| Diesel Performance Products (FASS) Home of Diesel Performance Products |
#121 (permalink) | |
1998.5 24 valve 5.9 Cummins - Quad cab 8ft bed 4X4 - FASS 150/95 - Areo Turbine exhaust - K&N intake - Mag-tec Hy-tec trans and diffs - 3rd Gen 17" rims and caps - Edge Comp Box - Various other mods
#122 (permalink) | |
FASS Tech Dept.
Between the 95 series and the 150 series, not much differance in performance. Both have the exact same pump options. The big differance is size. The 95 series is 25% smaller than the 150 series. The 150 series has filters you can cross to aftermarket sources. The 95 series you will need to contact a FASS dealer to get fuel filters as they are made just for us by Fleetguard. The water separator you can cross to a FG# FS19768 Number.
Dan MacDonald www.FASSRide.com 2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp, Currently running on B-100 '02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG |
#123 (permalink) | |
FASS Tech Dept.
#124 (permalink) | |
1999 Black quad cab, auto, CTD. 4" turbo back, Fass 150/95, S&B intake, Mag-Hytec pan and a SMARTY #9. No more Quadzilla Commander, good ol' fashioned mechanical ISSPRO gauges, and loving them!!! |
#125 (permalink) |
Colorado Chapter Pres
09323 thanks
99, QC short bed running the best of the best and proven to perform. A daily driver that gets 19+MPG and runs a 12.86 @ 104 mph 1/4Holland Court Diesel Your one stop Diesel SUPER SHOP 303-986-0330 Give us a call for the best of the best. Quality brand names with service you can trust all backed by nation wide warranties. Pureflow, Valair, BD power, DDP, HTT, Industrial injection, Dipricol, Quadzilla, S&B, Snow performance, Edge, Diamond eye, MBRP, PDR and more. We install what we sell
#126 (permalink) |
FASS Tech Dept.
I feel a snubber should be a standard item when installing a gauge. SO yes...i feel that would protect your gauge better, and would also restrict the flow of fuel if you ever had a leak on the gauge side so you would have less of a mess........ jbarker, You are good to go......got you on file.
#127 (permalink) |
Great thanks..I do not have a snubber as i have seen you post links to but i do have a needle valve installed in the line and i still get a slight tick at the gauge. would a snubber do a better job at making the gauge less noisy? John
#128 (permalink) | |
#129 (permalink) |
Diesel Dan i hear you are the man when it comes to FASS here is a few questions for you hopefully you can help me. I have a 2002 ram 3500 flatbed dually my lift pump is 100% dead the dealer wants to put a in tank pump in... i do have a warrentee that should cover this.. but im thinkin of just bightin' the bullet and goin fass. the questions i have are how hard is it to install, wiring, plumbing, etc. also because i have a hyraulic dump the hydraulic pump and resivoir are on the driverside frame rail where i think the fass should be mounted, i can not move the pump becasue of the way its hooked up can i still use a fass, also becasue its a dually my rear tires throw up alot of dirt sand snow salt that direction i imagine that that would not be good for the fass system. i have a block mounted lift pump right now, it is putting out 0 pressure and 0 volume how long its been like that who knows. do you feel that this system is the best setup for my truck or is there somthing else out there that i should look into? if it will work what would i need and what size let me know what you think please!
2002 Dodge 3500 4X4 cab chassis 24 valve automatic, flat bed/dump bed, full guages, smarty S-03, BHAF, MBRP 304 cool duals....Newbie to the diesel world and loving it!
#130 (permalink) |
01, whatever you do I would NOT let the dealer install an in tank pump. You're just asking for trouble there. As far as installation, if I can do it, anyone can. It's really not that difficult at all. Check out this link for an idea of what you'de be looking at ... Dodge Ramcharger Central - Cummins Diesel - Ram Truck - Power Wagon - Trail Duster - 4X4 - Plymouth - Chrysler - Mopar As far as where to mount it, The closer to the fuel tank I'd say the better, however I do know of a guy who mounted it up under his hood and he's getting good pressure. That's a big truck you've got there, you'll find a spot. Best of luck to ya !! Without a doubt the FASS is the way to go !!
#131 (permalink) |
im installing a fass for a 12 valve, how come theres nothing to plumb the injector return line, or the injection pump return line to the tank?
95 5sp 12V Cummins, No show...All go 06 CTD Laramie Auto. NewEnglandTurboDieselPower.Com |
#132 (permalink) | |
FASS Tech Dept.
