Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 07-17-2006, 05:27 PM   #13 (permalink)
you also need a bigger slipyoke for the 271 and shorten the drive shafts now is a good time to up grade to the 1480 series yokes but this can put a good price tag on the conversion also dont forget to bend the fuel lines outta the way for clearence
cahammer is offline   Reply With Quote
Old 07-17-2006, 05:30 PM   #14 (permalink)
Originally Posted by MR4WLR
4 NP 271 ................ $695 *
4 NP 273 ................ $695 *
@$300 cheaper than the 241, sounds like a good bomb
If you are going to be in Ashcroft at the NHRDA race this weekend, you can take a look at the 271 in mine. BigBadDodge was the first person I know of that did the swap.
Paul
02 4x4 Auto Mach 6+'s, Drag Comp,Source Automotive Twins, Ultimate Transmission
05 2500 4x4 Auto 3.73 Flux 6's, Smarty, Source Automotive Twins, F1 springs, push rods, Mitusa, PPE Dual Fueler, Ultimate Transmission, Opie shafts,Isspro gauges
paulb is offline   Reply With Quote
Old 07-17-2006, 06:06 PM   #15 (permalink)
Former Staff Member
MR4WLR's Avatar
Paul
I would like to check out both Ashcroft and the t-case but, a bit farther than I'm willing to travel for a non-sled pull event
I'll have to take a look at the next Portland race.
Corey Ritter - Amity, OR
'04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd, HO, Edge EZ, TST PowerMAXCR, Smarty, SPS 66, Rip's 4", AFE PG7 W/torque tube, FASS 150, Superlift leveling kit, Ride Rite's w/onboard air, Line-X. Torklift camper tie downs, fuel vent mod, CB, GPSmap 168, Buckstop/Warn 12,000 lb, KC Daylighters, MTL w/prolong in trans, Haisley DD, DiPricol gauges and Quad Commander. 77K
513/1043 Fast Specialties DDD 4-15-2006 TST-EZ stack, Quickest 1/4 mile ET 13.949 @ 96 MPH @ PIR
Hauls Lance "Lite" 1025 @4klbs
Wifes truck '98 Intense Blue 12V QC LB 4X4 Auto
MR4WLR is offline   Reply With Quote
Old 07-18-2006, 01:57 AM   #16 (permalink)
You guys ought to look at these.
http://www.offroaddesign.com/catalog/doubler.htm
You could also do a stock 205 swap.. This would be a 2:1 low range as opposed to the doublers 4:1 Either way you are cast iron and chainless..
CumminsRover is offline   Reply With Quote
Old 07-18-2006, 04:08 PM   #17 (permalink)
Here's a visual of the size difference. This was cahammer's swap.
Smokin Monster is offline   Reply With Quote
Old 07-18-2006, 04:23 PM   #18 (permalink)
Former Staff Member
MR4WLR's Avatar
Thanks for the visual Smokin Monster :thumbsup
Old 07-18-2006, 04:33 PM   #19 (permalink)
Pure Diesel Power
Bobcat698's Avatar
So do I just need to get a Posi-Lock to replace the vacumn acuated stuff up front?
Other than that, some driveshaft work?
Thanks!
Bobcat698 is offline   Reply With Quote
Old 07-18-2006, 08:09 PM   #20 (permalink)
cahammer...you didn't need a posi lock up front did you? I think that vacuum actuator still works.
Old 07-18-2006, 09:25 PM   #21 (permalink)
having a posi lock would help for shift on the go but no you dont need one the orginal actuator works but you have to slow way down like under 10mph to get it to go in there are advantages to the posi lock system you can have 2 low for backing up a trailer or when ever you just need a lower gear and then there is the cost factor that is what stoped me at the time of the conversion also just unscrew the vacume ports on the t-cases and swap them it was that simple
Quote "cumminsrover You guys ought to look at these"
my wife would me if she knew what was going on in my head right now
Old 07-19-2006, 11:19 AM   #22 (permalink)
1BADRAM's Avatar
When I done my conversion I could not find the 1480 series for the slip yoke. The only one I could get was the stock 1410. Doese anyone know where I can get the 1480 at?
99' Ram, 5spd 4x4, 271t-case, p-pumped, DDP 250HP injectors, II Silver Bullet.
1BADRAM is offline   Reply With Quote
Old 07-19-2006, 02:38 PM   #23 (permalink)
Pure Diesel Power
Bobcat698's Avatar
Talked to Scheids and apparently even Brad Ingram runs a 1410 off the transfer case, so if he runs it I think thats all we'll ever need
Old 07-19-2006, 03:22 PM   #24 (permalink)
Pure Diesel Power
Bobcat698's Avatar
CaHammer, do you have a extended cab long box truck? If so, I shouldn't have to notch the frame either, correct?
Thanks
