Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Diesel Auto Power
Diesel Auto Power Diesel Auto Power
Old 10-25-2009, 11:05 PM   #1 (permalink)
Cummins Crazy
Cummins6speed's Avatar
D-tech turbo group buy
This group buy is sponsored by Jacob here for some great deals on either a d-tech 62/65/12 or 64/65/12.
I contacted Jacob about doing a group buy because I am going to want to upgrade my stocker for the twins and I saw some other guys looking into 62's as well and here is what Jacob told me he can do:
62mm s300 $978/ $899 shipped after rebate to 48 states (add downpipe and clamp for $140) (add $49 for intercooler boot for 2nd gen trucks) HX40 or HE351 flange
64mm s300 $1195/ $1099 shipped after rebate to 48 states (add downpipe and clamp for $140) (add $49 for intercooler boot for 2nd gen trucks) HX40 or HE351 flange
Other options are:
Borg Warner Turbos
s300g 57/65/14 for $1039/ $955 shipped after rebate to 48 states HX40 flange & 2nd gen turbo outlet only
BD superB special style turbo 64/71/14 for $1418/ $1304 shipped after rebate to 48 states (no downpipe/ HX40 flange & 2nd gen turbo outlet only)
Those that want 1st gen downpipe and flanges they will be available for $239 shipped after rebate with purchase of a turbo.
If you want on the list let me know. If you have any questions feel free to ask, if I can't answer it I will direct you to Jacob.
We need to get at least 6 turbos, it doesn't matter which one you want we need a combination of any 6 to get the group buy price.
Jacob would like to get the first order shipped by around the 15th
My truck: 06 5.9 G56 4x4 Quad Cab Short Bed Patriot Blue. Smarty TNT, Valair 3600DD, DiPricol's, Home made intake w/ amsoil filter, Straight Piped w/ 7" tip, silencer ring MIA, glove box sticker MIA 2/28/09-470hp/980tq
IBEW 551-PACIFIC COAST DIESEL
Cummins6speed is offline   Reply With Quote
Old 10-25-2009, 11:41 PM   #2 (permalink)
Deanson's Avatar
so that meen we could get any combo of wheel sizes? for example.....62/65/14 ......62/71/14? or are they all going to be 12cm housings?
1997 Dodge Ram 3500 3k GSK, custom plate, 80hp Injectors, Laser cut DV's,16.5*, ARP 12mm studs, Custom Cold Air , 5" TBE Dual Exhaust, TCS Triple Disk, DTS Tranny, 35's , Leveled, HE351/S400 Twins , Flex-a-lite fans
Deanson is offline   Reply With Quote
Old 10-25-2009, 11:42 PM   #3 (permalink)
Cummins Crazy
d-tech turbo's only come in 62/65/12 or 64/65/12
Old 10-26-2009, 12:18 AM   #4 (permalink)
Deanson's Avatar
wastegated i hope?
Old 10-26-2009, 12:20 AM   #5 (permalink)
Cummins Crazy
Yes they are wastegated.
Here is the 62:
HTB2 Turbo or Phat Shaft - D-Tech Turbo Diesel Power Source
It is an s300 base I do believe.
Old 10-26-2009, 12:39 AM   #6 (permalink)
RAMBUNCTIOUS's Avatar
already ordered mine(62), should be here on TUES.
Now I am curious about the downpipe and such, Diesel Power place told me its direct bolt in??? just pull the 2 pins out of the stock turbo elbow ?
I will subscribe to this thread and update when I get mine installed.. with pics and such. maybe videos.
2003 2500 SO, SRW, SB, QC, NV-4500, 4X2,185k miles, SMARTY, ISSPRO'D, FASS150/95, VALAIR, Dtech 62/65/12
"1 SLW CR"
RAMBUNCTIOUS is offline   Reply With Quote
Old 10-26-2009, 12:41 AM   #7 (permalink)
Cummins Crazy
It is a direct fit. Just put your cast elbow on the back of it (as long as you get the 3rd gen style)
Old 10-26-2009, 12:45 AM   #8 (permalink)
Posting Suspended
Here is the 62:
Correct me if I am wrong... I know nothing about turbos... but it says on their site good for up to 430 hp. Isn't that a little small? Or is this just for a twin setup?
JDiepstra is offline   Reply With Quote
Old 10-26-2009, 06:14 PM   #9 (permalink)
SmokinRamMike's Avatar
what is the 64/65/12 good for HP wise and how long will this group buy be available for?
P.S. Are these downpipes HX40 Style?
Semper Gumby
SmokinRamMike is offline   Reply With Quote
Old 10-26-2009, 07:46 PM   #10 (permalink)
I was wondering about this to, since I am currently at 446hp. Diesel power told me that they did not want the 700hp trucks installing them and expecting them to last. or something along those lines.
Mine should be here tomo, and installed before the weekend.
"1 SLW CR"
Old 10-26-2009, 08:02 PM   #11 (permalink)
Cummins Crazy
Im going to be using it in a twins setup so it should make a lot more than 430hp. If an HE351 can make over 500hp Im sure this turbo can make more than that. This turbo is nothing but an s362.
I think they are just underrated
Here is the compressor map for the 62:
Old 10-26-2009, 08:19 PM   #12 (permalink)
Diesel Auto Power
jkidd's Avatar
Hi all,
I have been running one of these turbos for over a year, they spool almost as fast as a superB but flow more. You can run them over 430HP but you may not have the 1 year warranty. Most of you know that a truck with an hx35 can make more than 300HP but its not really efficient, the 430HP is a conservative # like that. If you are over 430HP you will want to consider the 64/65/12 which uses the same efficient ETT 64.5mm compressor wheel that is on the HTT, II and BD turbos.
For those of you who want a SuperB style s300G turbo or SuperB Special style 64/71/14 I will Have Cummins6speed put prices for those in the first post.
Reminder that the 62/65/12 and 64/65/12 turbos come in hx40 or HE351 exhaust outlet and 3rd gen style compressor outlet only. The exhaust housings can be interchanged with a 14cm or 13ss for 65mm wheel. Those using it on a 1st or 2nd gen intercooled truck will need to add $49 for the intercooler boot
If you want your turbo to last you WILL:
1. Use a turbo properly sized for your application and HP
2. Not cook it with high EGT or forgetting to cool it down to 350
2. Not run your engine with dirty oil (turbos are very susceptable to oil contamination.
3. Not run the snot out of it by overspin/overboosting it.
www.DieselAutoPower.com Call Jacob at 951-377-4844 for best pricing
SUPER DEALS on Injection pumps, Turbos, Injectors & Programmers
SUMMER SPECIAL--8% off after REBATE(up to $200 off per transaction.)
When you buy from me on Ebay and pay with paypal you will receive an 8% rebate from Ebay in 60 days.
Call me for rebate coupon code or questions.
Example: Buy VP44 for $1000- 8% Rebate of $80= $920 after rebate
jkidd is offline   Reply With Quote
The Following User Says Thank You to jkidd For This Useful Post:
Cummins6speed (10-26-2009)
