Traction bars and wheelbase ???? - Dodge Cummins Diesel Forum
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
post #1 of 21 (permalink) Old 07-27-2008, 03:38 PM Thread Starter
I have 143.5" wheelbase. How long should my traction bars be? Is there any type of formula for this? Thanks in advance!
H82LOSE is offline
post #2 of 21 (permalink) Old 07-27-2008, 09:26 PM
Compcowboy's Avatar
I believe it needs to follow the same angle as the driveline, you will have to figure the math on that, it all depends on your connection point on the rearend.
Sold - 07.5 6.7 Big Horn with lots of goodies.
New Project - 84 Chevy CCSB 12v Conversion, G56 w/271 transfer case, Custom 4 link Coil Over Suspension and much more!!!!!
Compcowboy is offline
post #3 of 21 (permalink) Old 07-28-2008, 05:44 PM Thread Starter
I was thinking that, just looking for a few different opinions. Thanks Cowboy
H82LOSE is offline
post #4 of 21 (permalink) Old 07-28-2008, 05:53 PM
dsl kicks gas's Avatar
i tryed to get mine as leval as possible with out killing the ground clearance....either way they make a huge diff
2000 / 3500 / DRW / QC / nv4500 / SB IG / ATS manifold / Fire Rings/ 62/65/14 / 105hp injectors / Schied HR VP-44 / Quadzilla Adrenaline w/ Pulse V2 / SMARTY / FASS 150 / 5" pipe / AFE intake / Recon LED's / Eagle Alloys w/ 285 Cooper STT's
dsl kicks gas is offline
post #5 of 21 (permalink) Old 07-28-2008, 05:56 PM
SIXINAROW's Avatar
if you are pulling then the longer the better, drag racing go shorter, that is what I have heard. I went long and end is right behind the front doors.
97 dwr 4x4, DTT, SDX 5X16,215 pump/180dv, 20*,5k,60lb,.020" HD,hx35
SIXINAROW is offline
post #6 of 21 (permalink) Old 07-28-2008, 06:25 PM
Hot Stuff's Avatar
Usually right about the back of the cab (longbed). This has been briefly discussed in several of our "ladder bars" or "traction bars" threads. If you search for them, they will show!!
But yeah, about the back of the cab to the middle of the (rear) doors is usually good on a long bed. Shortbeds will be rear of the front doors or so, roughly.
Some pics here to estimate length......
Traction Bars
'03 Black 2500 QC/LB 4x4, DRW 6 speed, SB3600DD, Fuel Throttle wheels, 305/70 Terra fronts, 285/75 Terra rears, B&W turnover, air bags, HE351 turbo, 5" pipe, CAI, 2nd gen intake, Pacbrake and Smarty
Hot Stuff is offline
post #7 of 21 (permalink) Old 07-28-2008, 06:51 PM
here is a few picts of mine....not a 3rd gen buy you get the poin
dont make fun of the little puff of smoke......i was in mpg mode
post #8 of 21 (permalink) Old 07-28-2008, 06:52 PM
try this again lol
post #9 of 21 (permalink) Old 07-28-2008, 07:03 PM
one more time then i quit
post #10 of 21 (permalink) Old 07-28-2008, 09:26 PM Thread Starter
Thanks for all the info guys. :thumbsup
H82LOSE is offline
post #11 of 21 (permalink) Old 07-29-2008, 10:50 PM
mine are 69" center to center of eye. I have bent or broke them 4 times in 4 pulls. first till bent the 1.25 inch pipe. ok go thicker. 1.25 pipe with 1 inch inside and welded together.
2nd pull: pipe ok, broke both rear heim joints. thought maybe they were weak from previous pull.
3rd pull, broke 1 front and 1 rear heim joint, pipe ok. thought my bump stops werent keeping enough up travel off suspension. fixed that..
4th pull: bigger heim joints. really tight suspension, about 10ft from end of pull in the video you can see them flex up and rest on the frame then when I let off, they roll down to them bottom.
I am going with square tubing now, so we'll see. Everyone has said that I shouldn't be bending them, but??? My friends 2.8 class pulling truck just has 1.5 inch bars and he bent the frame at the dhra pull a couple of years ago in indy, behind the cab.
All I know that this sux. hope we figure it out.
SOLD: 2001 ECLB 4x4 5spd, Air dog, TST Comp., homemade Amsoil intake, 4in exhaust, muffler and CoS MIA.
torquet is offline
post #12 of 21 (permalink) Old 07-30-2008, 08:10 AM
Hot Stuff's Avatar
Torquet, Post pics of your setup. Mounting points (axle and frame) etc so we can help point you in the right direction.
How thick of pipe are you using? Long bed or short bed?
