Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 07-19-2006, 04:40 PM   #25 (permalink)
bobcat yes mine is extendedcab l.b. no i did not have to notch my frame bbd did it just for a little bit more clearence i think
cahammer is offline   Reply With Quote
Old 07-19-2006, 04:58 PM   #26 (permalink)
Pure Diesel Power
Bobcat698's Avatar
I mean even it if torques enough where it hits, it should do nothing but stop it from moving, anyways.
Thanks for the info.. I am leaning closer and closer to getting the 271.
Do you run the slip yoke?
Thanks!
BTW I left a message on your phone.
Bobcat698 is offline   Reply With Quote
Old 07-20-2006, 01:04 AM   #27 (permalink)
zstroken's Avatar
1480 slip joint
Haisley Machine Repair has the 1480 slip joint. There is an application that has the right spline count, but the OD is too big. They turn it down to the right OD. Some of the Enterprise Pullers use the 1410 too. If you are running a 3.54 I would be a little leary of it, especially with dual rear wheels. Lot of it depends on truck setup though.
zstroken is offline   Reply With Quote
Old 06-29-2009, 10:06 PM   #28 (permalink)
bcmason's Avatar
Attention to "Bad 12V"
What transmission do you have that New Process 271 behind. I was wondering if it would bolt up behind my 93' 12Valve. It has a auto 618????
bcmason is offline   Reply With Quote
Old 09-15-2009, 02:48 PM   #29 (permalink)
what can be down about the speedometer on a 1996 truck without the rear speed sensor in the axle?
1998 12v 4k gsk, ring rings, ARP head studs, automatic, 2095 plug,
no plate or AFC lever.
SMOSKO is offline   Reply With Quote
Old 09-15-2009, 06:48 PM   #30 (permalink)
resident trans breaker
jackblack99's Avatar
holey thread revival batman!!
94 reg cab dually... haisley 911 pump trans is fixed, now the nonstock spinny thing broke.
jackblack99 is offline   Reply With Quote
Old 09-15-2009, 08:36 PM   #31 (permalink)
1997whitefozo's Avatar
ha, last night I was looking at this same thread!!
Will the np271 bolt up to the nv4500 in my 97?
97 cummins 5-speed 37's 4x4,HID's!,super B turbo. 5x14, sbc 3600dd, Rip's 4in, 4gsk no plate, gauges, titanium retainers, 60#springs, o-ringed head, arp's myspace.com/tylerfozo
1997whitefozo is offline   Reply With Quote
Old 11-03-2009, 08:37 AM   #32 (permalink)
Figured I'd pick this thread up again. I'm the currently the owner of a busted 241 DHD in my 02 auto 3/4 ton. I have been toying with the idea of swapping a 271 into the truck instead of just putting another 241 DHD in.
It sounds like a new rear slip yoke and shorting the drive shaft are the only two things that need to be done with this swap. Or am I missing anything? Also what model 271 should I be looking for? Any out of a 03 & up Auto? For someone who has done this swap, how much does the drive shaft need to be shortened? Would it be possible to use the entire drive shaft from a 03 & up to avoid reworking the rear drive shaft?
2002 4wd 2500 Quad Cab Short Bed 83K --- Stock
Frog212 is offline   Reply With Quote
