Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 09-17-2009, 05:20 PM   #13 (permalink)
nh591's Avatar
33 12.5 BFG all terrains
'03 2500 Quad Shortbed Laramie 235hp 48re 4.10s- 4" MBRP Pipe_Smarty_AFE Cold Air Intake_AFE Intake Horn_Edge Juice W/Attitude_Dunrite Triple Disk Converter_Valve Body Mods_Billet Input_Edge Jammer 25 Horse Nozzles
nh591 is offline   Reply With Quote
Old 09-17-2009, 05:23 PM   #14 (permalink)
nh591's Avatar
Originally Posted by swalldog View Post
ctm makes some sweet custom axle shafts also. double splined with a drive flange on the end. all made out of 300M.
CTM Racing Products
Do you know how much a set of those are?? I checked the site out and it looks like they only custom make them.
Old 09-17-2009, 06:19 PM   #15 (permalink)
TENNESSE CHAPTER PRESIDENT
01cumminsred's Avatar
Originally Posted by jackblack99 View Post
thats AAM not AMC. it stands for American Axle Manufacturer.
i was tired but you get the idea
2003 HO 4x4 stock or thats what i tell the wife
Rollin' Coal Pullin' Team
01cumminsred is offline   Reply With Quote
Old 09-17-2009, 08:04 PM   #16 (permalink)
resident trans breaker
jackblack99's Avatar
haha. its cool man. we all have those nights!
94 reg cab dually... haisley 911 pump trans is fixed, now the nonstock spinny thing broke.
jackblack99 is offline   Reply With Quote
Old 09-18-2009, 08:33 AM   #17 (permalink)
getblown5.9's Avatar
i got mine through haisley, they are made by CTM. thicker shaft, 37 spline, and its splined on both ends with a drive flange...
$1300 for a pair, not cheap at all
2002 Dodge Ram 2500 ECLB 6psd Patriot Blue
One Piece at a Time
2.8 Street legal Puller
getblown5.9 is offline   Reply With Quote
Old 09-18-2009, 07:41 PM   #18 (permalink)
nh591's Avatar
Am I thinking right, when you say splined on both ends with a drive flange??
Is the axle 1 solid shaft with splines on both ends 1 for rearend 1 for drive flange? Then the drive flange slides over the splines to bolt onto the hub?
Old 09-19-2009, 11:30 AM   #19 (permalink)
pretty much, the CTM's have some type of spring loaded snap ring that holds the shaft in the flange so it can be assembled as one piece.
heres some pics- i have comparison pics somewhere of them side by side with a stock shaft so you can see how much bigger they are. but this shows the shafts and the minispool from haisley as well.
One Piece at a Time
Old 09-20-2009, 08:12 PM   #20 (permalink)
powerbrake's Avatar
Originally Posted by DevilDogDiesel View Post
Dana 70 or 80? If its a 70 you need to upgrade to an 80. if its an 80 get a set of Haisley axles.
AXLES, HEAVY DUTY, DANA 80, 35 SPLINE, 37 SPLINE, DANA 60 ONE PIECE - Haisley Machine
the 70 runs 1 1/2" axles like all 1 tons do. you do gain strength in the pinion shaft with the 80 and of course you get much better brakes. why do you think the 80's axle shafts are any stronger?
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
Old 09-28-2009, 10:19 AM   #21 (permalink)
its the bigger pinion you want but you just move the weak leak down...so they are putting harder axle's in
Old 10-10-2009, 05:59 PM   #22 (permalink)
Wicked_Intentions's Avatar
Dana 80 axles and Dana 70 are identical 1.5" diameter w/ 35 splines. The Dana 70 is really a 70/80 hybrid. The center section is the same size, the axles are the same, the axle tubes are the same size untill right before the drum then it tapers down. The only real difference is the differential is a two piece that has smaller ring gear hardware, and a 10.5" ring gear. Where as the 80 is a one piece design with a 11" ring gear, and much stronger pinion gear.
Dodge Ram Dana 80 Axle Specifications
Dodge Ram Dana 70 Axle Specifications
Powertrax Locker for Dana 70/80 Product review on 4x4Wire.com
check these out I have more but this is the basic info with comparison.
also a 14 bolt is not stronger than a 70 or 80, see link below.
4x4 Truck Axle Tech - Torque Output - Four Wheeler Magazine
those are max output torque allowed.
99' QB/LB auto, Blue Chips VP44, FASS95/150, 7" FBD stack, Quad ADR w/ Pulse, FBD 200hp sticks, FBD fully built tranny with lock up switch,3pc. manifold, BD Super B Special, ARP Head studs, Hamilton Springs and Fire ringed Head
Wicked_Intentions is offline   Reply With Quote
Old 10-21-2009, 12:34 AM   #23 (permalink)
you can say that again!
neverenoughsmoke is offline   Reply With Quote
Old 10-28-2009, 03:21 PM   #24 (permalink)
found the pics of them next to a stocker
One Piece at a Time
