| Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling |
Pure Diesel Power
![]() Join Date: Dec 2005
241DHD vs 271 Transfer case
Does anyone know the specifications on the 271 T Case? I probably need a new tcase, I just cracked my 241DLD. Is the 271 a LOT beefier than the 241DHD? What are the ratios of the 271 in low range? IIRC the 241 is 2.72:1 THanks Garrett |
#3 (permalink) |
Former Staff Member
![]() Join Date: Feb 2006
will a 271 fit in our application?
Corey Ritter - Amity, OR '04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd, HO, Edge EZ, TST PowerMAXCR, Smarty, SPS 66, Rip's 4", AFE PG7 W/torque tube, FASS 150, Superlift leveling kit, Ride Rite's w/onboard air, Line-X. Torklift camper tie downs, fuel vent mod, CB, GPSmap 168, Buckstop/Warn 12,000 lb, KC Daylighters, MTL w/prolong in trans, Haisley DD, DiPricol gauges and Quad Commander. 77K 513/1043 Fast Specialties DDD 4-15-2006 TST-EZ stack, Quickest 1/4 mile ET 13.949 @ 96 MPH @ PIR Hauls Lance "Lite" 1025 @4klbs Wifes truck '98 Intense Blue 12V QC LB 4X4 Auto |
#4 (permalink) |
The 271 is alot beefier case then the 241. It will fit in our trucks. I have one in my 99', some driveline modifications are required though. Worth it if your gonna sled pull with your truck.
99' Ram, 5spd 4x4, 271t-case, p-pumped, DDP 250HP injectors, II Silver Bullet. |
#5 (permalink) |
Former Staff Member
Sled pull Who would do such a thing
#8 (permalink) |
if im not building a sled pulling truck, but i wanna hook every now and then will my 241 be ok...after seeing bobcat break his truck last friday im really scared to hook now
2002 Dodge Ram 2500 ECLB 6psd Patriot Blue One Piece at a Time 2.8 Street legal Puller |
#9 (permalink) |
I made over 600 1/4mile passes with my 241DHD, before I started to get "glitter" in the t-case fluid. I replaced it with a 271. It is physcially bigger, as well as being stronger. I got mine from Transfer Case Express. They can set it up so that you have the same shift pattern as a 241. I also had them put a flange on the rear output instead of the slip joint. The drive shaft had to be modified to have the flange as well. The front drive shaft fit without modification. The rear may have, but I wanted the flange, for the added strength. The newer 2nd gen's use the speed sensor in the rear end for the speedometer. The 271 does not have a place for a speed sensor in the tailshaft housing. I have heard that someone makes a electronic kit to make the speedometer work with a 271, but I do not know who it is. It was not an issue on mine, because my 241 did not have a VSS (vehicle speed sensor), in the tail shaft housing. Paul
02 4x4 Auto Mach 6+'s, Drag Comp,Source Automotive Twins, Ultimate Transmission 05 2500 4x4 Auto 3.73 Flux 6's, Smarty, Source Automotive Twins, F1 springs, push rods, Mitusa, PPE Dual Fueler, Ultimate Transmission, Opie shafts,Isspro gauges |
#10 (permalink) |
Former Staff Member
4 NP 271 ................ $695 * 4 NP 273 ................ $695 * Anybody know what the 273 differances are? @$300 cheaper than the 241, sounds like a good bomb
#11 (permalink) |
The 273 is electric shift I believe...for the newer trucks!! Chris
Chris Mayer 1998 Dodge 2500 QC, Auto, 4x4, 3.55's, 122K Performance: Teaked AFC, Scotty II, Straight Pipe, ThurenFab Crossover Steering and Trackbar, 2" CSS Coils, Bilsteins Plans: DTT, Twins, 913, ??? Results: Dynoed 176HP/392TQ STOCK on 11/25/06 1995 Dodge 3500 Club Cab, Cummins, 2wd, NV5600/NV241, 3.55, 326K, Flatbed Performance: #100 plate, S300 (62mm/.7), 022DV's, SBC DD Street, Valet, 3K GSK's, 17*, Rip Rook 4” Cosmetic: SW Boost/Boost/Pyro, X-monitor, Firestone Airbags, ViAir 460C, Lifted 2", LED's Sound: Sony CD/XM/MP3, JL 12w6v2, JL 500x1, JL XR653-Csi, JL XR650-Cxi, Pioneer 300x4 Results: Dynoed 328HP/769TQ Valet, 402HP/885TQ Full Fuel on 4/8/06 Waiting On BOMB Money: 1970 Chevelle, 350, AT, Pleather Seats --- 217HP/264Ft lbs |
#12 (permalink) | |
| The Following User Says Thank You to paulb For This Useful Post: | 95Cummins12Valve (08-08-2009) |
