Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Pulling
Cummins Pulling Discussion Pertaining to Cummins Transfer Sled Pulling
Old 09-08-2009, 11:06 PM   #1 (permalink)
what does it take 3.0
what does it take to be competitive in the 3.0 or 2.8 class. was thinking about pulling off the twins and turning it into a more serious puller. internal mods are studs, head work by floor it, valve springs, stage 3 pump, flux 4 injectors, helix cam, bd intercooler, full goerend trans, 3.73 gears. would it still be capable of towing a 32' fifth wheel or 20,000#s of water and chemicals for sprayer? snow plowing? i know im probably asking a lot but its what i use the truck for know and until i can buy another work truck its what i need
iafarmboy is offline   Reply With Quote
Old 09-09-2009, 01:08 AM   #2 (permalink)
PULLING IS A DRAG...
'00Cummins3500's Avatar
i assume you have a CR? where you live, to run 3.0, a scheid or haisley built truck... even to run 2.8 just change your turbos & then you will be really pushing it with no o-rings or fire rings. and towing, i doubt you could keep pistons in it with that set up. sorry, glad to see people taking intrest in the sport though.
'00 3500 black ext cab dually, auto, edge drag comp, jammer 3s, HX 40/35 hybrid, raptor 100, AFE stage 1,auto meter z-series boost, pyro, trans temp, banks big head wastegate, ARP studs, o-ringed head, FBD 5" strait pipe,future tranny rebuild...DUH!!!
Owner of TRACK BOSS pulling sled "when the big hook drops, the BS STOPS!!!"
'00Cummins3500 is offline   Reply With Quote
Old 09-09-2009, 08:49 AM   #3 (permalink)
sorry, from iowa with an 03 with a 62/71/13 and s480, also anyone know of pulling orgs with a class for twins. i would like to pull against some trucks with similar set ups. she dyno'd 793 and 1589 this summer at a local fair with floor it's dyo.
Old 09-09-2009, 08:54 AM   #4 (permalink)
Pull It Till It Breaks!
Smourj21's Avatar
The only class you could pull in is a run what you brung or the mod class
Leveled 2002 Short Bed Quad Cab 6 Speed SHO | MBRP 4" Duals | Short Shift | Valair DD | Edge A2 | BD HRVP44 | Airdog 150 | CFM+ | BD Steering Stabilizer | Brite Box| 3pc Exhaust Manifold | DDP 250HP sticks | 35" Toyo MT's on 18" Driiv Offroad |Bilstein 5100's| Dana 60/80 | 3:55's | Detroit TrueTrac | Traction Bars| HX40/S475 TWINS|
|520hp/1132tq With the 200's|
Smourj21 is offline   Reply With Quote
Old 09-09-2009, 09:01 AM   #5 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
Dont pull the twins off if you still use it on the street, you'll hate a big single once you've had twins
2000 QCSB, built auto, P7100, 131 dvs, 4gsk, .084 lines and tubes, 7 x .014s, 22*s, maxspool 2.5 cam, 110# valve springs, 125ft lb head bolts, 66/74/.9
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 09-13-2009, 10:16 PM   #6 (permalink)
he could run badger truck pullers assc. he would just have the make the s480 a 3" inducer
conk is offline   Reply With Quote
Old 09-14-2009, 11:05 PM   #7 (permalink)
thanks, how close to iowa do they normally get?
Old 09-15-2009, 01:22 AM   #8 (permalink)
we had a couple pulls around and west of the madison area. did you check the rules with fantesy truck pullers? they are a more of a iowa and westurn wisconsin club, I just don't know how there rules are
2005 2500, makes some power
BTPA Member
Old 09-27-2009, 07:54 PM   #9 (permalink)
kjpcummins's Avatar
Hey Tim i missed this thread. I cant remeber how far north you are but the mpa pullers have a 3.0/twin class. With a large single your not goin to be able to tow anymore. Have you pulled your truck much after the jefferson pull? I was curious if you got it to hook an better and if you have tried a tc lock up switch to see if that helped. You could just leave your truck as is and get another one and build up. In iowa it doesnt take much to be competitive an any class my old hx35 keep me out front many times this summer. Are you coming down for the dyno day?
Kyle
2002 2500 4x4 6 speed
Please provide physical proof to back this up.....or refrain from posting it.
Engineered Diesel Turbos/Southern Diesel Extreme Injectors
kjpcummins is offline   Reply With Quote
Old 10-17-2009, 04:23 PM   #10 (permalink)
RSieck's Avatar
Check fantasys website for this years rules. It has been brought up they are looking to drop the 3.2 twins to a 3.0 open driveline.
Where do you live in Iowa? Also check with the ecitpa. They have a unlimited single but 1 ton drive line
99 F250 PSD
RSieck is offline   Reply With Quote
Old 10-17-2009, 08:54 PM   #11 (permalink)
PureFlow Technologies
2Tone12V's Avatar
First you will have to start by ditching the CR
2Tone12V is offline   Reply With Quote
Old 10-17-2009, 08:59 PM   #12 (permalink)
kjpcummins's Avatar
Good advice you can give it to me i need a tow rig/dd and your 03 will get the job done.
