Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 11-03-2009, 07:34 AM   #1 (permalink)
MoPower05's Avatar
Breaks while spooling
All my breaks come while spooling. ex. axle, driveshaft. I just broke the front drive shaft again in the same spot, at the cv joint just off the transfer case. Does anyone else have this problem and what are you doing to fix the weak links? Truck has stock front suspension and normally hang about 350-400 lbs on the front.
Thanks
2005 dodge 2500(driver),2005 dodge 3500 white flat bed(2.6 puller)
http://www.youtube.com/mopower08
MoPower05 is offline   Reply With Quote
