cummins rat rod project - Page 6 - Dodge Cummins Diesel Forum
post #61 of 89 (permalink) Old 02-16-2011, 12:11 AM
Originally Posted by 1lowdiesel View Post
Damn, you got a good deal there. But i needed a reg cab short bed chassis. I didn't feel like shortening the LB chassis. Besides i needed the rear anyway for my dads truck and i needed the bed to build a display for our showroom.
it kinda fell into my lap right on new years eve. 2 hours before the ball dropped it was unloaded in my driveway. the PO had melted a few pistons in the original motor, but i had bought a motor a few months prior hoping to drop it into a chevy. but instead i bought the dodge chassis as it was complete and dosen't need any custom fabbing and parts compared to a conversion.
what for gear ratios are you going to be running? and if i had missed it, what happened to the GMC? parts from the 1500 donor?
MORE PICTURES!
2011 Chevy - Tangier Orange
1995 Chevy - RCSB Daily
1995 RAM 2500 - Rebuilding
My wallet likes to scream at me...
8898Chevs is offline
post #62 of 89 (permalink) Old 02-16-2011, 08:54 AM Thread Starter
For now it'll have the 3.55s that are in the 60 and 70 i picked up, I may go higher later on. The GMC i sold to a guy in Indiana, he's going to build a Cummins race truck out of it. The Dodge i'm just finishing up parting out.
Kyle
1lowdiesel is offline
post #63 of 89 (permalink) Old 02-17-2011, 05:46 PM Thread Starter
more goodies. I've now got all my fuel, oil and trans cooler fittings. The trans rebuild kit will be in on monday and I just got my 4wd tailshaft today! This weekend i'm going to work on getting the motor cleaned up and studs installed.
Kyle
post #64 of 89 (permalink) Old 02-21-2011, 12:40 AM
good start. keep it going! and if you still have them, do you still have those part numbers? or where i can get them? i need trans and fuel lines and fittings. been cleaning up my motor as well. definetly a greasy pig. also painted the valve covers. bout to go into the garage and fire up the tunes and work for awhile.
keep us posted!
post #65 of 89 (permalink) Old 02-21-2011, 12:43 PM Thread Starter
Well I still need to take out the stock lines and put adapters in for the trans. I'm using -8AN lines for the fuel and trans, -4AN lines for the oil feed and -10AN lines for the oil drain.
Got the motor apart and cleaned up. I painted the pump but it didn't come out anywhere near how i wanted it so now i have to redo that and the tappet cover. I just need to get some new gaskets and a damn keyway cause i lost the one that was in the pump when i took it off. here are some crappy cell phone pics.
Kyle
post #66 of 89 (permalink) Old 02-28-2011, 10:40 AM Thread Starter
Finally got some real work done this weekend. Built my gantry crane, got the frame stripped and cleaned and mounted the bed. With the height the bed is sitting right now i should be able to fit 35s w/o a lift.
And a few hours later...
next
Built some bed mounts
goodies
Kyle
post #67 of 89 (permalink) Old 03-02-2011, 09:48 PM Thread Starter
more progress
Where the stacks are gonna go
Mock up of where the cab needs to sit. Once the running boards are on it only about 2" of the frame will be visable. Also with all the room under the truck i'm toying with the idea of putting the radiator under the truck with electric fans.
"new" steering shaft. Top half is orig column and the bottom is the stock dodge piece.
Where it's pretty much gonna ride at. I need to get some junk tires for mock up but i think with no lift i'll be able to run 35s or 37s
Kyle
post #68 of 89 (permalink) Old 03-02-2011, 11:37 PM
looks great so far. where at in NJ are you located? not too far from NJ and would like to check this out if you have time
the dodge donor however...
do you still have the doors? discovered mine are almost completely rusted out at the bottom edge along the rockers. also, my hood is pretty beat. im missing tail lights, and also a rear bumper.
post #69 of 89 (permalink) Old 03-03-2011, 08:28 AM
Guntruck54's Avatar
Dude, love the rig and the paint on the block. Glad you take lots of pics!
I will be subcribing!
1992 5.9 12V, New to the Cummins Diesel World.
Guntruck54 is offline
post #70 of 89 (permalink) Old 03-03-2011, 01:25 PM Thread Starter
thanks guys. The truck is in tabernacle which is about 35min from Philly.
Sorry doors are gone already. I know someone that might have a few good ones though.
Hopefully i'll get to put the rest of the motor together saturday and get the cab mounted up. I'm trying to figure out the best way to make cab mounts. I'm either going to build up off the frame to the cab how the stock mounts would. Or i'm going to build something off the top of the frame then build off of that, this way the cab mounts aren't 10" tall.
Kyle
post #71 of 89 (permalink) Old 03-03-2011, 01:38 PM
Ram3500Dually's Avatar
Is that a 51 Dodge?
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
post #72 of 89 (permalink) Old 03-03-2011, 03:03 PM Thread Starter
haha well it used to be. Now it's sectioned and shrunken. It's actually the stage car for the broadway show Grease. It's the beat up greased lightning. It's also electric and only goes 5mph lol
Kyle
