Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Nut Motorsports
Diesel Nut Motorsports Home of Diesel Nut Motorsports
Old 08-05-2009, 10:49 PM   #13 (permalink)
Scrappy,
7100's aren't a must have but they are a good performing shock that are valved for this type of application. There are lots of people running 2 or even 3 5100 shocks on custom lifts and its obviously not for performance, handling, off road abuse but for looks. The kit we're installing has a dual shock mount up front and the customer opted to get a great quality shock.
wait till you all see the rear done...
'04 Dodge 3500
silvrcummns is offline
Old 08-06-2009, 01:33 AM   #14 (permalink)
1SIKDZL's Avatar
We need more pics Jason!
03 CUMMINS
STOCK
RidinHighMotorsports
1SIKDZL is offline
Old 08-06-2009, 04:02 AM   #15 (permalink)
1slo_CR's Avatar
Looks like a great kit!! And the right crew for the job. Keep those pics coming!!
'6.5 RC Dually, 6-Spd, Dura Grapplers 285/75r17E, 62/71/13ss^S480, SBC 3600 DD 12CB Sprung, 62"Traction Bars, AD150, Flux 2.4's, TNT-R PoD, MP-8, Hamiltons, ARP's, Billet Pushrods, Floor It Stage3, 5" TB.. www.discounttire.com
1slo_CR is offline
Old 08-06-2009, 10:16 PM   #16 (permalink)
So, yesterday started off all bad. The shock spacers left WAY too much slop, like 3/8". Kelderman's solution - shim it with 1/2" washers. I don't think so! So, I grabbed some 1" aluminum rod and starting machining new spacers for both upper and lower mounts. Got about 10 hrs into it, but its worth it!
More Bad. Kelderman installed the wrong fittings in the rear bags. Said if we wanted them faster than ground it was on us. Like hell! We got them local and they said they would reimburse us.
Next, no mention in the instructs of where the sway bar links mount to. A little looking online and there are some brackets they didn't ship us. Then they say, no, on 3500 trucks you remove the overload snubber, drill out the hole and mount the sway bar links there. Not my first call, but ok.
Bilstien didn't send us mounting provisions for one of the 7100 resoivors. Talk about awesome!! Called em up, told them whas was going on, "They are on their way red label" was the answer I got towards the end of a 3-4 minute call. OUTSTANDING!!
Playin on the lathe
While I working on that, Kenny and my little brother (Jamie) worked on the rest of the mechanical stuff -
Jamie eyeballing the lower link
Kenny working on something constructive I am sure Its the rear track bar.
Today, we got the spacers installed and got the rest of the parts hung. Also added a BD steering box stabalizer kit. All we have left is some wiring and a trip to the alignment shop!
Tomorrow I have more pictures and hopefully a finished product.
Diesel Nut is offline
Old 08-08-2009, 06:00 PM   #17 (permalink)
Well it's almost done. Truck went to alignment shop and is back. Now it just needs the auto ride sensors mounted and wired in. Those dual compressor's sound awesome. Not high pitched and whiny but kinda deep, sounds like a big bomber airplane to me... Hopefully Jason will have more pics on Sunday or Monday
'04 Dodge 3500
Old 08-11-2009, 03:23 PM   #18 (permalink)
In response to the shock question - When using an air spring you rely much more on your shocks to control the bounce and rebound. With an air spring, you only have enough spring to support the weight currently on the spring, whereas with a traditional spring you have enough spring to support the vehicle and cargo. Even with the duals, the shocks do produce a decent amount of heat on our test drives, however we don't have the smoothest roads around our shop.
More pictures to come, but for now its back to work on our other projects.
Old 08-12-2009, 10:44 AM   #19 (permalink)
Compressor box completed and installed.
BD Steering Box Stabilizer
Little bit of a tight fit to get it off the rack with those 22.5's. I think we had about an inch and a half of clearance on the tires after we added the 1/4" wheel spacers to clear the wheels on the suspension.
And here it is, ready for the trip to the alignment shop!
I have to see where the rest of the pictures went. I know we have some of it after we got it back from the alignment shop and set up the auto ride control. Now the truck has 3 preset levels, 4", 6" and about 8". The picture above is about 4" of lift.
Old 08-13-2009, 12:01 AM   #20 (permalink)
that looks sick
2K 2500 4x4-16" ultra mako's w/35" hankooks, lvled, suncoast, hrvp, tst, towing twins by me, 200's, .093tubes, AD150, allthe gauges, afe, 5"exh.
J&T Diesel & Performance
whitebullet3 is offline
Old 08-13-2009, 09:44 AM   #21 (permalink)
K2DieselPerformance's Avatar
Wow...
-08 MC/68RFE 4x4- Built by:K2 Diesel, H&S, & Shibby Engineering
-09 QC/G56 4x4- Built by: K2 Diesel, H&S, & Shibby Engineering
K2DieselPerformance is offline
Old 08-13-2009, 11:21 AM   #22 (permalink)
Thanks guys! It was alot of work, but it came out amazing. And the ride quality was unreal! Even with the 22.5's it rode like a half ton!
Old 08-13-2009, 11:30 AM   #23 (permalink)
1SIKDZL's Avatar
Looks very nice Jason. Great work!!
03 CUMMINS
STOCK
1SIKDZL is offline
Old 08-13-2009, 11:42 AM   #24 (permalink)
HELP FIGHT CA SMOG REGS!
dezl's Avatar
How are the compressors mounted to the box?
http://www.petitiononline.com/8484/petition.html
08 Chevy LMM 6" lift 20" monsters w/35's, other than that all stock.
69 Chevelle, big motor and bad brakes
dezl is offline
