 550-600rwhp?
Many thanks!
Chad
PULN PWR is offline
Old 01-08-2007, 10:28 AM   #36 (permalink)
Company Name
Diesel-Dan's Avatar
brad
13-14 PSI........BUT with that system, you can up the pressure as high as 80 psi (max) if you want.
Dan MacDonald
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
