Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 11-03-2009, 08:33 AM   #1 (permalink)
pulling with a CR auto?
i've got an 06 mega cab what do u guys with autos do? 4lo 4hi? drive with od locked out? i came from the duramax world and efilive... dodges are all new to me any help would be appreciated. i use to pull all the time but i could program the tranny to do what i wanted behind a 860hp 2.8 duramax. but im in the dodge world and wanna go back to 2.8 give the knowledge to get there thanks guys.
pville is offline   Reply With Quote
Old 11-06-2009, 09:05 AM   #2 (permalink)
4 low, pull in drive with OD locked out.
06 Inferno Ram - 2007,2008,2009 NKTPA 2.6 Point Champ
Feel the Force! - Force Fuel Additive!
Floor It - Formula One - Smarty Power - Dr. Performance - PPE Power - ATS Diesel
RAWRAM is offline   Reply With Quote
Old 11-06-2009, 09:16 AM   #3 (permalink)
Super Administrator
BBRam's Avatar
Same here.
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 11-06-2009, 07:18 PM   #4 (permalink)
whitey70ss's Avatar
Same here, 4 low od locked out , co-pilot on lowest setting.
'08 2500 QCSB-Black-shibby egr/cooler delete-RSD 5"TBE-XRT-68rfe-leveling kit-315/70/17 BFG AT KO's-tinted.
whitey70ss is offline   Reply With Quote
Old 11-07-2009, 08:39 AM   #5 (permalink)
MoPower05's Avatar
2005 dodge 2500(driver),2005 dodge 3500 white flat bed(2.6 puller)
http://www.youtube.com/mopower08
www.afterhoursdiesel.com
MoPower05 is offline   Reply With Quote
Old 11-07-2009, 09:03 AM   #6 (permalink)
can our CR's compete with the 12v schied boys in a 2.8 class?
Old 11-07-2009, 09:25 AM   #7 (permalink)
rpainter's Avatar
Nope
2004.5 3500 stock for now (hoping for upgrades soon)
rpainter is offline   Reply With Quote
Old 11-07-2009, 09:50 AM   #8 (permalink)
Alberta Pres
mattyboy72's Avatar
lmao only guys who can compete with the schied boys are the schied boys themselves hahahahaha
04.5 3500 laramie,DDP 64mm,50's,cam,springs,S&B stage2,Diablo Predator,Edge juice with attitude,4inch into quad stacks,glowshift gauges,mickey t's with dynapros,badass set of truck nuts
OIL COUNTRY COAL ROLLERS
PUBLIC DISTURBANCE
mattyboy72 is offline   Reply With Quote
Old 11-07-2009, 10:03 AM   #9 (permalink)
rpainter's Avatar
what is so great about the scheid guys?? I can get the same parts that they run just cheaper . I have built 2 Big block gas motors and 1 unlimited p-pumped 24v motor for pulling trucks and all of them dynoed over 1,000 hp.
Old 11-07-2009, 02:22 PM   #10 (permalink)
idk.... i could hang with them and hand some of them their butts with the dmax. but thats a different story
Old 11-07-2009, 08:39 PM   #11 (permalink)
jneal's Avatar
Pville, I didn't know you sold the dmax and went dodge. You should be just fine in the 2.8 class with a common rail dodge. With EFIlive in the testing stages for CTD and eventually the release of rpm tables you be fine. The only reason IMO that the 12 valves are so competitve is RPM's. Either limit there RPM's or run the same revs that they are and they are not any farther ahead than anything else. IMO once the RPM thing gets taken care of for the common rail dodges they will be the king no if ands or buts about it.
06 GMC RCLB 4X4 Duramax Allison 11.55@117mph 1/4 mile #2 only.
WTB 12V, 5 speed 4x4 3500 ECLB
jneal is offline   Reply With Quote
Old 11-08-2009, 01:21 PM   #12 (permalink)
TENNESSE CHAPTER PRESIDENT
01cumminsred's Avatar
i found until i hit certain hp range i couldnt turn the tires good enough in 3rd..so i did tow haul on and put in 2nd on the floor...high rpm's but puts me down the track..i have tired 3rd but seems to fall on its face
2003 HO 4x4 stock or thats what i tell the wife
Rollin' Coal Pullin' Team
01cumminsred is offline   Reply With Quote
