Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 09-11-2009, 08:11 PM   #1 (permalink)
nh591's Avatar
axles??
I got a question about axles for an '01 2500. I keep busting axles. Went through 2 sets of stockers and 1 set of Mosers. Twistting off right at the splines. Truck did not bounce on any pulls, just when I get down around 300 feet the sled pulls the rear down and the tires start diggin hard then snap! busted axle!
Any suggestions on what axles to run?? was looking at scs billets, but they're expensive! are they worth it??
'03 2500 Quad Shortbed Laramie 235hp 48re 4.10s- 4" MBRP Pipe_Smarty_AFE Cold Air Intake_AFE Intake Horn_Edge Juice W/Attitude_Dunrite Triple Disk Converter_Valve Body Mods_Billet Input_Edge Jammer 25 Horse Nozzles
nh591 is offline   Reply With Quote
Old 09-11-2009, 10:28 PM   #2 (permalink)
Cummins CrAzY
DevilDogDiesel's Avatar
Dana 70 or 80? If its a 70 you need to upgrade to an 80. if its an 80 get a set of Haisley axles.
AXLES, HEAVY DUTY, DANA 80, 35 SPLINE, 37 SPLINE, DANA 60 ONE PIECE - Haisley Machine
2000 2500 ext. cab short bed, AFE cold air intake, single 6 inch stack, SPS 62 turbo, FASS 95, Scheid Lightning II's, .093 connector tubes, Maxspool valve springs, A1 head studs, Fire ringed head, Adrenaline, HP intercooler boots, fully built trans. Goerend triple disc converter billet input Haisley full manual valve body with lots of other upgrades, custom trac. bars, draw straw
DevilDogDiesel is offline   Reply With Quote
Old 09-11-2009, 11:54 PM   #3 (permalink)
nh591's Avatar
its an 80, I'll have to look into them...thanks
Old 09-12-2009, 12:31 AM   #4 (permalink)
TENNESSE CHAPTER PRESIDENT
01cumminsred's Avatar
upgrade to a gm 14 bolt or the newer 11.5 amc dodge axle i have both for sale
2003 HO 4x4 stock or thats what i tell the wife
Rollin' Coal Pullin' Team
01cumminsred is online now   Reply With Quote
Old 09-12-2009, 04:58 PM   #5 (permalink)
nh591's Avatar
Yea I had a couple local guys tell me to do a swap like that, but i'm just trying to figure out all my options before I tear into it.
Have anyof you guys ever messed with that cryogenic treatment of the axles??
Old 09-13-2009, 12:46 AM   #6 (permalink)
Cummins CrAzY
Call and talk to Haisleys. Then can give you every bit of info you need and it will be from the horses mouth, not I heard or I know a guy that knows a guy.
Old 09-16-2009, 03:13 AM   #7 (permalink)
swalldog's Avatar
ctm makes some sweet custom axle shafts also. double splined with a drive flange on the end. all made out of 300M.
CTM Racing Products
01 QC/SB 6-SPEED, COMPOUND TURBOS, 255/70R 22.5 MICHELIN XD2
http://www.cumminsforum.com/forum/98...w-rig-fun.html
swalldog is offline   Reply With Quote
Old 09-16-2009, 03:19 AM   #8 (permalink)
ninerqb8's Avatar
Did you do a swap, because if not your truck would only have a dana 70 with the auto? Either way you wont brake a set of haisley axles if you are running a 80.
Silver 98 2500 Quad Cab long bed, 12 valve, NV4500. No cat, no muffler little AFC work no plate, little timing, KDP victim now tabbed. Soon to have 2001 cab with all the options and a new color!
ninerqb8 is offline   Reply With Quote
Old 09-16-2009, 05:07 PM   #9 (permalink)
nh591's Avatar
No the truck in my sig is my dd. The pulling truck is an '01 2500 5speed
Old 09-16-2009, 10:50 PM   #10 (permalink)
03 and up come with amc 11.5, dana was only in 1st 2nd gen....and read alittle around on the 80's even with harder axles people are breaking pinons...i am confused they dont seem as strong as the new 14 bot amc axles...jmo
Old 09-16-2009, 11:47 PM   #11 (permalink)
resident trans breaker
jackblack99's Avatar
thats AAM not AMC. it stands for American Axle Manufacturer.
94 reg cab dually... haisley 911 pump trans is fixed, now the nonstock spinny thing broke.
jackblack99 is offline   Reply With Quote
Old 09-17-2009, 01:29 AM   #12 (permalink)
THE Hood Stack Guy!
BossHawg600's Avatar
But what tires are you running? If your running something super aggressive, them suckers are gonna break in a hurry!!!
Jeff Faker
2006 Mega Cab, 37" KM2's, Twin Turbos, 6sp......stock Injectors, CP3, TST Turned Off
Dont Make Diesel the New Rice!!!
BossHawg600 is offline   Reply With Quote
