Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Competition Cummins > Cummins Off Roading
Cummins Off Roading Discussion Pertaining to Cummins Off-Roading - Baja , Muddin' , Rock Crawling Ect.
Old 10-26-2009, 04:41 PM   #1 (permalink)
redneck sailor
cajun5.9ctd's Avatar
air system
first of all let me start out by saying i have an on board air system and i like it so far, but i think the current compressor cant handle inflating my big ol' 35s when i deflate them to do some wheelin.
I have everything mounted where i want, but i just want to take off the old compressor and swap it with a "more better" one. Does anyone have some ideas on what tyoe of compressor i should use??
2006 Dodge 2500 4X4
Voliant Cold Air Intake, Edge Juice w/Attitude, Banks Ram Intake Manifold , MBRP 4inch turbo back exhaust, and a set of air horns
cajun5.9ctd is offline   Reply With Quote
Old 12-08-2009, 09:45 PM   #2 (permalink)
Whatever Works!!!
Prowelder's Avatar
Hey,
What do you have right now??? ARB makes various models for different needs so you might check them out!!!!
Later,
Winslow
Black Magic! 2001 Ram 2500 QCSB, 4x4, 2-cycle oil, 54 Block!!, NV 4500, 3.55 gears, B&W Hitch, Autometer Ultra-Light: Boost, EGT, and Fuel Pressure, Valair 13" Kevlar/Ceramic 3400 lb Single Disc Clutch, Valair Upgraded Hydros, Edge Comp (untapped), Jkidd 150 hp matched sticks, 3" Pipe, Custom Built Intake Horn, BHAF with 7075 T-6 Heat Shield and Red OuterWare, AFE Torque Tube, Air Dog II DF-165 with custom cover, PSC Pump and Brace, Jkidd Sport Headlights, Tunnel Ram on the way, and Building High Idle Fooler Setup!
Prowelder is offline   Reply With Quote
Old 12-09-2009, 02:24 PM   #3 (permalink)
CowboyCummins01's Avatar
Viair makes a good compressor. I believe they are under the Dealer section here
01 Ram 2500HO, "Oreo" NV5600,3.55's, 33'' meats, Fass150,Comp box, RV275's?,HX35, AFE Stg2, 5''str8 pipe, Valair HD, 362rwhp,811ft/lbs
Just Ledoux it-RIP Chris LeDoux
CowboyCummins01 is offline   Reply With Quote
Old 12-11-2009, 10:26 PM   #4 (permalink)
Scott39's Avatar
Best air compressor on the market, and it isn't cheap.
Airs up one of my 35" from 20 to 45psi in about a minute.
<>< JC Rules http://www.hollandcourtsales.com/
1995 2500 single cab 4x4 Cummins, 4.11 posi, 5spd, Gear vendor overdrive, dana 80, HB 2.5" level kit, rancho 9000s
Scott39 is offline   Reply With Quote
